Results 1 to 8 of 8
Thread: 2004 325i wagon brakes and rotor
    Feb 2018
    United States
    325i wagon 2004
    I need to replace the front rotors and brakes on my 2004 325i wagon. Anything I need to know before I start? What brand of rotors and brakes are you suggesting? Should I reuse the same brake sensor or replaced with new one? The reason that I am replacing is that when I brake the car jumps (vibrate) a little and pull to the right. I don't think that they were ever replaced the car has 71k miles I just bought it a month ago.
    Thank you all
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    BMW, Zimmerman, Pagid, Jurid, & ATE are OEM suppliers for rotors and pads. Replacing the wear sensor will yield the best result. I also highly recommend replacing all 4 caliper slide pins and rubber guides.
    For your vibration and pulling, I would take a very close look at the calipers and ensure one isn't sticking. If it is sticking, you will need to determine if its the caliper or the hose and replace whats necessary.
    Dec 2013
    Chicagoland area
    EXOTICS
    Inspect your suspension, as worn or failing FCAB's exhibit the same symptoms.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    +1
    ATE sells the boots in a kit, I would just clean the pins really well. Also inspect your hoses if you see any crack, especially at the bends, replace them.
    From one of our forum sponsors: https://www.ecstuning.com/b-ate-part...111157038~ate/
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    Quote Originally Posted by MIKYZZ4 View Post
    Thank you...but for most novices here, and I'm dumb as a brick, but what are THE worn or failing as you describe as "FCAB's" What is 'FCAB' with an 's' meaning more than one? Not trying to a wise-ass here...but I see this abbreviated stuff a lot here and on other BMW forums too. Many of us are IGNORANT yet willing to learn. We are not, I'll speak for myself, shop experts and we are not trying to overestimate the value BMW experts or their intelligence. NO, please explain if you really wish...what is FCAB...I'm really..quite REALLY very stupid..or I wouldn't be here asking..yet again..why am I not paying 'indies' to do my work on my BMW? Answer: I cannot afford it!
    Dec 2013
    Chicagoland area
    EXOTICS
    Sure, no problem to spell it out for the novices, as I was one myself.
    Front Control Arm Bushings = FCABs
    And yes, there is one for each control arm,
    1-left & 1-right
    dworthy's Avatar
    Nov 2010
    Yeah, you will feel the FCAB's as you go over bumps, and you will hear a clunk and/or feel the steering wheel move a touch. Also you may feel them under braking, as the wheel will jerk to one side or the other as you apply the brakes.
    Darin
    Current:
    Past:
    M-Flight Member
    Feb 2018
    United States
    325i wagon 2004
    I replaced the brakes, rotor, rubbers, pins, sensor and no more pulling and vibration,it brakes like a charm. Bought the kit from oembimmerparts.
  1. Replies: 2
    Last Post: 09-02-2012, 10:37 PM
  2. Zimmerman Brakes and Rotors?
    By IMAGE&STYLE in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-15-2004, 02:50 AM
  3. Suggestions for 2000 740IL Brakes and Rotors
    By erikdg in forum 1995 - 2001 (E38)
    Last Post: 07-31-2003, 01:26 AM
  4. Brakes and Rotors for 2000 740IL
    By erikdg in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-30-2003, 10:18 PM
  5. Changing Brakes and Rotors?
    By Scho in forum 1992 - 1999 M3 (E36)
    Last Post: 06-27-2002, 08:49 PM
