Page 2 of 2 FirstFirst 12
Results 26 to 47 of 47
Thread: E46 LS swap turned street/track rat
  1. #26
    Aug 2012
    Central, MD
    1995 M3
    I LOVE Pegasus!
  2. #27
    Sep 2016
    WI
    01 330Ci
    Quote Originally Posted by aeronaut View Post
    I LOVE Pegasus!
    Yeah that place is awesome. Even better they have a newer delivery service that caters to this region so if I have my order in before 3pm (as long as it's an in-stock item) it'll be sitting on my front porch about noon the next day, and it costs less than USPS rates. The hose I butchered had a replacement in less than 24 hours for about $5 in shipping costs.
    In other news...IT'S ALIVE!!! (Insert hearty pirate laugh here)
  3. #28
    Sep 2016
    WI
    01 330Ci
  4. #29
    Sep 2016
    WI
    01 330Ci
    Not the best video but it’s what I’ve got at the moment.
  5. #30
    Aug 2012
    Central, MD
    1995 M3
    It's alive!!! Awesome.
  6. #31
    Sep 2016
    WI
    01 330Ci
    Here's the first start. It's shaky as soon as the car fires up. The camera was locked onto a portable table in the shop, but the beast shook everything in there including the camera.
  7. #32
    Vancouver, BC Ca
    1993 325is
    I know you don't have any real driving experience with the car just yet, but what's your overall impression of the ChaseBays radiator? Good quality and fit and finish? Worth the $450 it costs? I'm torn between that one and the one from Ry-Wire.
  8. #33
    Sep 2016
    WI
    01 330Ci
    Quote Originally Posted by jakermac View Post
    My impression so far is it was worth the money. Welds are all great. The built in fan bracket is thick, heavy duty aluminum. Customer service is good as well. I had an idea/question for mounting it and wanted to get input from them. I got a pretty quick email reply that answered exactly what I needed.
    I also have their raised radiator filler neck, overflow tank, and T56 to BMW master clutch line they all seem built very well. No complaints so far.
  9. #34
    mslevin's Avatar
    mslevin is offline Have you checked RealOEM? BMW CCA Member
    Dec 2015
    Sunnyvale, CA
    E36, E38, E46
    Looks like you have a Cartek battery isolator in there, what do you think of it? Thinking of getting one for my new build.
  10. #35
    Sep 2016
    WI
    01 330Ci
    Quote Originally Posted by mslevin View Post
    I do have the Cartek GT isolator. I love it. It's smaller than a deck of cards and the installation is super easy. I like having one button for a master power switch and as many kill switches as I need around the car. Right now I just have the one to the left side of the dash for a corner worker to access. It's on the expensive side, but worth it to me. The solid state electronics have built in over voltage protection as well. Solid state is where it's at!
    EDIT: It also has a 40 amp control circuit that activates an ECU (or whatever you want under 40 amps) when the master power is turned on. I wired that to a toggle switch so that I can run other circuits, or test electrics, without having the ECU and fuel pumps kick on.
  11. #36
    mslevin's Avatar
    Dec 2015
    Sunnyvale, CA
    E36, E38, E46
    Quote Originally Posted by Matt330LS View Post
    Appreciate the info. That separate control circuit sounds really useful, I've been thinking of ways to turn on lights/dash separately without the main power coming on.
  12. #37
    Sep 2016
    WI
    01 330Ci
    Not much to report since I got the car running. That was a good stopping point me and after it fired I had to turn my attention to other things for a bit. But, I did tinker with the base tune on the car after I got it fired up. AFR was all over the place at idle initially. Long story short the base fuel pressure I put in the software didn't equal actual fuel pressure. I was using a mechanical gauge and it wasn't as accurate as I'd have liked so I swapped out for a Holley pressure sensor and I'm getting fuel PSI readings to the tenth of a pound. Made the software adjustments and the FPR adjustments and now it's good to go.
    Also swapped out the wheels that were on the car. Got a great deal in the classifieds here on some used Team Dynamics Pro Race 1.2 17x9 with some RS3s that have a little life left in them. They're gloss black, which wouldn't have been my first choice but for the price and how pristine they are for used wheels I'll deal with it.
    I've had only an e-brake functional on this thing since I tore it down so I pulled the trigger yesterday on the M-Performance brake upgrade. Figured now that it starts it needs to stop as well. Got it through Turner but it's an ECS kit that retrofits the 135i 6-piston Brembos to the E46. It'll be a bit before I can get back out to the garage to install them but they were out of stock for awhile so I figured I'd better grab the kit while I could (and while they're on sale) and set them on the shelf.
  13. #38
    Aug 2020
    Western Australia
    E46
    Great looking build! Did you get any further with the ABS? I'm half way through an LS swap in an E46 and wiring is coming up soon. I'd like to keep the ABS working but bin all other BMW wiring but I can't find any solid info on whether it will work or not.
  14. #39
    Vancouver, BC Ca
    1993 325is
    For sure the E46 M3 ABS can operate as a stand alone system. Many many people (including me) wire it in as a stand alone in other chassis (E36 in my case). However, that does not include the DSC functionality.
  15. #40
    Sep 2016
    WI
    01 330Ci
    Quote Originally Posted by WestozE46 View Post
    Thank you. For ABS it'll work you just have to go with a stand-alone setup. My car (2001 330Ci) came equipped with the MK60 unit so I just need to get a stand-alone harness. You have to keep the wheel speed sensors, brake pressure sensors, and yaw sensor as inputs, plus power and ground to the ABS unit. There are a few companies that make complete kits or the individual parts necessary (such as the harness).
  16. #41
    Apr 2014
    Cardiff, UK
    E39 528i, E46 325ti
    Great build and sounds awesome. Hats off to you.
    Did you make those front floor plates? They look nice and tidy.
  17. #42
    Sep 2016
    WI
    01 330Ci
    Thanks, it's been a long road so far with a little bit still to go.
    I did not make those floor plates. I had a shop near me make those along with the rear firewall and package tray, the mounting points to be able to bolt my dash to the roll cage cross bar and some solid jack points under the car.
  18. #43
    Apr 2014
    Cardiff, UK
    E39 528i, E46 325ti
    Well its looking good so far.
    Ah ok, thanks very much. I was considering something similar for the my front floor pans and like the way yours fit neatly.
  19. #44
    Sep 2016
    WI
    01 330Ci
    Didn’t realize how long it’s been since I posted here. Long and short of it is I got about 370 miles of backroads and cruising, but no track time last summer. I’ve got a couple things to tend to on the car but will finally be good to head to the track this summer. Here’s a quick video shortly after I got the exhaust installed. I recommend you turn up your speakers for this beast…
  20. #45
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    Wondering how the track day shakedowns have gone this summer???
  21. #46
    Aug 2012
    Central, MD
    1995 M3
    Update Update Update!
  22. #47
    Springfield, IL
    The people want what they want.
  1. Replies: 2
    Last Post: 01-31-2015, 11:16 AM
  2. E46 LS Swap Headers that WORK!!!
    By greenmonster138 in forum Engine Conversions
    Last Post: 05-28-2014, 06:36 PM
  3. E46 LS Swap Wiring Questions
    By TON3R in forum Engine Conversions
    Last Post: 10-23-2012, 09:52 AM
  4. where's the e46 LS swap???
    By Maersk in forum Engine Conversions
    Last Post: 12-04-2010, 07:22 PM
  5. looking for a street/track rat - trading/selling my drift car
    By mattmartindrift in forum Middle Atlantic - US
    Last Post: 09-21-2009, 05:09 PM
