Results 1 to 25 of 36
Thread: E36 Weight
    West V
    1995 M3
    E36 Weight
    Can someone tell me generally what a stripped down E36 is gonna come in at or point me to the thread? I can't find any specific topics.
    1995 E36 M3
    Removed all stock interior except the dash, added 2 Sparco Evo seats, roll bar, carbon sunroof delete, lightweight battery ~14lbs, a/c delete, and the only glass is windshield and rear (rear quarters are Plexiglas cutouts). Anyone venture a guess? 2800?
    Apr 2016
    Irvine, CA
    99 328is, 03 X5
    Depending on how much fuel, I would say 2700-2750.
    Richmond, VA
    E82 128i, E36 M3
    Probably 2800-2850 if you still have the heater core and door windows
    West V
    1995 M3
    No door windows. Does have core. I even heated and scrapped up all the sound deadening in the tub and removed the trans tunnel blanket for heat tape.
    Apr 2013
    Alabama
    1995 M3 Coupe
    yea, 2800 is prob right. Our 325i is 2600 with a quarter tank of gas and no driver...but we cut the doors down to nothing and still have more to cut.
    1995 M3...Screwed
    West V
    1995 M3
    Quote Originally Posted by Jab31169 View Post
    Curious do you have both seats in the car?
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    May 2009
    Richmond, VA
    Spec3 & MCoupe
    See Post #33 of my previous build. Gutted interior except dash and stock front seats, no rollbar, heat, A/C, and power windows still functional. The weight was 2,680 without driver and with the fuel light on.
    https://www.bimmerforums.com/forum/s...c3-Build/page2
    Apr 2013
    Alabama
    1995 M3 Coupe
    Quote Originally Posted by BacDoc View Post
    No that's our champcar race weight with no cool suit. With the seat, mounts, and belts it prob adds 35 pounds or so. We gutted the trunk lid completely, gutted the front doors, and we still have to cut out the rear doors and rear deck lid. Our biggest weight savings tho was moving from our stock exhaust to the bimmerworld race exhaust. Only the front windshield is glass. All rubber door seals have been pulled as well. We still have a lot of the stock wiring under the dash left and some other random bits we could cut out.
    1995 M3...Screwed
    West V
    1995 M3
    Quote Originally Posted by OCRentAPopo View Post
    Awesome. Thanks. I would love to come in under 2700.
    I'm pretty close to that. Any resources on wiring. I'm scared to death to cut and remove with the DME or whatever that security crap is on this car.
    Apr 2013
    Alabama
    1995 M3 Coupe
    Haven't really looked into it yet, still trying to cut all the other weight out first. Working on the bumper supports (Cut them down, should net about 10lbs out of both combined), and then the hood support structure. I imagine its a nightmare just looking at all that wiring....but we will prob do that last if I was a betting man. Also keep in mind we have a full cage in the car as well.
    1995 M3...Screwed
    Jan 2002
    North Augusta SC
    Mine is right at 2800 with a half tank of gas. S54 conversion with full glass, power windows, full cage, two race seats/harnesses, cool suit rig, no AC, standard battery. I believe S54 adds about 50#, so I would think you could easily get down to 2700.
    '95 M3 S54 Track Toy
    '19 X5 40i M-Sport
    '16 Cayman GT4
    ‘23 GR Corolla
    Richmond, VA
    E82 128i, E36 M3
    For wiring, this post in my build has the basics of what I did. Make a list of what you want to keep, get comfy with the ETM, label every plug when disconnecting, and prepare to spend a lot of hours tracing wires and verifying before you cut. It's long and tedious but the end result is well worth it.
    https://www.bimmerforums.com/forum/s...7#post29561367
    As for the weight.. I'm really curious to see what my car weighs next week. Fully stripped interior, thinned chassis harness, gutted doors, stock glass and side window glass, full aero, etc. I'll post up what it is next week.
    PA
    ZHP, 95 325i, 95 318ti
    95 325i- gutted, S52, all glass in place, full cage, 2 Sparco seats, no heat, thinned harness, lightweight battery, wheels, carbon sunroof delete etc. 2650 1/2 tank & no driver.
    With driver
    Sent from my N9519 using Tapatalk
    __________________________________________________ ___________
    West V
    1995 M3
    Said car...
    Apr 2014
    Slidell, LA
    Many
    [/url
    This is a fully caged car with me in it (220lbs) and a 1/4 tank of gas, full glass. Full racecar setup though. Also note this is the first weight after building the car. I have to ballast about 200lbs for my class and will use that weight to get a 50/50 weight distribution in the car.
    Sep 2010
    mid-atlantic
    70's p-cars
    ...and a pair of needlenose pliers
    Apr 2014
    Slidell, LA
    Many
    Quote Originally Posted by emoore924 View Post
    Good eye
    Feb 2016
    NJ
    E36 M3 SEDAN
    Quote Originally Posted by hoki06 View Post
    I just went through the process of a major thinning of my harness and I ended up bricking my car, even after starting after every connector cut. The culprit? The right hand dash relay wires were loose after working on all of the connectors. I also had a previous auto conversion park conversion wire come loose. It took a while to figure this all out... It's not that bad though. Just be meticulous...
    Sep 2013
    Perth, Australia
    2011 BMW 135i
    1995 E36 M3
    Mine came in at 1298kgs (2861lbs) with
    Full tank, no driver
    Stripped interior except dash
    2 sparco seats on Vac mounts.
    Carbon sunroof delete
    Half cage
    Stock battery
    Stock glass
    Stock electrics (except stereo harness removed)
    Still had AC.
    17x9 Apex wheels
    3" exhaust with cat, resonator, muffler.
    So yours should be a good chunk lighter with the plexi, smaller battery and no air con.
    Vancouver, BC Ca
    1993 325is
    I got my 93 325is down to 2,380 with all interior panels, but lots of other weight reduction efforts. No cage but still full interior (rear seat delete, lightweight front seats but the rest of the interior is still there).
    West V
    1995 M3
    Quote Originally Posted by jakermac View Post
    Wow. I have a new goal!
    Richmond, VA
    E82 128i, E36 M3
    Fully stripped race car with a 1/2 tank of fuel, stock glass minus the door windows, full aero, 25 lbs taken out of the chassis, E46 flares with 285 Hoosiers on 18x10 wheels, etc. etc.
    Build thread: https://www.bimmerforums.com/forum/s...6-M3-track-car
    Colorado
    My E36 supercar
    With or without the motor? Scale is off by 500 lbs?
    Would like to know what you did.
    Vancouver, BC Ca
    1993 325is
    The list is a long one. Here are some highlights:
    Vis Racing 18lb CF hood
    MA Shaw 9 lb CF trunk
    Toms Motorsports 9lb CF bucket seats with no sliders
    Rear seat delete
    CF 2 1/2lb sunroof plug
    1997 Z3 aluminum single Vanos block
    UUC aluminum flywheel
    S52 crank with 12lbs carved off
    318is 168mm rear diff with strong old school LSD
    1995 M3 LTW aluminum doors
    A/C delete
    Engine fan and A/C fan delete with 2 1/2lb Spal fan
    Lightweight single 3" stainless exhaust with stainless headers
    Lightweight front brakes - aluminum calipers, aluminum rotor hats with small rotor rings
    2gal of gas
    Etc...
    Dec 2014
    Indianapolis, IN
    1995 M3 LTW 2001 325i
    So what's the lightest one that get's driven on the street and to the track?
  1. E36 Weights
    By Tommy R in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-10-2006, 11:00 AM
  2. AutoX E36 Weight & Power Vs Cost
    By megatron in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 09-19-2005, 03:22 PM
  3. E36 Weight Loss
    By Low Level in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-09-2005, 05:27 PM
  4. 325 auto tranny, e36 weight?
    By KLEAR in forum 1991 - 1999 (E36)
    Last Post: 08-07-2003, 12:59 AM
  5. E36 Weight Comparison
    By 98323iConv in forum 1991 - 1999 (E36)
    Last Post: 09-18-2002, 05:37 PM
