Results 1 to 6 of 6
Thread: Buying e46 with 190k miles
    Mar 2018
    Los Angeles
    E92, e46
    I need a car and I was looking into an e46 since my e92 is being repaired from an accident. Anyways the price on the e46 is 1000 and it runs great. Only issue is that it is smoking my guess is a valve cover gasket leak, and the maintenance in the past of the car is unknown since it was bought from an auction. Just thinking if it could be a good buy or not and its a manual transmission.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    Well for 1k there isn't too much that can't go wrong. Yeah, there are always plenty of problems with the older cars, and that smoking can be multiple things.
    So to help up to help you:
    Year:
    Model:
    Color of smoke:
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Mar 2018
    Ohio
    2001 BMW 325xi, e46, m54
    Sounds like a good deal if it's running. I just bought an 01 325xi with 140,000 miles for $550... Has a blown head gasket but I figured I'd take a risk and see how bad the damage is. I needed a project anyways. As I've been working on it I have found some things that need to be done besides the head gasket issues... Maybe things you would want to keep in mind for the future.
    1.Vacuum from Intake manifold to secondary air pump broken (along with all other vacuum hoses being brittle and cracked)
    2. Hose to heater core from radiator expansion bay had a lot of small leaks
    3. CCV lines are plastic and very brittle so I broke one or 2 pretty easily. Everyone suggests replacing them after a while anyways.
    Good luck with ur new ride. I would say that for $1000 even if it bites the dust before long you could either fix it, or part it out and easily get your money back
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    I'm new to BMW and to the E46, now a year. Service records....if there are any can tell you a lot if you know what e46 cars typically have issues with and what you are willing to fix. Oil leaking from the 'oil filter housing gasket' is I believe a most common, even from 100k miles. Service records may indicate that repair. Other common issues usually involve serpentine belt pulleys, water pump. Even if these have been replaced some time ago, they may need now to be replaced again. Alternators do not give much past 200k...if you were not a high AC user...Replacing an alternator on an in-line 6 requires removal of the intake manifold...My take here, for a cheap and running, few bucks spent, drive it to the ground..or find love with it and $pend!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Replacing the alternator does not require the removal of intake manifold!!! I had the alternator in my 2001 330Ci out several times without removing the manifold.
    California
    325e 535i M5 325iT 330i
    Quote Originally Posted by MarcoZandrini View Post
    Agreeing with Marco here. Hint: You will need a 16mm socket and a long handle to get lots of torque.
  1. Sell e46 with 100k miles for a 206K 98 M3? Worth it for $5500?
    By Audley in forum 1992 - 1999 M3 (E36)
    Last Post: 02-14-2018, 02:51 PM
  2. Buy E46 with no key?
    By Honolulu in forum 1999 - 2006 (E46)
    Last Post: 12-08-2016, 10:48 AM
  3. Should I buy m3 with 150k miles
    By Marin2234 in forum 2001 - 2006 M3 (E46)
    Last Post: 02-24-2016, 10:20 PM
  4. Buy 335i with 92k miles?
    By epborden in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 08-28-2015, 04:05 PM
  5. How long will a E46 with 165k miles run?
    By Sprint in forum 1999 - 2006 (E46)
    Last Post: 06-04-2003, 06:49 PM
