Never been tracked or drifted, it's just not my thing personally. Car comes with tons of spare parts, duplicates of all body modules, spare cluster, extra fuse box relays, brand new door lock actuator, spare rear trailing arms, I can go on and on...
I went through my receipts finally and there's been an insane amount of money put into this car at this point. Clock is just about to hit 195k but has only had 50k put on over the last decade since the rebuild. I've come to accept a certain amount of oil leaking from the e36 chassis, so it does have that. I keep it full of 10-40 synthetic with a full change and new filter EVERY 6k miles.
The exhaust is all new and CA compliant besides the Euro e36 M3 headers. (Since they have OEM stamps, I've typically gotten them to smog it as long as I change the intake elbow and airbox). The cat is on 2.5" v-bands if you would like to make a track pipe.
The ride is still phenomenal and I keep up with almost any car in the canyons. I can leave most of my e36 buddies minutes behind in two miles of road. Hilariously, that's not even an exaggeration. 200 tread street slicks are on the front wheels, 400 tread Potenzas of some sort are on the rears, and unfortunately it has a 3.38 welded diff installed, as my roommate really wanted my built 3.46 lsd.
It's for sure a car everyone can love driving, though I know aesthetically it's not everyone cup of tea. (That said I never get any attention from cops and it's never been broken into.)
Would like to have $8,000 for it, if not I'll part it out for much more.
Build thread:
https://www.bimmerforums.com/forum/s...-stole-my-life
Quick spec sheet:
__Engine__
***Mostly stock OBDI Vanos 2.5 liter w/ 195k miles
Turner Motorsports /Conforti chip tune (91 octane ONLY)
Vorshlag poly competition motor mounts
Turner Motorsports all aluminum underdrive pulleys
1595mm x 21mm 6 groove belt
Upgraded Bosch 140amp alternator (rebuilt 08-2015)
Heavy duty battery (08-2015)
Samco silicone intake boot
All silicone 3-ply reinforced vacuum hoses
Bimmian gunmetal billet aluminum oil cap
Updated oil filter housing w/ threaded plugs
Gates reinforced fuel injection hose
Ultrasonic cleaned & bench matched green top injectors
M Euro Sport billet aluminum throttle bushing
Eurosport intake w/ aluminized kevlar heat shielding
__Exhaust__
OEM euro e36 M3 hydroformed equal length long tube headers
VAC euro e36 M3 header flangers
Custom 2.5" stainless steel piping by West Coast Muffler
Vibrant 1140 stainless 2.5" ultra quiet resonator
CA compliant catalytic converter on 2.5" v-band flanges
Remus 2.5" single inlet muffler w/ dual out squared tips
__Cooling__
SPAL 16" 1300cfm gasketed pusher fan (not installed)
Custom front side aluminum fan shroud
Mishimoto e36 full aluminum radiator
Zionsville rear side full aluminum shroud w/ integrated overflow tank
SPAL 16" 1300cfm gasketed puller fan (runs full time via relay)
Stewart Components performance water pump
Aluminum water pump shaft nut
80c thermostat
All silicone 4-ply reinforced hosing w/ heater core bypass
Evans NPG waterless coolant (used full time since rebuild)
__Drivetrain__
Getrag 5 speed manual transmission
Vorshlag 80A poly transmission mounts
AKG stage II quick shiter (black delrin knob)
AKG DTM dual shear selector rod
Turner Motorsports stainless clutch line
__Rear end__
AKG 95A poly subframe bushings
Welded 3.38 differential
Active Autowerke differential brace + upgraded bolt
__Suspension__
Eibach Euro Pro-Street valve-matched coilovers (separate spring in rear)
Eibach 28mm front adjustable sway bar w/ poly bushings
21mm rear adjustable sway bar w/ poly bushings
AKG 75D poly front control arm bushings (centered)
SPC rear camber arms
Syncro Design Works spherical rear trailing arm bearings
__Body__
***New windshield installed 04-14-2015
VIS carbon fiber hood (stock latch, no vents)
VIS carbon fiber trunk
S2R Tuning fiberglass sunroof delete
ZKW glass headlights w/ 12mil Lamin-X
OEM e36 M3 bumper
OEM luxury slats
ECS matte blackout grilles
OEM front license plate delete strip
OEM fog delete blanks
Ikon Motorsports AC Schnitzer style polyurethane lip
Motion Motorsports e36 M3 aluminum underpanel
OEM e36 M3 side moldings
Eagle Eyes smoked tail lights
e46 rectangular jack pads
***Bavarian Autosport ultimate car cover
__Bracing__
OEM X-Brace
Front subframe reinforcement (weld-in)
Front strut tower reinforcement plates (bolt-in)
Rear subframe reinforcement (weld-in)
Rear sway bar tab reinforcement (weld-in)
Rear trailing arm pocket reinforcement (weld-in)
Rogue Engineering rear shock mount plates (bolt-in)
__Wheels__
Kosei K-1 17x8.5 40mm offset - all corners
Full size 17x8.5 40mm offset Kosei K-1 spare wheel
Flush Italian removable valve stems
Motorsport Hardware bulletnose hex end 90mm studs
Velocity Motorcars 12mm spacers w/ lockdown
__Brakes__
Fully rebuilt OEM calipers, painted black
Rotora Drilled & Slotted discs (front)
ATE solid discs (rear)
Hawk HPS brake pads (all corners)
Brass caliper guide bushings - all corners
Speed bleeder valves - all corners
Gruven Parts front brake cooling back plates
Optional/removable brake ducting
__Interior__
Special edition black Momo Competition 350mm steering wheel
Rogue Engineering steering wheel quick release
Momo #2008 early e36 hub adapter
Rebuilt steering lock housing w/ re-keyed tumbler + new ignition switch
Mason Engineering steel short kick clutch pedal
Ultimate Pedals aluminum anti-slip pedals w/ custom heel toe mod + rubber grips
ARD adjustable clutch stop
Mech-less Pioneer head unit
BavSound 20mm silk dome tweeters
BavSound 65mm midrange speakers
BavSound 130mm midbass speakers
BavSound 6x9 rear midbass w/ 20mm silk dome tweeters
LED dome light + map light mod
OEM floor lighting (tied into dome light)
Hard-wired for Valentine V-1 radar detector
Valentine V-1 remote display is integrated into the instrument cluster
OBC delete
Custom aluminum door panels w/ nylon door pulls
Custom aluminum glovebox delete panel
Custom black anodized diamond plate floor pans (Front + Rear)
Sparco Pro2000 seats (brand new) black dyed stitching)
Motion Motorsports infinite adjustable side mounts
VAC black anodized floor mount adapters
VAC 3 point belt brackets + new receptacles
IGGEE black vinyl rear seat cover
***All tar scraped, cleaned, and painted w/ black epoxy paint
Ive followed your build off and on ever since i got my first E36. Youve been an inspiration and ive always admired your car. That being said, i for sure thought it was S52 powered for some reason.
Anyways, good luck with sale
Thanks dude, very kind words. Honestly I've always been waiting for the little m50 to fizzle out but it's just been so strong! And with the 3.46 gearing I ran it never felt underpowered. The plan was always to drop in a reworked s50, but just never had to.
The s50 long block can be sold with the car for cheap, as I kind of doubt we're going to do anything else with it.
Weather is getting nice too quick though, so I may end up just parting her out soon.
^ A gentleman AND a scholar. Thanks man
This car is awesome. Is it active or salvage title.
Clean title, which is what I think you mean. I still drive it, just mostly to keep all the fluids moving.
Only been touched once, and that was when a drunk dude grazed the bumper and corner light on the driver side. Fender was untouched as well as the hood, but the bumper support bracket was tweaked, bumper cracked, corner light cracked, and the tabs on my headlights cracked. Literally everything was replaced and lines up like new. This was documented in the build thread with photos.
interested in the CF hood if you part it. Does it work good with no pins? VIS site says "requires" them
Definitely works without them. Obviously not recommended at high speeds, but I regularly do 70-85 with a couple trips just above 100 and it's been rock solid without them. (This is knowing that I wasn't going to keep the car much longer. Otherwise it would have had pins since day 1.)
I took my time and adjusted my hood catch, certainly wasn't hard though.
How's the sale going?
Well it seems like nobody wants to buy a well documented car for about a third the cost to build one, so part out will likely start in a week or two.
Where is the car located?
Concord, CA 94521
get the car off his hands groff!
Bump, haven't been motivated to see her go, but the 2002 is getting close to finished and needs my full attention.
Car can be wrapped almost any color, so don't let the Sharpie bother you too much. Will only wait a couple weeks before I finally start parting out stuff.
Thank you,
Update, just parting out now. All the parts are available, forum members get first dibs:
___Engine___
***Mostly stock OBDI Vanos 2.5 liter w/195k miles
SOLD
Eurosport intake w/ aluminized kevlar heat shielding (seals against hood)
___Exhaust___
Custom 2.5" stainless steel piping by West Coast Muffler in Concord, CA 2017
___Cooling___
SPAL 16" 1300cfm gasketed pusher fan (not yet installed)
SPAL 16" 1300cfm gasketed puller fan (wired to run full time via relay)
80c thermostat
___Drivetrain___
Turner Motorsports stainless slutch line
___Rear end___
___Suspension___
SOLD
SOLD
SOLD
___Body___
SOLD
OEM e36 M3 bumper
OEM luxury slats
___Bracing___
OEM X-Brace
Front subframe (totally un-cracked or damaged)
___Wheels___
SOLD
SOLD
Motorsport Hardware bulletnose hex end 90mm studs - all corners
SOLD
___Brakes___
Optional/removable brake ducting (intake ducts, 3" hoses, flanges)
___Interior___
(x1) Sparco Pro2000 fixed back (brand new, blacked out stitching)
SOLD
Momo #2008 early e36 hub adapter (retains horn, retains turn canceling, no airbag light)
BavSound 6x9 rear midbass w/ 20mm silk dome tweeters + mounting adapters
LED dome light + LED map light mod
Valentine V-1 stealth remote display integrated into the instrument cluster
OBC delete
