Hi Guys,
I'm new to the coding area,
Unfortunately my BMW 320d e92 coupe has a really bad map on the ecu causing the car all sorts of issues,
The car was remapped by a previous owner and not encoded the vin to most modules,
I'm trying to use the e89 data to update the ecu to the latest software to remove the map.
but when I took the ZB No 8506162 for the DME/DDE Module the WinKFP it popped up with this error,
Error 704:
Error on determining the ZB number!
Check assembly file
And Code 3000
And Code 995065
This is currently preventing me updating the ECU!
I also updated the air bags, now its saying code mismatch on DIS GTI, which I believe you need to recode them by resetting the system time.
Sorry I'm new to this coding thing :( , as I work in IT I thought this would be an decent challenge.
So does anyone have an idea how to get the zusb to recognise the ECU ZB code to update?
So I can salvage this poor car!
Thanks in Advance
Caleb
