Up until now I have been successfully using NCS Expert with Revtor's excellent NCS Dummy to code my two E31 cars, my E39 M5 and E36 M3. All with an ADS cable, of course.
Feeling cocky, I went into back into my 95 850Ci went about trying to see why my newly bought key would not initialize. While looking at the EWS module, I see that there was a selection for EWS III and that it was selected not enabled. Thinking that someone prior to me disabled it, I re-enabled it knowing that I could always go back in and disable it if it didn't work. I tried starting the car, and all it did was crank and not start, so I went back in and disabled EWS III and I get the following: COAPI-2060: Coding Errors (general)
C_EWS, C_C_AUFTRAG: ERROR_ECU_PARAMETER_WRITE
So now I am able to read the EWS module, but I am unable to write to it. Along with this change, I am now unable to read the DWA module. (I was able to read and write to it previously). I get this error:
Error during ZCSUT conversion
COAPI-2020 error: No answer from ECU
IFH-0009: NO RESPONSE FROM CONTROLUNIT
Is there any fix to these errors?
Mike
