Results 1 to 3 of 3
Thread: SWAP e30 with S52B32 many questions for a race engine rebuild
    Dec 2011
    Montreal Québec
    Question SWAP e30 with S52B32 many questions for a race engine rebuild
    It will be complete rebuild :
    ALREADY IN STOCK
    e34 oil pan with Achille motorsport baffle
    Knife edge balanced crank shaft
    ACL Race crank and rod bearing
    PAUTER forged rod
    Sunbelt race cam
    euro oïl filter housing
    Solid lifters kit
    Stewart waterpump
    Bimmerworld silicone boot 3.5
    S50 intake
    Cometic head gasket
    Header Supersprint eBay copy
    Power steering delete
    ??? QUESTIONS -What is the best $$$ for HP???
    STOCK 10,5:1 compression pistons or 11:1?
    HD spring with the use of the Sunbelt race cam?
    Bigger valves?
    Port match?
    30lbs injectors?
    Engine management : Megasquirt ?
    May 2017
    Flowery Branch, Georgia
    69 Ferrari Replica w/M73
    I'd go with 10.5 pistons, HD springs, 30lb injectors, and DEFINITELY one of the MS3Pro ECUs. 10.5 compression will help the engine last longer, HD springs are a must for a high lift cam, and 30lb injectors will give you plenty of fuel without being too big (stock was around 20lbs, IIRC). I'm runnning an MS3Pro to control my M73, and is has more than enough I/O for what you're doing. Especially for the price, you can't beat it.
    Dec 2011
    Montreal Québec
    Thank’s
  1. Piston Rings Question for M50/M52 Engine Rebuild
    By MrMuddle in forum Forced Induction
    Last Post: 01-27-2018, 07:30 PM
  2. Racers with Cool "suits" - Questions for you.
    By ChadsM3 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-16-2009, 05:11 PM
  3. An E30 with a new 335 E90? or 135 Engine swap
    By mcchris808 in forum 1983 - 1991 (E30)
    Last Post: 03-21-2009, 08:14 PM
  4. people with NOS, some questions for you...
    By speshuled619 in forum Forced Induction
    Last Post: 11-14-2003, 08:00 AM
  5. Many question for a new member
    By B5Beauty in forum 1975 - 1983 (E21)
    Last Post: 10-02-2003, 06:44 PM
