Results 1 to 7 of 7
Thread: vibration through hole car and wheel when turning steering wheel
    Sep 2016
    West Plains MO.
    2004 BMW 325i
    Just started. When turning steering wheel there is a sound like the motor is agince frame and makes alot of noise and vibration in car. I changed the reservoir with filter and no help. Anyone have this happen. 2004 325i
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    So does this happen while moving or only stationary? Did you bleed the power system properly after dumping the fluid and replacing the reservoir?
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Sep 2016
    West Plains MO.
    2004 BMW 325i
    It is all the time. Really bad when turning the wheel setting still but when I raise the RPM it is not as bad. When I step on the gas to go around a corner and the rpm goes up the noise gets better but when pulling in a parking the sound goes up and the vibration gets bad. The fluid is moving in the reservoir.
    Sep 2016
    West Plains MO.
    2004 BMW 325i
    dworthy's Avatar
    Nov 2010
    Still didn't answer my question: Did you bleed the system, and do you know how?
    Just in case you don't:
    1) Fill the reservoir to the max on the stick
    2) Raise the front of the car off the ground
    3) Go lock to lock on the steering wheel 5 times with the motor off
    4) Check the fluid level to ensure it hasn't dropped below the Min.
    5) Lower the vehicle and start the car, should be just fine.
    Now if you are still having problems, I would think it is the pump going bad.
    Darin
    Current:
    Past:
    M-Flight Member
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    Gee, I'd wonder about the motor or transmission mounts?
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Mounts.
  1. Replies: 16
    Last Post: 03-08-2016, 01:07 PM
  2. Replies: 6
    Last Post: 01-23-2015, 03:59 PM
  3. "Whine" when turning steering wheel
    By dudekma in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 03-12-2010, 02:25 AM
  4. revs drop when turning steering wheel
    By mattr328i in forum 1991 - 1999 (E36)
    Last Post: 01-03-2010, 10:02 PM
  5. RPM Drop when turning steering wheel.
    By wolffbimmer in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-12-2009, 02:13 PM
