Originally Posted by
slagdemon
I just had this problem yesterday. First the tire was stuck on the hub so I had to pry it off from between the spokes and then grind all the rust and corrosion off the hub and wheel. Then the axle wouldn't come out of the hub, even when whacking it, so I decided to take the knuckle off the strut tower and the bolt holding the knuckle to the strut tower sheared off. So I ended up taking the entire strut tower and hub assembly off with the driveshaft still in it and pressing it out on my 20 ton press and it took a LOT of pressure to do so. then I drilled the bolt out and replaced it with a nut and bolt combo and finally got it all put back together. Ended up taking 12 hours from start to finish.
