Results 1 to 6 of 6
Thread: cv axles
    colorado springs, co
    2001 3.0 Z3 1996 Lexus
    cv axles
    Just got done replacing the front cv joints on my grandsons 2001 325xi. The drivers side came out of the hub fine, but hit, put a slide hammer on it trying to force it, and lubed the heck out of it. In the end, I cut the axle off and took of the hub where I could get a good swing with a sledge on the end of the axel. It finally came out, but boy was that a lot of work. Was there a smarter way to get rusted axels out of the hub? I also had trouble reinserting the cv joint on the passenger side and ended up pulling the C-clip out of the old joint because the new one was slightly out of round.
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Every XI is this way. So far i haven't found a better way to remove to install them.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The simplest solution is to buy a RWD car.
    Oct 2015
    Lawrence, Kansas, USA
    98 M3(sold), 2002 325XIT
    I just had this problem yesterday. First the tire was stuck on the hub so I had to pry it off from between the spokes and then grind all the rust and corrosion off the hub and wheel. Then the axle wouldn't come out of the hub, even when whacking it, so I decided to take the knuckle off the strut tower and the bolt holding the knuckle to the strut tower sheared off. So I ended up taking the entire strut tower and hub assembly off with the driveshaft still in it and pressing it out on my 20 ton press and it took a LOT of pressure to do so. then I drilled the bolt out and replaced it with a nut and bolt combo and finally got it all put back together. Ended up taking 12 hours from start to finish.
    Aug 2014
    Lawrence Kansas
    Quote Originally Posted by slagdemon View Post
    I see you're from Lawrence. If you ever see a graugrun colored E46 in the Prairie Park area, wave.
    Oct 2015
    Definitely!
  1. Rebuilding CV axles for turbo use
    By Dirtleg in forum Forced Induction
    Last Post: 02-11-2007, 12:21 PM
  2. any suggestions for removing a cv axle?
    By jeffspicoli in forum 1991 - 1999 (E36)
    Last Post: 08-31-2006, 10:17 PM
  3. high hp cv axles
    By beamerboy182 in forum BMW Parts Wanted
    Last Post: 04-23-2006, 07:16 PM
  4. WTB: 325ix Driver's Front CV Axle
    By Sean325i in forum BMW Parts Wanted
    Last Post: 02-15-2006, 11:55 AM
  5. cv axle/halfshaft differences
    By Thin Air in forum 1991 - 1999 (E36)
    Last Post: 12-15-2004, 12:34 PM
