Results 1 to 8 of 8
Thread: E46, trying to find electrical short.
    Feb 2018
    Montreal, Canada
    2000 bmw
    Bought this test light, Innova 3410 but it's not giving much joy.(two stupid lights, why oh why do the have to reinvent the wheel)
    At any rate, light comes on when placed between battery post and connector.
    Remove each fuse, one by one, light never goes off.
    Brand new Kirkland battery.
    At this point, any thoughts or suggestions will be greatly appreciated.
    Thanks.
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    A test light is NOT the tool to use for testing parasitic draw. A long time ago when cars had carburetors and distributors and no computers and modules, that was a valid test. Any car with electronic components will require a multimeter. E46's, like other bmws of the era, requires 16 minutes for the modules/systems to completely shut down or "go to sleep". At this point the parasitic draw on the battery is supposed to be 10-30mA (.01-.03A) depending on the options installed. You will notice the shifter light go off (auto only) when the car goes to sleep. Opening or closing doors, hood or trunk will cause the car to wake up. The vehicle will still go to sleep with doors, hood and trunk open but they must not change. You will want the trunk, hood and lf door open to access the battery, fuses ect. The most common causes of an excessive parasitic draw are the final stage unit and the electric cooling fan. Get yourself a multimeter capable of measuring 10A and good luck.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Feb 2018
    Montreal, Canada
    2000 bmw
    Thanks for the detailed answer, much appreciated. And it looks like I revealed my age here too.
    And I do of course have such a multimeter.
    We'll give this plan a shot...
    Thanks.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    To determine what’s drawing power you need to set up the digital multimeter to read milliamps (ma). Disconnect the negative cable from the battery and connect one meter lead to the cable. Connect the other lead to the battery’s ground post. Allow the car to go to sleep. Check the meter. Anything over 70ma (0.070 amps) is too high. If the draw is too high start removing one fuse at a time. In the E46 the first thing to check is the passenger compartment heating/cooling system. This is controlled by the climate control module in the dash. It’s called “IHKA” in BMWspeak. The IHKA uses a part called the “final stage resistor” to provide a wide variety of blower speeds. The FSR can short out and drain the battery.
    Feb 2018
    Montreal, Canada
    2000 bmw
    Great info, thanks.
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    Kirkland battery?.....I get mine from 'Job Lot' here in New england...labelled China. Snap-On...makes accurate electronic measuring tools.....and with truth to be known.....
    Feb 2018
    Montreal, Canada
    2000 bmw
    Quote Originally Posted by Eaglesail View Post
    Kirkland battery is the house brand from Costco.
    Made by "Interstate Battery" if I'm not mistaken.
    Oct 2020
    Florida Miami
    Florida Miami
    Mate, be careful with that. I had an incident last year, I wanted to change my electric wires in my bedroom, and that guy burns all my electric wire system, and since then I don't trust everyone. I only hire electricians that someone recommends me. Personally, I can recommend you electrician Miami, FL , they are good professionals, they know what to do. I don't want to scare, but to aware, just be careful who you hire. Hope I helped you.
  1. Trying to Find E46 330i ZHP or equivalent price M3
    By DelusionIsGG in forum 1999 - 2006 (E46)
    Last Post: 05-30-2017, 03:35 PM
  2. Replies: 0
    Last Post: 03-21-2011, 11:55 AM
  3. Trying to find Sparco short hub for coupe...
    By creich53 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-26-2010, 04:28 PM
  4. Trying to find a turbo for a 99 328i (E46)
    By rashdavin in forum 1999 - 2006 (E46)
    Last Post: 04-22-2007, 05:01 AM
  5. Trying to find a Walker Dynamax for my race car...
    By Ben 93 325is in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-25-2002, 06:03 PM
