Results 1 to 5 of 5
Thread: SMG Cog light isn't on but scanner picked up a bunch
    May 2014
    Vancouver,WA
    00 Maxima SE
    I was looking at 02 SMG E46 M3 (118K Miles) yesterday and I was using Schwaben/Foxwell Scanner.The cog wheel light wasn't on nor blinking (no CEL either) during my 15-20 minutes drive and about 20 minutes sitting idles. Test drove was fine, SMG was fully functioning. I did, however, picked up a bunch of SMG codes from the scanner.
    Code 17: Activation, solenoid valve, clutch (OBDII P1740)
    Code 3B: Acuation, Cluch, Dynamic.
    Code 61: Voltage Supply.
    Code 32: Selection Angle Can't engage (OBDII P1758)
    Code 38: ON period, hydraulic unit (OBDII P1717)
    What's you guys thought on these?
    Walk away?
    FEEDBACK THREAD
    00-03 Nissan Maxima HID Retrofit
    6th gen AV6 FX35 Retrofit
    Chassis and Suspension
    2011 Space Grey E82 N55 DCT
    2000 Sunlit Sand Maxima SE 5Spd.
    1997 Arctic Silver E36 M3/4/5.
    1997 Techno Violet E36 M3 Coupe 5Spd (SOLD).
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    If you don't know when or how old those codes are, just take note, clear and go for a drive. If anyone of them come back I would worry.
    While I like the Foxwell scanner, I don't know a lot about them. Do you get more info on the codes like milage when populated? Or maybe frequency or code counts if it had happened more than once?
    A couple of those codes can be caused by a new battery.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    May 2014
    Vancouver,WA
    00 Maxima SE
    To be honest, I just got the Scanner and been using it for 6-8 times looking at E36/E46 M3. It does more than my Peake does for sure. Slowly, I'm learning the capability of the scanner. So far this is an awesome scanner. This along with Quick Jack, I can be more efficient of selecting which car should I do PPI.
    FEEDBACK THREAD
    dworthy's Avatar
    Nov 2010
    If you are serious on getting the car, than a PPI is a must. Anytime you are going to pay over 10k for a car, a 120-140 dollar PPI is a bargaining chip.
    The scanner helps in a way for you to see what is going on, and perhaps an idea if you really want to by the car.
    Oh and swing by the recall site to ensure it is upto date: https://www.bmwusa.com/safety-recalls.html
    Darin
    Current:
    Past:
    M-Flight Member
    May 2014
    Vancouver,WA
    00 Maxima SE
    I decided to get an 01 manual 6 speed for $1000 more with less miles with sub frames reinforcement and rod bearing recalled already. Will need Vanos lock down eventually but they all do eventually.
    FEEDBACK THREAD
  1. Air bag light on but scanner says no codes
    By VitaminZ in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-04-2016, 02:45 PM
  2. Replies: 2
    Last Post: 06-07-2014, 08:27 AM
  3. ASC Light on; ABS light isn't on..
    By shadow25 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-31-2011, 12:17 AM
  4. running lights/corners are on..but no blinker?
    By nike001 in forum 1996 - 2003 (E39)
    Last Post: 12-29-2009, 12:58 PM
  5. Tire Warning light keeps coming on but Tires are fine?
    By Ali in forum 2001 - 2006 M3 (E46)
    Last Post: 04-30-2005, 03:25 PM
