BMW of Bloomfield
Results 1 to 25 of 31
Thread: Twin Screw 1998 M3 Estoril Blue Coupe
    Kansas City, MO
    Lots
    SOLD
    Knowing that I will probably always regret it, the time has come to sell my Eurosport Twin Screw
    1998 Estoril Blue E36 M3 6-Speed non-sunroof coupe with 103K miles (if I recall correctly). There are 20K less miles on the motor. This car was my introduction to BMW’s and the beginning of a lifelong fandom. I have put a LOT of blood, sweat, and money into this car but I have to face the facts, I just dont drive this car enough to justify keeping it (I have 7 cars) and I can't bear to watch her sit and waste away.
    So, it’s time I let someone else enjoy this amazing vehicle. I believe in being straightforward and honest. I’ll tell you all that I know (good and bad) about the car because I want you to be happy with your purchase, and I don't want to hear complaints from you later. I just want a nice clean transaction. Please understand, I do not need to sell this car. I'm listing it for what I believe is currently a fair price (and way less than what it would cost you to replicate), and will not entertain low ball offers, especially those trying to leverage my honestly identified “bad” details to justify a lower price.
    I believe that I am the second owner of this car and I purchased it on August 1st 2007. When I purchased this car it had approximately 70k miles, it was Vortech supercharged, had Ground Control coilovers, and a Dove gray interior. All other modifications have been done during my ownership.
    This is a low options car, which makes the body somewhat rare. No sunroof, no cruise control, no tilt wheel. It’s a bare bones, get in, hold on, and drive car.
    Modification/Parts List:
    ENGINE
    • S52/ZF trans (70K miles) - Original motor pulled @ 99311 miles
      • The ONLY reason the original motor was pulled was because the Twin Screw came as a package with a motor that had 20k less miles and a built head. NOTHING was wrong with the original motor.
      • ACS/DSC Delete
      • All new belts and coolant hoses
      • VAC SuperCharger Cams
      • VAC Valve Spring and Retainer Kit
      • ARP 2000 Head studs
      • Cometic .120 MLS Head Gasket
      • VAC Underdrive Pulleys
      • S54 Oil Cooler with high flow Bimmerworld diverter valve
        • Oil thermostat delete
      • Custom baffled oil pan and spot welded oil pump gear nut
      • Custom stainless dual pipe exhaust
        • Ebay stainless headers
        • Magnaflow mufflers
      • Dinan Big Bore Throttle Body
      • Hi Flow Porsche 803 MAF
      • Stewart Hi Flow Water pump
      • Low temp thermostat
      • Aluminum thermostat housing
      • Zionsville Racing Radiator and Electric Puller Fan
      • Zionsville Radiator Drain Plug
      • Walbro 255LPH Fuel Pump
      • Stainless Slave Cylinder lines with restrictor valve delete
        • Makes for smooth clutch engagement
      • Motion motorsports underpanel
    SUPERCHARGER
    • Eurosport Twinscrew Super Charger with Air/Water Intercooler Core upgrade
      • Dyno supported 395rwhp/327TQ corrected to SAE
        • Should be making over 400whp since header/exhaust install but never dyno’d
      • Serviced @ MaximumPSI. (25K on ESTS)
      • Separate Coolant reservoir for intercooler ( came with TS)
      • Machined down 6mm hex for removal of SC drain plug
      • OBD II tune from Conforti (good AFR's)
      • Cobra Double Core Heat Exchanger
        • Custom machined aluminum brackets to hang off of shock posts
      • 76mm SuperCharger Pulley
    DRIVETRAIN
    • Euro E36 M3 6 speed transmission w/ Shaft and trans mount
    • Gripforce FX Stage 3 clutch with Chromoly Flywheel
      • I’m a big fan of these flywheels and clutches and use them on my track car as well
    • UUC DSSR E36 M3 6 Speed - 109mm
    • UUC EVO3 Short Shift Kit E36 M3 6 speed
    • UUC Trans Mount Bushings Red
    • UUC Trans Mount Enforcers
    • ZHP Weighted 6 Speed Shift Knob
    BRAKES/WHEEL/HUB
    • Wilwood Superlite4 Front brake Calipers
      • Custom front Caliper Brackets
    • E46 M3 Front rotors
    • Turner Motorsport Hub Extender kit
    • Turner 10mm Hubcentric wheel spacers
    • Turner 78mm wheel studs
      • 17mm 12x1.5 wheel lugs
    SUSPENSION/BUSHINGS
    • Rouge Strut bar
    • Ground Control SA coilovers 525F/600R
    • Vorschlag Poly Motor mounts
    • Turner rear trailing arm bushings w limiters
    • Turner Rear Trailing arm pocket reinforcements
    • Bimmerworld solid offset front control arm bushings
    • Turner Motorsports Solid Poly Rear Diff Bushings
    • UUC Swaybarbarian Sway Bar Set (25.4mmF/23.8mmR)
    • Treehouse racing rear camber arms
    INTERIOR
    • Leatherz E36 Gauge Panel
    • Innovate AFR Gauge/Kit
    • Autometer Oil Temp gauge
    • Autometer Boost Gauge
    • UUC Aluminum Pedal Set
    • New Headliner
    • Full black interior swap including heated, non-power Vader seats (no rips or tears but could use a dye job on bolsters)
    • Audio (Did this a long time ago, no idea why. I don't ever listen to it and the car is loud)
      • Alpine Receiver
      • Soundstream Amp
      • Infinity Speakers
        • 6x9’s adapted to rear deck
    WHEELS/TIRES
    • OZ Mito II Wheels
      • Front 18x8 et (I'll have to check)
      • Rear 18x9 et (I'll have to check)
    • Tires
      • FRONT - Sumitomo HTRZIII - 235/40/18
      • REAR - Sumitomo HTRZIII - 255/35/18
    EXTERIOR
    • E36 Depo Ellipsoid Headlights (DDE Raptor 6500K) + Lamin-X protection film
    • AC Schnitzer 3 piece rear wing
    • Clear Corner Lights
    • Clear Side Marker Lights
    This car is not for the faint of heart, the beginner, or the guy that wants something carefree and comfortable. If you’ve never driven or ridden in a twin screw powered car you need to understand that this car is brutally fast with instant and punishing power delivery. The twin screw enables nearly total torque delivery the moment you push the throttle. As such, this car is easily capable of breaking the rear wheels loose in 2nd and 3rd gear at a 30mph roll. Couple all of this with the fact that there is no traction control and a stiff suspension and chassis and you’re in for a wild ride if you don't know what you’re doing. I'm lucky enough to also have a V10 R8 and this M3 feels just as punchy when you push the throttle, no joke. Don't buy this car if you’re looking for something to drive on the weekend and take your kids to school during the week - they will die. Don't buy this car if you just want something to tinker with and don't really like to drive. This car should be driven. Obviously a car with this level of modification takes maintenance and care, things I just don't have time for anymore. This car is for someone that is comfortable working on cars if they need it, loves to build and modify, loves to drive and go fast all alone in the car because a passenger just adds extra weight, and someone that wants to do more of all of the above.
    The bad:
    I imported the transmission from the UK and installed it myself. There is a noticeable catch/grind shifting into 3rd. It’s always been there and I really can't determine if its a result of the UUC 6 speed shifter (which I’ve read a lot of complaints about) or if its a synchro issue. Either way, it's never prevented me from shifting into gear or popped out of gear. It’s just not a smooth shift and is very annoying (to me at least). I tried both redline gear oil as well as Amsoil ATF in the hopes it was a synchro lubrication issue and the issue persists. I'm happy to include a 5 speed transmission, driveshaft, and 4 bolt diff flange with the car if you’d like to switch back.
    I’ve recently noticed that the front shocks are compressing too quickly over road bumps which leads me to believe that they may need to be rebuilt. These can simply be mailed to Ground Control and I believe rebuilds are about $150 per corner.
    This is a 20 year old car and while its been well taken care of, it's been driven and isn’t perfect. There are a few rock chips, and imperfections here and there. There appears to be some slight paint fading on the top of one of the fenders (you probably wouldn’t notice if I didn’t say anything). The vaders have typical bolster wear and could use a dye job. Also, the forward tilt latch cable on the driver's seat has broken preventing the seat from leaning forward. The wheel lips could use a polish, there are some chips in the powder coat of the wheel faces, and the wheel bolts need a rechrome (if you’re a wheel guy).
    That’s about it. I wouldn’t hesitate to drive this car anywhere (that doesn’t have snow). I still think she’s a beautiful car and the performance is simply astounding.
    Please free to ask any questions at all and I’d be happy to send additional pictures upon request. Asking $18,000 (pretty firm)
    Some pictures (please let me know if you want specific/detailed pictures of anything):
    https://www.dropbox.com/sh/wjcpf7bkrki5c9y/AAAsRqfHLNyzgyR9DpVaFYFIa?dl=0
    Anyone can buy it, its those that can build it that are a cut above the rest.
    1998 M3 - Estoril/Black, Eurosport Twinscrew, 6 speed, nothing stock
    1995 318ti - S52 swap, T-trim supercharged, intercooled, track car, nothing stock
    2002 M3 - Suspension, exhaust
    2014 - X5
    Sep 2003
    whippany NJ
    1990 325is, 1990 325i
    Damn fine car. I've always been amazed by the torque curve of the twin screw s/c. Good luck with your sale.
    Kansas City, MO
    Lots
    Hey thanks for the compliments. These really are incredible with a twin screw. Just monstrous and immediate acceleration.
    2014 - X5
    Feb 2016
    Rogers AR
    1995 BMW M3
    where is the car located?
    Jul 2004
    TC
    '98 M3
    PM sent
    Kansas City, MO
    Lots
    Car is located in Kansas City, MO
    PM Sent
    2014 - X5
    Apr 2013
    Alabama
    1995 M3 Coupe
    Priced too low, needs to be about 20k if not more!!
    1995 M3...Screwed
    Kansas City, MO
    Lots
    Hey Jab31169, thanks for the comment. I agree, the price is lower than I would like, and nothing compared to what is in it. I'm trying very hard to be "fair" given that the front shocks likely need a rebuild, there is a catch shifting into 3rd, and there is very slight paint fade on the fender. In the end, I realize that I've offered it at a very reasonable price and will be pretty damn firm with the sale. Take care.
    2014 - X5
    AL
    99' M3, 98' M3, 13' X5
    Free bump from a fellow ESTS owner! After almost 8yrs of ownership, still in love with mine!
    May 2003
    Tampa, FL
    E92 M3, 970TT
    This car's incredible... subscribed.
    991 | 964 | G55 | D90 | LX570 |
    Past: SC'd e34 540/6, CSL'd E46 M3, E36 M3/4/5, E36 M3 turbo, E36 M3, 335D, Porsche 951, 80 Series LC, Kleeman E55 Wagon, LX470, 970 Panamera TT, E92 M3
    Kansas City, MO
    Lots
    Thanks for the compliment. Will be updating the Dropbox tonight with interior pics
    2014 - X5
    Kansas City, MO
    Lots
    Dropbox has been updated.
    There is also a small video in there of the boost gauge showing how ridiculous and instantaneous full boost and resulting torque is applied. Just amazing acceleration.
    2014 - X5
    Kansas City, MO
    Lots
    Bump to the top
    2014 - X5
    Mar 2011
    bethlehem pa
    1999 Estoril blue M3
    WOW that hood looks good! good luck with the sale jordan.
    Kansas City, MO
    Lots
    Ha! Thanks again. Take care
    2014 - X5
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    I'd recommend highlighting your price and put it at the top and bottom....took me a minute to find it without reading the ad in depth. Point is, if I'm interested, the price is what will get me to read the print....also, your print is kind of small, making hunting for the price a little difficult!
    This is a special car for a special buyer, good luck with your sale!
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    Feb 2016
    Rogers AR
    1995 BMW M3
    looks like he lowered the price too
    Kirkland, WA
    2006 Toyota Tundra
    Quote Originally Posted by lbennyboobool View Post
    Don't think so. It was always 18k
    Feb 2016
    Rogers AR
    1995 BMW M3
    Quote Originally Posted by Alpine 318is View Post
    I thought he started at $19k?
    Sent from my 2PYB2 using Tapatalk
    Kansas City, MO
    Lots
    Hey BMWManiac, thanks for the suggestion. Will do
    2014 - X5
    Kansas City, MO
    Lots
    Pending sale
    2014 - X5
    Oct 2017
    VA
    1998 328i, 1990 Spec E30
    Good luck. Its the perfect build.
    Mar 2008
    El Paso, TX
    1995 bmw m3
    Have you considered posting in bringatrailer.com. Those guys go crazy with bids on any e36. This afternoon a '95 techno-violet M3 w/VF supercharger just sold for 23k.
    Kirkland, WA
    2006 Toyota Tundra
    Quote Originally Posted by WATTSBMW3 View Post
    Myself and the Seller currently have a deal in place. Just waiting till next weekend to fly out there to pick it up.
    Feb 2016
    Rogers AR
    1995 BMW M3
    are you collecting all the twin screw supercharged M3s that come on the market?
  1. 1998 M3 Estoril Blue/ Black Interior
    By SDKCM3 in forum 3 series & Z Series
    Last Post: 03-06-2008, 02:57 AM
  2. WTB: M3 Estoril Blue Coupe-Any Year
    By dphamtx in forum 3 series & Z Series
    Last Post: 08-16-2007, 06:45 PM
  3. FS - 1998 M3 Estoril Blue/Dove Grey
    By bimmersinner in forum Canada
    Last Post: 03-11-2007, 04:15 PM
  4. Feeler: 1998 M3 Estoril Blue/Dove Grey
    By ftc3 in forum BMW Cars For Sale / Wanted
    Last Post: 09-21-2004, 01:06 PM
  5. FS. 1998 M3 Estoril Blue LOW MILEAGE
    By EUROMPOWEREDM3 in forum BMW Parts For Sale
    Last Post: 05-16-2002, 06:46 PM
