Results 1 to 4 of 4
Thread: What fluid to use in getrag 260/6?
    Richmond, Virginia
    '88 735i, '06 RSX
    I think the fluid in my trans is original, I will have a buddy of mine drain and refill with clean fluid. Can I use Maxlife ATF or do I need something more specific to the G260? I'm not looking to use super high end oils.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    https://www.bimmerforums.com/forum/s...a-Getrag-260-6
    quote:
    Lubrication
    Lubricant 85W Gear Oil
    single grade HD motor oil SAE 20/30/40 (owner's manual 01 47 9 780 737)
    The Bentley BMW 5-series E34 Service manual declares the oil capacity of the 260/5 and 260/6 transmissions to be 1.25 litres. Manual transmissions installed on the E34 are normally filled with Dexron III Automatic Transmission Fluid (DX3 ATF), though alternative fluids may be used depending on shifting effort and gear noise.
    Some 80W-140 oils promote themselves as a suitable alternative where DX3 ATF is specified by the manufacturer.
    https://en.wikipedia.org/wiki/Getrag_260_transmission
    http://www.exx.se/maintenance/gearbo...ge/index.shtml
    Richmond, Virginia
    '88 735i, '06 RSX
    So it is safe to use Valvoline full synthetic ATF since it meets dex3 yes? Also 75w140 full synthetic gear oil for the LSD as well? Fluids are probably original...long past being needing to be changed. Is it safe to do so at 200K miles?
    Oct 2008
    Romania
    1994 BMW E32 730i M30
    For 3 years I own a 1994 E32 730i w/ M30 engine and Getrag 260/6 manual gearbox. In the past, I had for 10 years a 1986 E28 535i which also had the manual Getrag 260/6 gearbox.
    Bottom line, I have 13 years of Getrag 260/6 experience.
    When the weather is rather cold (e.g. below 18 deg. C / 65 deg. F), shifting becomes difficult on Getrag 260/6, particularly 1st to 2nd gear shifts. If you put ATF oil in the gearbox, shifting effort at cold improves a lot
    However, when outdoor temperatures jump over 32 deg. C / 90 deg. F and the gearbox gets hot, the ATF oil will make shifting hard (particularly shifting into 1st gear from a stand still), and the gearbox may sound harsher.
    Therefore I recommend gearbox mineral oil (85W, or 80W90, or 80W) at all times, except maybe in the winter. Although, even in winter time, if you are gentle with your shifts until the gearbox heats up, the mineral oil would be just fine.
    Since I doubt very much that Getrag redesigned gears and/or materials inside the 260/6 in order to cope with the specs of ATF, I strongly believe that ATF oil was specified instead of normal manual gearbox oil just depending on the climate of country of destination. Therefore, you may want to play a bit with gearbox oils until shifting matches your taste.
    Just make sure that you don't put API GL5 oil inside, because it contains sulfur and will damage the synchros. Also, stay away from synthetic oils, or you may enjoy oil leaking, particularly from rear seal (ask me how I know).
    1994 E32 730i M30 manual
    ex- 2006 E86 Z4M Coupe
    ex- 1986 E28 535i
  1. WhatS a good tranny fluid to use in Zf 5 speed
    By 89325iturbo in forum 1991 - 1999 (E36)
    Last Post: 07-12-2010, 03:49 PM
  2. What type of power steering fluid to use in an E30?
    By bmwcajun in forum 1983 - 1991 (E30)
    Last Post: 07-21-2009, 01:36 PM
  3. What Fluid To Use In Power Steering?
    By Ghery in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-10-2007, 11:48 PM
  4. What transmission fluid to use in E34 525i?
    By Andryuha in forum 1988 - 1996 (E34)
    Last Post: 06-18-2006, 03:07 AM
  5. What tranny fluid to use in E39 540ia
    By cleoent in forum 1988 - 1996 (E34)
    Last Post: 02-18-2005, 04:19 PM
