Results 1 to 8 of 8
Thread: e36 m3 __SLOTTING strut-tower for camber?
    Oct 2005
    Nördlich des Äquators
    M3TTst2Meth-K1300S-1100G
    I have a e36m3 with Eibach Bilstein suspension (no coil-overs)
    maxed out at ~ -1 deg front camber
    planing on slotting holes in strut-tower and add backing plate under it to get me to -2.5 deg
    I run Ventus 214s, 245-40 on trm 17 x9 , square setup
    would you?
    are there any other cheap solutions ? (not interested in 300-$400 camberplates which are usually made for coil-overs)
    My car is both street & track
    thanks for the feedback
    Apr 2016
    Irvine, CA
    99 328is, 03 X5
    Why not use the OEM 96+ M3 top mounts, flipped them (L2R, R2L), and shim the strut for additional camber? I was able to achieve -2.5 by flipping the M3 top mounts, and -3.5 with the shims. This was just with Bilsteins and lowering springs....
    I run z214 on track and find I need nearly -4 up front (-3.6 currently), and -3 (-2.7 currently) in the rear at most tracks, just as an FYI.
    Apr 2002
    Broomfield, Colorado
    What TeamNeverlift said. Move the stock plates to the opposite side.
    Free. You will still be able to sell your car in the future.
    Also look at the turner camber shims. $50 and you get a degree out of them.
    2002 BMW M Roaster.
    1998 BMW 328is SCCA E Production road racer.
    Oct 2005
    Quote Originally Posted by Team Neverlift View Post
    Great info
    what toe do you run?
    is your car track and dd?
    Oct 2005
    Quote Originally Posted by CoMZ302 View Post
    OK thanks, will look them up
    Apr 2016
    Irvine, CA
    99 328is, 03 X5
    Quote Originally Posted by Haifisch M3 View Post
    Great info
    I run 0 toe all around. Always have, that's just what I prefer.
    Yes, track (time attack) & DD.
    I provided hidden link in my original post to Bimmerworld shims btw
    Vancouver, BC Ca
    1993 325is
    And I run 4 degrees negative camber in the front on my daily driver/autocross car. Toe at between zero and 1/8" toe in. No big issues with extreme premature tire wear. Sure, the inner shoulder wears faster than the outer, BUT I can still get 35-40,000 kms out of a set of soft street tires without having the inner shoulder worn to the steel belts.
    Oct 2003
    Seattle
    99 M3
    Due to shape of strut Tower, simple slotting of the attach holes most likely will not work as the shape of the stock Guide Supports/strut mounts will ride on the radius of the tower.
    Dinan and Turner offer an inexpensive “fixed” camber plate.
  1. E36 1995 E36 M3 front struts prepped for inserts
    By dano670 in forum Suspensions, Springs & Shocks
    Last Post: 03-02-2012, 07:28 PM
  2. E36 FS: E36 M3 Dinan Strut Tower Brace $240
    By E36Shikara in forum Suspensions, Springs & Shocks
    Last Post: 02-07-2012, 07:15 PM
  3. E36 WTB: E36 M3 Front Struts (Using for Konis)
    By Mistamike17 in forum BMW Parts Wanted
    Last Post: 04-06-2011, 10:36 PM
  4. E36 OEM E36 M3 front strut housings (for koni inserts)
    By lsbm3nm in forum Suspensions, Springs & Shocks
    Last Post: 07-29-2010, 03:13 AM
  5. E36 WTB e36 m3 rear strut bar for sedan
    By KGB M3 in forum BMW Parts Wanted
    Last Post: 03-29-2010, 04:25 PM
