Results 1 to 7 of 7
Thread: reinzosil Vs hylomar
    Feb 2012
    Southern Ontario
    93 850Ci, 2012 X5 35d
    I will soon be replacing my leaky valve cover gaskets, and am assembling parts and tools...
    I realize reinzosil hardens, and hylomar doesn't, should I be using one over the other? Are there places i.e. valve cover gasket or intake gaskets that I should specifically use one or the other?
    Any help would be appreciated....
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Regular black RTV is fine. Put some on the gasket itself on the half moons. Then on the engine, a dime sized dab at the creases where the timing covers meet the heads. That’s it.
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    I followed several members suggestions when I resealed the rubber intake manifold gaskets on my car recently. I used the Reinzosil. I only use the Hylomar on the gear covers of my formula car transaxle because it does not stick to metal like rv sealant so its very easy to clean off. And, Hylomar does not last from my experience. Seems like it breaks down from oil after several months. I think its really only popular for those assemblies that will be resealed occasionally because its so easy to clean off, it just wipes off surfaces.
    So I cleaned rubber gaskets well and soaked them with silicone spray and then put them in ziplock bags and left them for some weeks until I was ready for reassembly. Supposedly the silicone will help revitalize the rubber. Then I cleaned the contact surfaces and applied Reinzosil on surface facing heads, waited several minutes, and then bolted them down. Did the same on intake manifolds and then stuck them onto gaskets/studs. You only need about 1mm of sealant. I believe the torque for nuts on head studs is around 17lbs and only 7lbs on manifold nuts.
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    That’s totally unnecessary
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Reinzosil all the way.
    Jul 2016
    Chicago, Illinois
    are slow
    Reinzosil
    Sunny Cali,
    6.5 second 69 Camaro
    ...agreed,
  1. cometic mls hg. hylomar vs. copper spray
    By five&dime in forum Forced Induction
    Last Post: 08-07-2011, 02:04 PM
  2. M3 vs Camaros
    By PM3 in forum Kill Stories
    Last Post: 06-13-2006, 01:12 PM
  3. Supercharged M3 vs. BPU Supra
    By V Shah in forum Kill Stories
    Last Post: 06-23-2001, 07:38 PM
  4. M5 vs Ford Contour SVT
    By MarkM5 in forum Kill Stories
    Last Post: 04-01-2001, 06:30 PM
  5. 97 M3 vs Lexus GS400
    Last Post: 03-07-2001, 12:05 PM
