Results 1 to 4 of 4
Thread: Motor Seized??? After Oil Pan Gasket Replaced
    Mar 2018
    Saint Louis
    BMW 128i
    Hello - replaced oil pan gasket, everything back together car fired up, let run for about 10 minutes, took for test drive Drove for about 5 minutes, heard something, got out, popped hood, all looked ok, got back in car, (still running) started driving car died and will not fire. No engine lights came on. Oil level checked fine. Had battery replaced 3 months ago. Motor will not spin even with plugs out. Tried replacing starter. Do have power from battery to the starter. Any ideas??? Is the motor seized?
    NW suburban Chicago
    hiss by my window
    Put a wrench on the crank and try it by hand. If it turns, no, if not, yes. If you can change an oil pan gasket and starter I'm surprised you haven't tried this.
    A failure catastrophic enough to seize the engine would give warning, over heating, low oil pressure eventually accompanied by the inevitable awful noises an engine makes when the bearings fail. Your scenario is a bit implausible.
    Mar 2018
    Saint Louis
    BMW 128i
    As i stated , motor will not spin, even with plugs out, guess I should have been more specific, by using a wrench, I tried to turn the motor. It turns a few inches, that is it. Was not sure if BMW had something else weird (being BMW) that maybe I needed to know about that might have been stopping it. I just find it odd that a motor just seized out of no where. No metal in oil, no warning, no lights, no nothing.
    Quote Originally Posted by mbass3598 View Post
    NW suburban Chicago
    hiss by my window
    If it turns at all it's not "seized" perse. What you describe sounds to me like perhaps a main bearing failure. When they go they don't protest as loudly as a bearing in a rod end which is constantly changing direction. I've seen a wiped out main that actually turned enough within the saddle to overlap the other bearing shell, effectively wedging the crank in place. It would turn a few degrees and stop, turning it backwards* would "free" it but would lock up again if turned again in the proper rotation direction. What you describe reminds me of that scenario, which, by the way, died from oil starvation. Motor was junk, crank wiped out and overheated as were two main bearing saddles, didn't bother to examine much else closely but I don't remember any spun rod bearings which I thought a bit remarkable.
    What happens when you turn the engine the other direction?
    Regardless of what the failure if it won't turn it'll need to come apart. I wonder if a piece of debris from the gasket job could have somehow gotten into an oil passage. Was the pump off?
    * this was only possible using a LOT of leverage, as in hanging on a six foot pipe.
  1. Oil pan gasket replacement. What's needed?
    By oups59 in forum 1988 - 1996 (E34)
    Last Post: 10-25-2007, 04:24 PM
  2. M70 upper oil pan gasket replacement DIY
    By shogun in forum 1988 - 1994 (E32)
    Last Post: 04-18-2007, 09:51 PM
  3. Replies: 0
    Last Post: 01-08-2007, 10:52 AM
  4. E30 M20 Oil Pan Gasket Replacement
    By SammyBoyOfJoy in forum 1983 - 1991 (E30)
    Last Post: 04-28-2006, 05:21 PM
  5. oil pan gasket replacement - how much?
    By virtualj in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-08-2002, 10:45 AM
