Results 1 to 8 of 8
Thread: N54 Mystery Issue HELP !!!
    Dec 2011
    Worcester, MA
    1997 BMW M3 sedan
    I was driving along and the engine randomly shutoff while taking off from a stop sign(clutch engaged maybe 10mph) and would not start back up. When it finally started back up, it surges from 1000-1200rpm and only revs (WOT) to a little above 2k. So I pulled the codes and am getting both camshaft position sensor A & B intermittent circuit codes P0344 & P0369 along with some other "Powertrain" codes.
    I already checked, cleaned, and reinstalled both Vanos solenoids and nothing changed.
    Two days before. . . I hit a severe pothole bending two rims. There is a strange tapping noise coming from under the dash after the pothole incident.
    Car is not driveable, no torque and usually won't start.
    What could be the issue? I am mechanically inclined and planning to do everything I can before taking to a mechanic.
    My plan for next step in the diagnostic procedure is to check the camshaft position sensors themselves.
    Any help appreciated! Thank you!
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    Buddy, Save yourself the trouble of attempting to diagnose this yourself via the internet. I understand you are trying to save money... But if you are going off of advice of people that have never touched your particular vehicle all bets are off. You will end up spending MORE money on parts thrown at it then a proper diagnosis and repair in one shot! If you have a scope, multimeter and a proper scan tool then it may be possible to get to the root of this issue. If you keep listening to adivce of strangers you will spend money on fuel filters batteries sensors for what may be a simple cabling issue or worse yet an engine out of time that needs to be rebuilt. I am not a weekend mechanic I work on these cars exclusively I recommend you take my advice.
    Buy my native installed ISIS ISTA-D/ISTA-P bmw diagnostic laptop. More Info Here!
    Dec 2011
    Worcester, MA
    1997 BMW M3 sedan
    Quote Originally Posted by Driiven View Post
    Aright. . . then maybe you are someone who can help. Have you ever exhibited symptoms like this before?
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    I agree with Driiven. Without some real bmw fault codes and details we are just shooting in the dark. So many things can cause these engines not to run. Chasing every single option would cost a fortune and a ton of time.
    Find an indy in your area with a proper scanner for bmw, if for nothing else then to read out all the codes and send you in a general direction. Shouldnt cost more then $100 for a full diagnostic scan of the entire car.
    If your determined to do it yourself then head over to the diagnostic software section of the this forum and get yourself set up with scanning software. That will be the best use of your time at this point.
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    Dec 2011
    Worcester, MA
    1997 BMW M3 sedan
    Legoman67. I used an obd2 mini scanner and Torque Pro to pull 8 different fault codes listed below.
    P0344 - Powertrain
    Camshaft Position Sensor "A" Circuit Intermittent (Bank 1 or Single Sensor)
    P1636 - Powertrain
    Throttle Valve Control Circuit
    P0340 - Powertrain
    Camshaft Position Sensor "A" Circuit (Bank 1 or Single Sensor)
    P0341 - Powertrain
    Camshaft Position Sensor "A" Circuit Range/Performance (Bank 1 or Single Sensor)
    P0365 - Powertrain
    Camshaft Position Sensor "B" Circuit (Bank 1)
    P0369 - Powertrain
    Camshaft Position Sensor "B" Circuit Intermittent (Bank 1)
    P1417 - Powertrain
    P1638 - Powertrain
    I have ordered a crank shaft position sensor off partsgeek and plan to replace it this week.
    Jun 2017
    Denver, CO
    '08 E90 335xi manual
    Those generic codes are worthless for a BMW. You need a scanner that reads BMW codes.
    Curious - why the crankshaft position sensor?
    Are you gonna eat that?
    Dec 2011
    Worcester, MA
    1997 BMW M3 sedan
    Quote Originally Posted by relative4 View Post
    Thanks for your reply. I have decided to give in and take it to a local indy w/ a bmw scanner.
    My buddies and I were thinking it could be the crank pos sensor b/c we are reading both camshaft position sensors. . . highly unlikely they both went out at the same time.
    Update - I replaced the crank pos sensor and it obviously did nothing. Luckily I found one cheap.
    I'll give an update after the Mechanic looks at it.
    Calgary, Alberta Canada
    318I,CTSV,328IS,M3,135i
    It would be very unlikely that something could cause all those codes at once. It is almost certainly an electric issue. The severe hit probably damaged a main electric connection somewhere. Being you say there is a strange noise under the dash, I would look for that and find what it is first. Electrical issues especially grounds can cause all sorts of bizarre issues. Good luck.
  1. Mysterious issue of why no or low oil? Please help
    By duck2011 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-12-2018, 08:10 AM
  2. Major engine issues!!! help!! n54... faulty vanos????
    By BoostedE60 in forum 2004-2010 (E60,E61)
    Last Post: 09-13-2014, 10:29 PM
  3. Word processing issues...HELP!
    By fable in forum Off-Topic
    Last Post: 08-28-2002, 03:43 PM
  4. Girl Issues help guys!
    By Nillaice in forum Off-Topic
    Last Post: 08-06-2002, 10:24 PM
  5. 95 325is WINDOWS ISSUES HELP!
    By cleoent in forum 1991 - 1999 (E36)
    Last Post: 10-11-2001, 06:46 PM
