Results 1 to 7 of 7
Thread: 1989 325i Sedan
    Feb 2018
    Compton
    1989 325i Sedan
    1989 325i Sedan
    Hello fellow E30 enthusiest,
    Id like to introduce myself. Im Erek and i own a 1989 325i Sedan. Its been sitting at my dads house for the past 4 years and i am now getting ready to get it back on the road. A couple years back i was using it as a DD and i did alot of maintenece on it.
    Timing belt
    Timing belt tensioner
    New fan
    New fan clutch
    Radiator and hoses
    Alternator
    Fuel pump
    Brakes and rotors
    Thermostat
    Water pump
    O2 sensor
    CPS sensor
    Plugs and wires
    Cap and rotor
    Drive shaft was rebuilt
    Center support bearing and guibo replaced
    Transmission was replaced
    Clutch
    Rebuilt shifter
    Catalytic Converter
    Magnaflow muffler
    Flushed the fuel injectors
    16" Konig Remembers wheels
    I then purchased a new car and lost interest. Gave the car back to my dad and he was using it as his DD comuting from Tracy to Oakland everyday. About 100 miles round trip.
    The car eventualy snapped a rocker arm and was parked for the next 4/5 years. well fast forward to today and ive had the car in my posetion for about 2/3 months now.
    I have started to break it down to find what broke my motor. I have another thread on R3V https://www.r3vlimited.com/board/sho...d.php?t=419391 but havent had much interaction with alot of users as in tips, advice, criticizm lol its all accepted.
    Heres some Pics from when i got the car and to where i stand today.
    *Warning Iphone Photo dump*
    When I first got the car
    Now with the car back in my possesion i have been working on it slowly. Its not my DD so im not in a rush to get it back on the road.
    I pulled the valve cover off only to find that not 1 rocker but all my rocker arms had snapped.
    A couple weekends ago i started to tear down my motor and i found what broke my rocker arms. My Timing belt tensioner had snapped causing slack on the timing belt.
    The visible wear on the inside of the timing belt cover.
    Broken timing belt tensioner
    The following weekend i got the head and intake manifold removed. Found minor damage on the heads of the pistons but i dont feel any carnage when i cycle the motor.
    Broken Exhaust down pipe.
    Not much progress this weekend but I did clean up the pistons a little bit. This is about 2/3 hours of scrubbing. Not the best pics sorry.
    Before:
    After:
    I’ll be dropping the head off to get rebuilt in the next couple weeks as well as hitting the purchase button on a top end gasket kit. I was looking at the package that bimmerheads offers. Has anyone picked up their “M20 ultimate head gasket set”?
    https://bimmerheads.com/products/m20...ead-gasket-set
    I see CATuned has a similar set up for about the same price.
    https://catuned.com/ajusa-m20-head-gasket-set
    Any suggestions before I purchase anything?
    I also see a price difference in the Gates timing belt but they seem to have the same part number T131RB. Does anyone have any idea if there is any difference in the two besides the vendor?
    Bimmerheads:
    https://bimmerheads.com/products/gat...=8345201672234
    Catuned:
    https://catuned.com/gates-timing-belt-m20-t131rb-bmw
    Thanks again always looking forward to anyone’s advice.
    Nov 2016
    San Jose
    E30 1992 325ic
    Hey! Im in the bay area! I got a block you can have for like 50 bucks - good condition!
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    dang man, that sucks. that's a very good looking car. I would smooth out those marks where the piston hit the valve, to remove any possible hotspots, and than just throw another head on it and put everything back together.
    beauty of a car though.
    the same thing happened to my wife's 325is back in the day. after I put it back together, it was the first m20 that I had never heard the valve noise on. it was quiet like a sewing machine
    No e30s again.
    Regina, Sask, Canada
    82 320i 89 325i
    welcome. nice looking car. left a msg in the alternate thread the other day.
    best pricing i ever found on a gates blue belt and tensioner was rockauto. just make sure the parts numbers / brands match up both when ordering and on arrival. otherwise stick to the better known suppliers.
    Feb 2018
    Compton
    1989 325i Sedan
    Quote Originally Posted by Siebenthal View Post
    Thanks man but im in SoCal its a little far for me.
    Quote Originally Posted by superj View Post
    I cant wait to get everything put back together man.
    Quote Originally Posted by 82eye View Post
    I appreciate the comments and tips everyone. i will try my best to document the whole process the best i can. Of course with many pictures
    Feb 2018
    Compton
    1989 325i Sedan
    Wish I had more to update but financially haven’t been able to make any purchases. Just sitting and staring at it.
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    The Goetze head gasket or an original BMW should be good. The only head gasket to avoid is the Victor Reinz, although in general VR gaskets are good. (The VR head gaskets seem overly sensitive to prep work.) The Gates racing belt is overkill. A basic Continental/Contitech one is fine. INA for the tensioner and Graf water pump are good choices. Don't forget new head bolts. They can't be reused as they are stretch bolts. Make sure you follow the correct torque procedure that tightens them to an initial torque and then turns them through an angle. Deburr the pistons as suggested to prevent hot spots.
    "Howdy, Folks!"
  1. FS: 1989 325i sedan automatic in Queens New York $1000
    By Makster in forum 3 series & Z Series
    Last Post: 10-01-2010, 11:36 AM
  2. FS: 1989 325i sedan automatic in Queens New York $1000
    By Makster in forum New York / New Jersey / Connecticut
    Last Post: 10-01-2010, 11:35 AM
  3. FS: 1989 325i sedan automatic
    Last Post: 03-26-2008, 04:55 PM
  4. 1989 325i sedan red 5-speed New Jersey
    By lventura in forum BMW Cars For Sale / Wanted
    Last Post: 07-07-2007, 11:28 AM
  5. 1989 325i sedan
    By jay diemme in forum BMW Cars For Sale / Wanted
    Last Post: 11-07-2004, 02:01 PM
