Results 1 to 25 of 39
Thread: Should I turbo or supercharge my e31? Which route to go?
    Iceland
    BMW 850
    Its just to slow in the form of NA
    Feb 2017
    Raleigh, NC
    1998 M3 643whp
    IMO, you are making a mistake both ways on a V12. Build it out to be an NA, equal length header, ITB, sound porn car if you are unhappy with the power. There just isn't enough room in that bay for anything else. Anything you do should be centered around making the V12 shine as that is the real unique, collectible aspect of this car.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    It’s slow by today’s sport hatch standards and a porker in the weight department. I’d turbo it to have the torque to get it moving. An LSx V8 swap might be cheaper.
    Iceland
    BMW 850
    There are supercharger setups out There. One guy has 600 at crank
    Virginia
    97' m52 turbo
    Quote Originally Posted by Fatandre View Post
    Leave it alone, as is
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    That thing weighs almost as much as my 1999 Chevy Suburban.
    An 850 is a weekend driver.
    Find an E36, so you can enjoy the spoils of ALL the existing research and development.
    Iceland
    BMW 850
    Quote Originally Posted by milKt View Post
    My car is a bit ligther
    Any more inputs?
    Dec 2005
    Melbourne, Australia
    E24, E34 x2, E36
    If there is an effective supercharger kit go for it. Even though the centrifugal supercharger is technically the least efficient way of FI it’s the best if you want to retain a naturally aspirated type of character.
    Ive seen some v12 8seires with twin turbo and they certainly make great power but just lose some character.
    BMW’s
    90 E34 M5
    84 E24 M635csi standalone ecu with coil on plug
    94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
    97 Z3 2.8
    97 E36 M3 euro SC still u/c
    OTHERS
    11 Audi S5 APR stg2
    19 Volkswagen Amarok V6
    Iceland
    BMW 850
    but With turbo you could also get some insane sound, right?
    Oct 2016
    Philadelphia, PA
    E36 2JZ
    Twin Turbos will be loud and very expensive. And not always a good loud. Build it as an NA first with headers and cams. If you still need power then go NA E85 build and then supercharger. Your car just needs an exhaust and tune really. Don't spend 10000 on a turbo setup unless you plan on drag racing or something
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    Really depends on if your 8 is manual or auto. The auto makes things tricky with turbo, as the exponentially greater torque may overpower what that terrible and heavy automatic can handle. If it's manual, I'd say a custom single turbo. Twin turbos are very hard to package in that engine bay. Turn the exhaust manifolds forward like the F-body Camaro guys to and run a turbo up front and low.
    The biggest hurdle outside of packaging is tuning. To go turbo you really want a standalone, as the factory DMEs are very poor technology and trying to tune 2 (or 3 if you have an m73) will be a nightmare.
    Obviously turbo can cost a good bit more, especially if you don't do your own fabrication. That being said, you can really choose how you want your turbo power to come on depending on the size of the turbo. A single Holset hx40 or hx50, or a Borg Warner S400sx3 series turbo, would be great single turbo options and give you plenty of room to make power.
    If you were to go turbo, you could more easily package them by converting to a custom M8 style headlight by putting by xenon projectors with HIDs into the bumper lights, and get rid of the massive flip up headlights. I had an 8 series I was going to slap an iron block 5.3L LS into and do that exact thing, by going dual top mount turbo, and putting 1 turbo on each side where the factory headlight housings sit.
    All that being said, if you were to swap in a proper LS engine, or an S62, you would probably be better off in the long run.
    Quote Originally Posted by JOutterbridge View Post
    The v12 engine responds poorly to head work, camshafts, etc. Many have tried and it's a big waste of money because the engine itself is very inefficient.
    Dec 2005
    E24, E34 x2, E36
    If there is a supercharger kit out there with an intercooler get it.
    Like all kits u may need to finish off the kit especially with the tuning.
    lovely looking car. Btw
    BMW’s
    90 E34 M5
    97 Z3 2.8
    OTHERS
    11 Audi S5 APR stg2
    Sep 2009
    Lawrenceville, GA
    VW TDI and Dodge Dart
    Is it wrong that I want to see that car with a hole cut in the hood for an 8-71 Roots blower? That would solve the "no room under the hood" problem.
    Matt Cramer
    1997 BMW 328i convertible, 1972 Chevy C10 pickup, 1966 Dodge Dart slant six
    BMW - where "Why doesn't everybody build cars the way they do?" meets "Why can't they build a car the same way everyone else does it?"
    Virginia
    97' m52 turbo
    Quote Originally Posted by Matt Cramer View Post
    Wrong.
    If I had a V12 8 series, depending on the mileage. I would either
    Park it / drive it on weekends
    or
    (higher mileage) clean it up, weld in an unrestricted exhaust, and then drive the hell out of it.
    If I wanted a blower sticking out the hood I'd go domestic
    If this were my car it'd be my DD
    But all in all -
    what is the 12 worth on an auto anyway?
    And a few guys I've talked to say "whats the BMW V12 worth at all"
    Iceland
    BMW 850
    Its a V12 manual transmission
    Virginia Beach
    e36 M3 Supercharged
    Dinan did it.
    They may provide you with the information you need, since their kits are no longer available.
    http://www.jrwappel.com/my-rides/1991-dinan-8
    Norristown PA
    mostly bmw
    Neither.
    95 turbo 330ti. 01 maxpsi m3 e85. 01 m5. 01 m coupe. 03 AIM 996t e85. 06 x3 w/Meyers plow and winter daily. Prussian Motors is hiring!! prussianmotors.com/jobs
    Current e39t LS Turbo swap: https://www.bimmerforums.com/forum/s...LS-e39-Touring
    Iceland
    BMW 850
    I am starting to lean more towards the Turbo option
    NY
    skateboard
    Quote Originally Posted by bubela View Post
    Neither.
    This.
    Dec 2014
    Marin,Ca.
    4.9L 540i/Porsche 997
    Turbo, if possible. More expensive, but more boost options. I have a built s/c E34 540i/6 and would love it if it was turbo'd. But, S/C was easier to install and fab up. Still, either way is the fun way, gotta love boost, and in my case with fully built 4.9L M62 engine.Wish you good luck on your quest Luke Skywalker.
    Edit: I went turbo.
    22RPD Tuning '95 540i/6 custom turbo mit Borg Warner S400sxe/Rebello Racing 4.9L M62/JE pistons/Arrow rods/custom cams/S62 crankshaft/Darton sleeved/Focal custom stereo
    Porsche 996 Turbo Evosport GT 700-[700hp]-my daily
    Huntsville, AL
    95 M3
    I would go with two rear mount turbos, a small muffler pre-turbo and no muffler post turbo. The sound of the turbine would be heavenly.
    WOT
    Oct 2016
    Philadelphia, PA
    E36 2JZ
    I agree. You don't have an auto and you want power go mid size single or twin. Yes it'll cost more but setup properly it'll be a sick build. Expect to pay a lot though because standalone Ecu's and turbo part/fittings really add up
    Jul 2004
    Sid Knee
    325is, 96 M3 Euro
    a few NA bolt ons would have the most character
    Iceland
    BMW 850
    Quote Originally Posted by digger View Post
    like what?
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    Found an ancient thread from someone who built a TT 850: https://www.bimmerforums.com/forum/s...-streets-of-DC
    Looks like John in DC also sells supercharger kits so you might want to try to contact him.
  1. Turbo or Supercharge My E39 525i?
    By BmwLifer99 in forum 1996 - 2003 (E39)
    Last Post: 10-04-2016, 11:31 AM
  2. Turbo or Supercharge my e36 325i?
    By CameronC in forum Forced Induction
    Last Post: 11-29-2011, 03:24 AM
  3. Turbo or Supercharge my e36 325i?
    By CameronC in forum Engine Conversions
    Last Post: 11-27-2011, 01:19 AM
  4. Which route to go wiht my CA's
    By TYE in forum 1992 - 1999 M3 (E36)
    Last Post: 02-20-2003, 07:02 PM
  5. eibachs or h&r springs? which way to go?
    By 1995red318i in forum 1991 - 1999 (E36)
    Last Post: 10-15-2001, 03:55 AM
