Page 6 of 23 FirstFirst 12345678910111213141516 ... LastLast
Results 126 to 150 of 573
Thread: My '33 Hotrod is DONE....1/31/2023 update pics at post 515
  1. #126
    DeWitt, Michigan
    '97 540i/6, '97 328i
    To my way of thinking, the fact that the LS engine ISN'T overhead cam and still makes the power, is one of the biggest attractions to it. It's a very compact engine that crams a ton of power into a small space.
    I wonder what Mercury would pull out of a 9L non-DOHC LS engine, since they aren't concerned with emissions or really even power band. Probably not too much less than the DOHC version.
  2. #127
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Yes it is a nice small compact engine. It's 1.2L larger than our 4.4L and physically smaller. So easy and CHEAP to hop it up too.
    In need of space to open more boxes of parts the roof is now on top of the body and hoisted up to the ceiling.
    Got the starter, A/C, and alternator mounted. I'm 1/4 way thru the wiring.
    Started laying out the exhaust, will need to make custom pipes to connect the headers that I bought to the rest of the exhaust system.
    Top idler pulley and belts coming tomorrow. As soon as the chrome plated steering column arrives I'll start working on installing the electric steering.
  3. #128
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Tight clearances in that engine bay! Where does your LS3 source its accessory layout? CTS-V?
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  4. #129
    DeWitt, Michigan
    That's looking beautiful Jim! Do you see any obvious difficulties that have to be dealt with? In one pic it looks like the water pump connections might be in a bit of difficulty with the frame? Luckily, these water pumps come off with no trouble and can be chopped and welded if necessary.
    I like your ICT Billet (?) alternator bracket. What does it accomplish for your setup?
  5. #130
    May 2015
    Atlanta, GA
    540i6 S2M5 M2C 135 S52ti
    Saw the Mercury review in HotRod magazine last year, fantastic engine. Would be nice to have 750HP but in a 2400Lb car I'd probably kill myself. What I have now is a bit over the top.
    That engine probably costs more than my whole build.
    I don’t doubt it... and 2400lbs ?!? Holy $**t could use an M52 and be fast af
  6. #131
    May 2015
    Atlanta, GA
    My '33 Hotrod is here!
    Quote Originally Posted by tptrsn View Post
    Probly not much more without the head
  7. #132
    May 2015
    Atlanta, GA
    Quote Originally Posted by philly98540 View Post
    Wow! Thats gonna be fast!
    No DOUBT
  8. #133
    DeWitt, Michigan
    Quote Originally Posted by angeleye540i View Post
    I think you're overestimating the difference the DOHC head makes. A "regular old LS3" with just a cam can make close to 600bhp, at 6.2 liters.
  9. #134
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by computiNATEor View Post
    One can buy all of the CTS info, at a pricey $1200+, other companies sell all billet chrome parts for $1600-2500.
    Don't remember if the CTS parts are high mount components or not.
    The engine is a brand new, I don't want to have to replace the water pump, harmonic balancer, etc to use the above parts.
    I wanted low mount alt and AC so I'm piecing it together, think I'm into it for about
    Up front is tight. Got the new swivel t-stat today so that takes care of that issue.
  10. #135
    JimLev's Avatar
    Sundance Mesa, NM
    Just figuring out the spacing for the alt and AC to get it aligned with the crank pulley took some time and many put it on, take it off.
    T-stat is now replaces with one that swivels 360°.
    The ICT was really for an LS in a truck that had a long shaft WP and harmonic balancer. It was only $85.
    Just had to cut the spacers to get it aligned.
    One of the GM Connect and Cruise LS3 options was a 535HP. The sprinkle a little magic dust on it and your over 600.
    The ZZ454 puts out 727HP, pretty pricey.
    Don't need 4 stinking cams to make a lot of power.
  11. #136
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Well, I guess the CTS-V accessory drive kit wouldn't really fit, as it has provisions for a hydraulic power steering pump. It has the AC/alternator mounted in about the same place as your mounts do, though.
    I think it's an out-of-the-box bolt on for any LS crate engine, but I could be wrong. I remember Turbo Tom using it in his LS3 Miata build.
    This kit:
    https://www.summitracing.com/parts/nal-19155066
    As used in this Miata:
    https://youtu.be/fL3ZEQ8dzns?t=3m18s
    Nate J.
  12. #137
    JimLev's Avatar
    Sundance Mesa, NM
    Right, I'd need to dump the PS pump, plus I think the bracket for the AC and the compressor would hit my frame.
    In a normal car/truck the CTS would be an OK option.
    Good Miata video, it's going to be fast.
  13. #138
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    That seems like something I would have expected Factory5 to figure out for you. Or do they? Is the chassis designed for a classic SBC or...?
    Nate J.
  14. #139
    JimLev's Avatar
    Sundance Mesa, NM
    They offer the kit without engines and trannys.
    You tell them what your going to use (GM, Ford, Chrysler, etc) they supply the mounts to fit it into the chassis.
    You buy the engine from wherever you want, new or used.
    AC/heater box installed
    New t-stat swivel housing. The OE t-stat is 86°C, no 108°C crap. Main belt will be here tomorrow.
    Tranny dipstick and fuel regulator.
  15. #140
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Very fast. LS3 525. 2731 (+157 vs stock) pounds w/ hardtop, 54%/46% F/R (+1%/-1%). 433whp, 410wtq. ~11.6s @130mph.
    I hope you don’t mind me drooling over the pushrod suspension!
    Nate J.
  16. #141
    May 2015
    Atlanta, GA
    I’m not overestimating anything I’m just stating some factual info about setup and the output of over 100BHP per liter of the SB4... and makes 250 more HP than it’s pushrod brother... ALSO, all that cam modding is essentially to make up for the lack of a higher tech valve train and comes with sacrifices... idle is piss pour and could make one vomit from motion sickness lol... I’m not hating on push rods or LS... but we are talking about a crate motor with a warranty Bone stock... sure u can stroke, Cam, breath, and tune an LSx, but it’s warranty is void at that point... . As large or as small the difference is between a DOHC Motor vs a pushrod motor with the same specs, the DOHC will have the better efficiency (HP/MPG etc.) with regard to size, better power and tq curve, both shape and peak numbers... in this case the difference is about 250HP... but it’s much larger so there are sacrifices also...
    for the record I never said u needed DOHC to make power and the compact size of them without is one of the most appealing parts to them.... also without “magic dust” I can’t find any making much more than even at 500, I saw one with all the bolt ons making almost 500 wheel... but it had thousands of $ If parts and work in it.... all I was ever trying to. Say is the SB4 turn key swap is a step in the right direction for Mericans.... pros and cons to each, and the LS3 crate motor is DEFINITELY on my swap list.... the others LS7-SB4 are still 5 figs.... I’m just a fan of technology...
  17. #142
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Holy crap Jim! You’re really scooting along on that build! Pretty soon, that thing is gonna be really scooting you along! Awesome work!
  18. #143
    May 2015
    Atlanta, GA
    Tell me about it, I friggin love suspension like that...
  19. #144
    May 2015
    Atlanta, GA
    I just drooled for quite some time over all the pics.... reminds my (kind of) if my buddy who just built an Exocet
  20. #145
    DeWitt, Michigan
    LS3 crate motor with a cam, comparing the LS3 intake against the Mast Motorsports intake:
    Whether 575-ish bhp satisfies the definition of "almost 600bhp" or not is up to you.
    I love the cantilever front suspension too Jim!! That is going to look so clean!
  21. #146
    May 2015
    Atlanta, GA
    That’s impressive... I did snag I found one just shy of 500 wheel so I wasn’t calling u out... but only found one...
  22. #147
    May 2015
    Atlanta, GA
    And yes close to 600 would include anything over 560 IMO...
  23. #148
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by BimmrMeUpSnotty View Post
    Steve, hope to have the engine running in a few weeks, probably with open headers.
    Still have a butt load of wiring to do.
  24. #149
    May 2015
    Atlanta, GA
    So Jim, not that u need it in your Sub 3klb car... but knowing “your style” I’m wondering if u plan on spraying any magic ? If I had to guess without reading every post I’d guess not fresh out of the gate but probly down the road...
  25. #150
    JimLev's Avatar
    Sundance Mesa, NM
    I've thought about it but for the first year or so it'll stay stock. HP is something that we never seem to have enough of.
    I may not need more...did I just say that?
    The B7 looks pretty good!
  1. M62tu44 Vanos Guts and update on my ‘33 Hotrod
    By JimLev in forum 1996 - 2003 (E39)
    Last Post: 06-16-2021, 12:13 AM
  2. Replies: 28
    Last Post: 12-09-2004, 08:01 AM
  3. Who here has done a HID foglight conversion ? Pics?
    By CarbonBlkM3 in forum 2001 - 2006 M3 (E46)
    Last Post: 05-11-2004, 09:21 AM
  4. SF Bay Area Meet : e46 M3 - 1/31/2004 UPDATE
    By tomperwu in forum California sponsored by Avus Autosport
    Last Post: 01-27-2004, 02:55 PM
  5. World Challenge cars are done and off to Sebring (Pics).
    By TomM in forum Professional Motorsports sponsored by Bimmerworld
    Last Post: 04-04-2003, 03:15 PM
