Results 1 to 3 of 3
Thread: Help - Central Locking System Not Working,,
    Oct 2008
    Davidson, NC
    1995 540i Sport, 1968 Po
    Spent most of the day yesterday installing a new drivers door lock cylinder - not the easiest project. At one point the wires attached to the lock switch below the cylinder heater broke off . I was able to solder the wires back on and finish the installation. However... now none of the locks work. I've checked the #27 fuse as well as the internal fuse in the lock control unit and both are good. Thinking that my repair to lock switch may be the culprit, I went to pull-a-part and got a switch off an e30 - just hooked it up and still nothing. Thoughts on next steps? I've searched the interwebs and have run out of ideas. Thanks in advance guys!!
    Quadratechtown, PA
    5, 7, 4x4
    http://www.mesaperformance.com/faqs/centlock.html
    Without more info on exactly what the system is/is not doing, I would check the CLCU. You may have triggered the automatic unlock safety in that unit. Requires resoldering. But that means central locking locks then unlocks immediately.
    Oct 2008
    Davidson, NC
    This system is doing absolutely nothing - like it's getting no power. I pulled the CLCU and the little bit of metal is still soldered to the tower pin in the corner - no other burn marks etc. so it looks ok. Thanks for the response 8991XJ!
  1. Central Lock Button not working
    By Error47 in forum 1995 - 2001 (E38)
    Last Post: 04-11-2013, 01:09 AM
  2. Need help central locking system
    By djKibblez in forum 1983 - 1991 (E30)
    Last Post: 10-12-2010, 11:51 PM
  3. e36 coupe central locking does not work
    By achulbert in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-09-2008, 05:51 PM
  4. Central locking system not working
    By MPowerE30 in forum 1983 - 1991 (E30)
    Last Post: 08-10-2007, 01:43 PM
  5. central locking does not work on front passenger side
    By Bonzi in forum 1991 - 1999 (E36)
    Last Post: 02-09-2007, 10:05 PM
