Results 1 to 25 of 28
Thread: 1994 325 no start - lots of fun
    Feb 2018
    Coos Bay/Redmond, OR
    1994 325 - 1979 Mustang
    OK, purchased a one owner 325 140K Miles. Was running then wouldn't start.
    Brought it home, swapped the *completely* dead battery with a good one.
    Cranks at speed, but I was not getting power to the fuel pump.
    Fuse is good but the relay is not providing power to the fuse slot.
    When I jump the fuel pump relay, I get power to the fuel pump fuse.
    No new/used/borrowed relay would put power to the fuel pump fuse. Ground terminal on relay? terminal 86 functions with the key.
    That's problem number one.
    Problem number two.
    When I jumped the fuel pump relay, a humming noise could be heard from under the intake manifold. air injection pump? why would that turn on?
    I pulled the rear seat and you can barely hear the fuel pump running. almost inaudible with the fuel pump cover on. Normal?
    For problem number one,
    Should I be looking at the ground signals from the computer to the relays?
    For problem number two,
    Any experience?
    Car still does not start with fuel pump relay jumped.
    Any questions/answers are appreciated.
    Thanks All!
    Jun 2010
    NY
    1997 328i
    Probably the cam sensor.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    The humming sound you hear under the intake when jumping the fuel pump relay is probably the fuel pressure regulator, which is located on the fuel rail.
    Recently tested my E32 750 fuel pumps and also heard that sound, the fuel pressure pushes the fuel thru the fuel pressure regulator and pushes the diaphragm into open position, that the fuel is going thru the return line back into the tank.
    washington dc
    Avus Cosmos Calypso!
    gas in tank/no-working fuel gauge?
    Apr 2014
    UK
    1995 BMW 328
    First things is first, stop messing about and do a "stomp test" to get the check engine light to flash out any fault codes.
    IIRC cam sensor does not stop these starting, they batch fire instead
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
    Feb 2018
    The cam sensor is preventing the fuel pump relay from operating? I'm not sure I understand unless it has to do with the ground signal to the relay?
    thank you shogun, its surprising to hear as it sounds very mechanical/electric motor drive.
    Gas in tank, level sender functional.
    Will pull codes on Wednesday, I am away from my shop and only have access to a test light as of now.
    Still have a question from the first post,
    When I jump the fuel pump relay, the pump runs but its is extremely quiet. Inaudible with the rear seat on.
    Is this normal? It just barely makes a humming noise, half the volume as the sound under the intake.
    Could I be looking at a bad fuel pump?
    Apr 2015
    Tennessee
    1998 BMW 328i
    Pretty sure terminal 86 on the relay is the ignition switch for the relay. If it works with the key, and the relay is putting out power to the pump (terminal 87 is usually the output) then I'd say the wiring is fine and the pump is probably on it's way out.
    Can you record the fuel pressure while manually jumping the pump?
    Apr 2008
    Canada
    1992 BMW 325i
    I have a similar problem.
    Main relay supplies power to fuel pump relay via pin 87.
    If main is good, check if 12V at Pin 1 on DME connector with IGN ON.
    Pin 1 supplies 12V to fuel pump relay #85.
    My Pin 1 is only supplying 2.12V not 12V which is my problem and may be yours.
    Apr 2008
    Canada
    1992 BMW 325i
    Update:
    The above statement is correct except:
    Connector Pin#1 is supplying 2.12V is not an issue. I tested Pin#1 on another car and it gets even less voltage with IGN ON..
    I suspect our issue is a grounding issue on FPR #85. Even when I ground it out and it gets fuel it will not start like your problem.
    Apr 2014
    UK
    1995 BMW 328
    Quote Originally Posted by E36328Coupe View Post
    Why is everyone not in favour of actual diagnostic info
    Feb 2018
    Quote Originally Posted by XnWarden View Post
    Thank you, I don't currently have a gauge with the car, that was my first thought after I heard the pump running.
    Right, it does function with the key. But does not power the fuel pump circuit with a relay in. So the relay isn't functioning due to ground issue maybe?
    Apr 2008
    Canada
    1992 BMW 325i
    I took my fuel pump relay schematic to my local auto electric guy.
    Right away he said the #85 gets its ground from the DME #31.
    The FPR gets it power from #1 DME.
    His hunch w/o testing was the Crank Sensor as the DME is not sending. So I am going to take a chance and replace even though my ohms was 490.
    Feb 2018
    Quote Originally Posted by Grasshopper2Ant View Post
    Exactly what I figured out today. No ground on 85.
    I think crank and cam sensors along with a fuel pump would be appropriate in my situation.
    Feb 2018
    No codes.
    Apr 2014
    UK
    1995 BMW 328
    Quote Originally Posted by BlueCollarCars View Post
    No codes.
    As in stomp test gave no codes or diags machine gave no codes (with an ADS interface)? Still info that would be useful to say earlier.
    Cam sensor won't stop it running and will generate codes (usually)
    Feb 2018
    Stomp test, I had 4 cars in storage and this one did not make it on the transport back, this Wednesday it will closer to a scan tool
    "..Wont stop it running.." The car or the fuel pump?
    Not getting a ground on the FPR terminal is why the FP isn't running, someone on the forum had indicated that the ground signal comes from the computer and it relies on the cam sensor being operational.
    What would you do without the scan tool? I have a full day to work on it.
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    Did you do a continuity test on the fuel pump?
    The pump has a GRN/VIO and a BRN wire. The BRN is ground, the GRN/VIO is 12v.
    The fuel pump does not run if there is no CPS input.
    You said the car is a '94. Are you sure? If it is a '95, there is a thing called a Running Loss Solenoid and a Delay Relay. I do not know what these do, but they are tied into the fuel injector circuit. If this goes away, the Fuel Pump Relay does not fire. If the Production Date is 09/94 or later, the car is a '95. If the Production Date is before 08/94, then the car is in fact a '94.
    On the ground wire to the ignition coils, there is a 240 ohm resistor, if this is open then you could have a no-ground condition to the coils. If the resistor was shorted, you would likely not know, or maybe get some noise in the radio - something like that. Loss of ground would give no spark, not no fuel. (Just covering the bases.)
    Apr 2008
    Canada
    1992 BMW 325i
    Update:
    I changed my CS with a used one that had 520 ohms and the car started!
    FPR #85 is grounding as it should.
    Diagnostic codes may reveal CS or test for crank signal at the DME.
    Easiest is to test CS removed. I tested on vehicle and it got 490 ohms which seemed OK but took off and it had dirt and grease at bottom. It may very well be my problem.
    It may be DME but highly unlikely. Cam sensor and fuel pump are non factors.
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    Just for future reference the fuel pump only runs for a couple seconds when the key is turned on until it sees the crank position sensor indicating that the engine is at a high enough RPM to indicate that it is running. So you would need to be listening under the back seat while someone turns the key to the run position. The pump should not be very loud, you won't hear it unless the seat cushion is removed and maybe even the access cover on the passenger side. The drivers side cover is just the second sending unit.
    Feb 2018
    Quote Originally Posted by jc43089 View Post
    If only this were true.
    The FPR will not energize the FP circuit unless it sees the ground from the computer (which is controlled by the crank sensor). Even when turning the key to "on" with a bad sensor it will not energize the fuel pump.
    Put in a new crank sensor and all is well.
    I had a test light on the fuel pump fuse when turning the key, no power until I put the new crank sensor in.
    Update:
    Same here, purchased a new unit to the tune of $65. And the car started immediately.
    Thanks for touching base with me on your issue. I'm glad we were able to get things running again.
    Quote Originally Posted by Eric93se View Post
    Final answer?
    Apr 2014
    UK
    1995 BMW 328
    Answered in post 5
    Feb 2018
    Answered in post 5
    I don't know what to say to you. I never mentioned the cam sensor until someone indicated it could be a problem.
    I replaced the crank sensor after finding another ground issue thread on another forum.
    you didn't help at all bud.
    Diagnostics aren't the be-all and end-all people think. For example wife's 325 would crank easy but not run and no fault codes a while back. The ECU would have spotted a fuel pump relay missing (low current circuit) but not the lack of fuel due to a faulty immobiliser cutting the fuel pump.
    Another fun one I had recently, changed oil on it, started fine, then would not start. Diags showed the EWS systems was not letting car start (no faults as working as intended)
    Turns out the drivers door handle on the outside was stiff and the handle was sticking out and that was the cause...........I did not even see a ref to this in the EWS 1 manual!
    In spite of the fact it may not help if I was you, and I am not, I would get INPA and ADS interface and mistreku.zip
    Wont stop the car running, no need to speculatively replace
    Apr 2014
    UK
    1995 BMW 328
    Someone incorrectly indicated it could be a problem.
    I indicated it wasn't.
    You asked.........
    Answered in post 5
    I answered whether you found it helpful or not is beyond my control.
    Feb 2018
    You asked.........
    Right O. Incorrectly indicated, so you brought it up another time to prove what? I wasn't asking you for anything besides clarification of your vague "it" post. "It" is pretty vague when referring to a vehicle not running.
    Thanks for whatever you were trying to do.
    Apr 2014
    UK
    1995 BMW 328
    It wasn't vague at all in post 5. For someone that would have looked at the red herring cam sensor it would be useful, but as I said, if you found it useful or not is beyond my control
  1. 2000 528i Sport - Hard Start, LOTS of white smoke, No turns, high beams, dash lights!
    By adrock2003 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-04-2011, 05:25 PM
  2. EuroM3vsE46 330i, lots of fun
    By EuroBeast in forum Kill Stories
    Last Post: 10-13-2004, 06:44 PM
  3. Replies: 22
    Last Post: 04-20-2004, 12:41 AM
  4. lots of fun today
    By Crazyb in forum Kill Stories
    Last Post: 03-31-2004, 10:35 PM
  5. 1994 325is FOR SALE..... LOTS OF EXTRAS
    By Slvr328IS in forum BMW Cars For Sale / Wanted
    Last Post: 02-17-2003, 09:19 PM
