Results 1 to 5 of 5
Thread: MSport suspension and replacement shocks??
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Hi
    Answered my own question, MSport suspension is a 15 mm height reduction so standard shocks are OK.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Dec 2013
    Chicagoland area
    EXOTICS
    From my understanding, MSport shocks/struts are not the same as standard,
    in dimensions or part#'s!
    Verify here:http://www.realoem.com/bmw/select.do
    It's been awhile since I owned my z3,
    but I think I recall correctly.
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Yes they have a different part numbers. Only OE are available at silly prices, no after market ones. I was looking at the impact of fitting standard shocks/struts. Since the difference in ride height is only 15 mm, I concluded that standard shocks/struts would be OK.
    Dec 2013
    Chicagoland area
    EXOTICS
    Yes,theoretically ok,
    but in practicality,
    a much shorter service life,
    as you shall soon see.
    M and non-M struts are mostly interchangeable, the key difference is non-M sway bars connect to the control arm whereas M sway bars connect to the strut. Thus, you can use either type of strut on a non-M, but an M requires an M strut.
    Should be fine using the non-sport suspension on a sport Z3 model as well. No reason to expect a decrease in part life...
    PRICE CUT on ALL FABRICS
  1. 2001 740i Sport, Can I keep Springs and Replace Shocks
    By Johnny740i in forum 1995 - 2001 (E38)
    Last Post: 07-25-2018, 08:10 PM
  2. Replies: 9
    Last Post: 11-04-2017, 12:33 AM
  3. BMW Z4 New OEM M-Sport suspension and front shocks - No Longer Available
    By ArtemLepilov in forum Suspensions, Springs & Shocks
    Last Post: 08-22-2014, 06:16 PM
  4. Suspension Q: Replace entire thing or just the shocks?
    By motosport3 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-06-2003, 05:39 PM
  5. just replaced my suspension and have my old on for cheap!!
    By mkalle1 in forum Middle Atlantic - US
    Last Post: 08-15-2003, 08:46 AM
