Results 1 to 3 of 3
Thread: Gas Tank Replacement
    Jul 2016
    South Carolina
    1986 325e 2001 330ci
    Ok so I've had to work on other projects and just got back to the 86 325e so far I've replaced
    gas tank
    both gas pumps
    all fuel line
    timing belt and water pump
    starter rebuilt
    alternator rebuilt
    replaced all radiator hoses
    filler assembly
    washers under oil tube
    pulled and cleaned the intake
    cleaned the injectors
    changed the oil
    filled the cooling system with water (it's in a garage and I will replace with 50/50 after it runs)
    new battery
    Marvel Mystery oil in the cylinders
    new spark plugs
    So I'm ready to put gas in it and see if it starts when checking to make sure all gas lines are secure I see the two small lines that go over the in tank pump. I didn't know what they were until I started checking. So now that I know it has a gas expansion tank here are my questions.
    Since the gas tank was a huge disaster of rancid 18 year old gas and rust I'm guessing the expansion tank is also in a bad condition?
    Regardless as long as the car is not moving gas should not go into the expansion tank should it? I really want to start the car but I don't want to suck trash from the expansion tank and ruin my good work either.
    Thoughts?
    May 2005
    Houston, TX.
    15 X5, 02 330i, 09 MiniS
    The expansion tank doesn't generally have liquid gasoline in it, its more a vapor storage tank that may find itself with some liquid in it if you overfill the tank or if thermal expansion were to occur.
    I've parted out and worked on many E30's and never seen one of those tanks dirty inside.
    Tenured Automotive Service Professional - Avid BMW Enthusiast
    Jul 2016
    South Carolina
    Quote Originally Posted by Stück View Post
    Thanks. I was just confused because some people call it an expansion tank and some call it an overflow tank. I thought it might have been metal and corroded. I pulled the wheel and panel last night and inspected it.
    Put 6 gallons of gas in it today and while it won't idle it fired right up and will hold at about 1500 rpm. No smoke and runs smooth so for a car that sat for 18 years I'm happy. Now I just gotta get it to idle and I'll be moving on to getting the clutch/pressure plate, transmission and rear axle seals done.
  1. Fuel leaking from charcoal canister after gas tank replacement
    By RyanWsays in forum 1983 - 1991 (E30)
    Last Post: 07-11-2017, 02:51 PM
  2. Gas tank replacement DIY write up long!
    By Edwin NL in forum 1995 - 2001 (E38)
    Last Post: 08-12-2013, 10:53 PM
  3. HowTo-> Gas tank replacement
    By Edwin NL in forum E38 Common Problems and DIY Fixes
    Last Post: 02-03-2009, 10:55 AM
  4. A/C Gas Tank Replacement.
    By shook in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-21-2007, 07:12 PM
  5. e34 Gas Tank Replacement
    By AndrewH in forum 1996 - 2003 (E39)
    Last Post: 03-04-2006, 10:03 AM
