Results 1 to 5 of 5
Thread: 2007 x3 e83 loud knocking sound at hard acceleration.
    Feb 2018
    Canada
    2007 x3
    Hi, my x3 makes this sound when I accelerate, I made a video please watch it and let me know what you think it might be;
    I already changed flex disk, drive shaft center support mount, new oil in differentials, new oil in transfer case.
    Car still vibrates at over 60km/h and still has rear knocking sound.
    Thanks!
    Last edited by kosmos3d; 02-26-2018 at 02:43 AM. Reason: added slow motion to video
    Dec 2013
    Chicagoland area
    EXOTICS
    That sure sounds like a backfire/misfire problem,
    caused by the sudden & hard acceleration,
    with the popping/knocking sound being emitted by the rear muffler.
    This may be just me, but l would definitely check sparkplug conditions and gaps,
    if showing wear or age-Replace, along with a diagnostic scan for good measure.
    Feb 2018
    Canada
    2007 x3
    Quote Originally Posted by MIKYZZ4 View Post
    Thanks for the reply! I am not sure it sounds like backfire, to me the sound is more mechanical sound, like gear hitting other gear or metal, maybe wheel bearing/hub, or cv joint is my guess.. or differential needs to be rebuild or transfer case belt is loose..
    in snow and ice when the wheel is slipping and i apply enough gas it makes even more knocking
    Loose or broken suspension piece or exhaust bracket. Get it up on a lift and look at it.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Using Tapatalk
    Feb 2018
    Canada
    2007 x3
    Quote Originally Posted by dano1200r View Post
    Thanks for the reply. I will definitely inspect the suspension.
    *I added slow motion to video to make the sound more audible*
  1. loud whirring sound at start-up
    By Blutarsky in forum 1988 - 1996 (E34)
    Last Post: 11-29-2007, 01:34 AM
  2. e39 loud knocking sound from front wheels.
    By moodyblues in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-02-2007, 06:37 PM
  3. knocking sound at certain rpms
    By Acer in forum 1991 - 1999 (E36)
    Last Post: 05-11-2007, 06:23 PM
  4. Hard, but not loud, knocking sound....
    By SecondtoNone in forum 1992 - 1999 M3 (E36)
    Last Post: 07-27-2006, 04:59 PM
  5. Car Makes Grinding Sound At Hard Right
    By HK_M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-28-2001, 01:14 PM
