Results 1 to 14 of 14
Thread: Depo smileys
    May 2017
    LI New York
    1990 325i convertible
    Depo smileys bulbs required
    Received my smileys today. I know the headlights require the bulbs H1. Are the high beam and low beam the same bulb? Please let me know what you used.
    Feb 2018
    Anderson SC
    2000 BMW 528i
    Can you post a pic when you get them in? I am interested in seeing these.
    How was the fit and finish of these lights?
    Sent from my SM-N920P using Tapatalk
    Valencia, CA
    Imola E36 M3 E30 Touring
    Yes, they're both H1 bulbs.
    May 2017
    LI New York
    Quote Originally Posted by JamieG296 View Post
    Fit and finish was very good. Wiring was a bear. Used two relays and two diodes but everything works as designed. The city light are awesome btw.
    D03E4C5E-6C2C-479C-9655-9700C9DB023F.jpg7902E046-0910-4C2B-A417-869EAD03251B.jpg56010CD4-A4C1-4AB5-93FA-46245A728633.jpg
    1990 e30 325i convertible (BMW noob)
    Feb 2018
    Anderson SC
    2000 BMW 528i
    Quote Originally Posted by Scootsk View Post
    They look good!
    Do you have any advice on the wiring. Did you have a schematic on the wiring or some sort of read on it?
    I am definitely interested in these, so I want to gather some info on it. Anything you have would be very helpful.
    Thanks for replying
    May 2017
    LI New York
    No schematics. I tried wiring it from a YouTube video but when I put the brights on the low beams turned off. So I thought about it for a while and came up with a solution. I can try to explain. Can’t now but I’ll post something soon.
    Nov 2005
    canada
    2001 740i
    Just wondering where you got your Depo smileys from?
    1991 318is
    2001 740i
    Mar 2012
    Hopewell Junction, NY
    1987 325iS...edan
    Why did you need relays and diodes? I just made a small fuse box jump and wired the city lights into the running lights.
    Interested in vintage cars? Ever thought about racing one?
    Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
    Elva Courier build thread here!
    Feb 2018
    Anderson SC
    2000 BMW 528i
    Alright, thanks.
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    If it took you 2 relays and 2 diodes, you probably did it the hard way. But as long as it works...
    The problem is that the outboard lamps on a sealed beam car are actually 2 lights in one. In low, 1 light is lit from its own circuit. In high, the other light is lit on a piggyback from the high beam. With smileys and their H1 bulb, the car is wired that the outboard light circuits are powered in both low and high position. There is no second light to piggyback from the high beam. There's a mod you can do to one of the relays in the fuse box to keep the outboard lights powered in high.
    "Howdy, Folks!"
    May 2017
    LI New York
    Quote Originally Posted by bymep View Post
    eBay
    May 2017
    LI New York
    Quote Originally Posted by richardodn View Post
    i agree. It is the hard way. But here are my reasons. The headlight power is supplied by an 18ga. wire. Wasn’t comfortable putting two H1 bulbs on that wire. In addition I added a 7.5a fuse block since each light is protected in the fuse box by a 7.5a. Now the diode I added to prevent the backfeed of 12 volt through the low beam circuit. I couldn’t get a straight answer from several forums as to any issues this may cause so I added that protection. So what I have is a safe albeit over engineered headlight circuit. Wish I knew about the relay mod you mentioned. Would have been done last week and saved myself a few shekels. Lol
    Quote Originally Posted by ELVA164 View Post
    see my answer above. The city lights are wired through the side markers. They are led so wasn’t worried about the additional 12v draw.
    Feb 2018
    Anderson SC
    2000 BMW 528i
    Can you elaborate on the relay mod or post a link?
    Scootsk, it sounds like you were looking a safe route. I don't want to start a fire installing smileys lol. I am interested in seeing the mod though to see what would be best for me. I want a purchase a set for my car, but I want to make sure everything is already known before I start. I already have a ton of work to do on this car. The less headaches the better lol.
    Mar 2012
    1987 325iS...edan
    There will be no fires. Smileys are original equipment. Even the slight bump in wattage from sealed beams to smileys isn't dangerous, especially if you stay at the original 55W.
    Here's the link to one of the relay jump threads:
    https://www.r3vlimited.com/board/sho...ght=Relay+jump
  1. E34 Depo smileys w/ HID
    By cant hit bombz in forum E34 Classifieds (closing soon)
    Last Post: 04-13-2012, 09:45 AM
  2. Depo smileys fit '95's?
    By 5mall5nail5 in forum 1988 - 1996 (E34)
    Last Post: 02-01-2012, 08:47 AM
  3. E34 WTB depo smiley lens
    By dragracer440wed in forum E34 Classifieds (closing soon)
    Last Post: 01-17-2012, 03:15 PM
  4. FS: depo smileys and black skirts 06320
    By AHenry014 in forum E34 Classifieds (closing soon)
    Last Post: 07-10-2011, 03:51 PM
  5. Depo smiley headlights w/ philips ballast HID kit - comments?
    By vkluu1286 in forum 1988 - 1996 (E34)
    Last Post: 12-11-2006, 11:37 PM
