RM European Auto Parts
Page 1 of 4 1234 LastLast
Results 1 to 25 of 81
Thread: Active steering and DSC failure:/
    Jul 2012
    Sunde i sunnhordland
    E70 X5, E30 325i 2 door
    Hello. I posted earlyer on this forum but in the wrong place.
    Please check link and come with advice if you have some.
    The car is : e60 530d 2004 model.
    Optionlist are big but the relevant equipment is : dynamic drive, active steering and dynamic lights.
    To update, i have replaced following:
    SZL (3times used ones coded and programmed with winkfp and ncs expert)
    Active steering module (coded with winkfp and programmed with NCS expert)
    Motorposition sensor (New oem part)
    Battery (new original BMW 110ah) registered with DIS / gt1
    Idrive CCC unit because the old one was faulty.
    I still cannot run throug the acive steering calibration, and it failes when im told to turn the wheel +- 10 degrees from center.
    I have tryed calibrating with : DIS / GT1, ISTA rheingold, and INPA. (failes the same place in every program.
    The fault codes and some pictures are in this link :
    https://www.bimmerforums.com/forum/s...nd-DSC-Failure
    All tips and experience sharing is much apreciated.
    Sorry for bad english writing.
    Jul 2012
    The steering wheel is about 15 degrees to the left. I have active steering warning lamp and DSC warning light.
    Sometimes when i take it for a drive, the ABS is acting up and it pulses on the pedal when i brake evry time. The brakes are also very bad when this happends. Park the car. stop and start it again. all is back to normal. I have ordere a DSC module because of this, and a theory that it might be the module that keeps disturbing de CAN line. But this is just a theory. (all brake lines,disc and pads are new because of MOT )
    Have checked wires from the rack and found on suspicious wire with a break on the isolation but after i fixed this, there was no difference. (was to the lock solinoid on the rack.
    Jul 2004
    Houston, TX
    36 Cylinders
    I would try the following:
    Set steering perfectly straight on a flat road.
    Open Tool32, File> Load SGBD > choose SZL_60.prg
    Run job "luz_null_setzen" once to try to set steering back to zero.
    Also run job: "ABGLEICH_LENKWINKELSENSOR_RUECKSETZEN" followed by "ABGLEICH_LENKWINKELSENSOR" jobs
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jul 2012
    Thanks for reply
    I can try this tomorrow. But corect me if iam wrong, isnt this just calibrating the steering angle sensor ?
    When reading live data in inpa the steering angle sensor reads 0 when steering wheel is centered. And i have no problem calibrating just the steering angel sensor in INPA.
    Jul 2004
    Houston, TX
    36 Cylinders
    Ah ok. I am concerned about the plausibility error. Plausibility means that the sensor is working, but the values that are coming out do not match to another reading.
    The above procedure clears everything to zero in SZL.
    I have not worked on this ARS system much, but there are many functions and offsets possible with Tool32 in ars_60.prg
    I am starting to think that there is a value in the ARS that isn't matching the angle sensor in steering wheel, so plausibility error comes up. Then because of that, it doesn't let you calibrate. Just my guess.
    You may be able to set a zero point or delete any other calibration points with tool32.
    Has the replaced steering rack been centered on the tie rods?
    ARS_60.prg "START_LOESCHEN_LEWI" is an interesting job. It does: "Reset the learned steering angle offset"
    -Abel
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Abel, I'm glad you're here. Bimmers86, please know that 328 Power 04 is more familiar than anyone, with the computer programs you're using.
    However, he points out what I'd be guessing is the major issue you're having: MECHANICAL alignment. If the rack and tie rods are not correctly aligned, you can't possibly make the computers happy. I'd guess that some mechanical part is incorrectly aligned / installed, so the computers cannot be made happy with the numbers that are being shown by the sensors.
    Have any purely mechanical parts been replaced (like tie rods, rack, etc?) Have you hit a big pothole? Have you had a 4 wheel alignment?
    Chris Powell
    BMWCCA 274412
    Jul 2012
    the problem happend when i bougt the car. when driving home. a long trip. after 6hours driving the error came. then i stopped and checked oil. there was low oil level so i bought chf and refilled but no luck.
    the rack has not been replaced. and i have taken no alignment. im thinking electrical problem since i get trown out of the afs startup calibration program.
    Jul 2012
    i get error when trying "luz null setzen".
    code is :error_ecu_conditions_not_correct_or_request_seque nce_error.
    the other commands are okay.
    Jun 2002
    E39M5, E500 4WD
    This may not be the cause of your issues, but I saw on your DIS screen, at one of the threads you linked to, that your power supply to the AFS was 11.68 volts. That would certainly qualify as "ECU conditions not correct". All work of this nature needs to be done with a battery maintainer holding between 13 volts and 15 volts.
    Also, I see that you have an ABS pulsation issue. Is this not setting a code? Have you tried watching all 4 wheel speeds, to see if they correspond?
    I noticed on one screen your error happened when you had .46 G's of cornering, and significant yaw angle. It's worth noting that the active sway bar switches from leaning into the corner to leaning out of the corner at approximately .45 G's. Since you are also losing fluid, have you checked the braided stainless hoses that go to the sway bar motor, to see if one is torn?
    You've got so many links to so many threads, it's hard to keep up, but I think I saw a bunch of communications failures ? Is there any way you can post those screen shots all together on this thread?
    Chris Powell
    BMWCCA 274412
    Jul 2012
    hello. there is no fault code from the dsc except steering angle and signal between afs and dsc. (5f62 if i remember correctly). i have tested wheel speed with inpa and all are showing the same the last scann i did in ISTA shows error code on IBS communication. could this be the problem ? new one is ordered but i feel like im just replacing parts now to and see no result from it :/
    Jul 2012
    will do a read out of the fault codes again tomorrow and post new pictures since there is alot of links to other forums.
    Jul 2012
    Jul 2012
    Jul 2012
    Jul 2012
    20180226_172232.jpg20180226_172255.jpg20180226_173010.jpg20180226_173019.jpg20180226_173045.jpg
    So i updated with new fault code readouts. So i think its best to use this info. There are a couple of new ones on the SZL that i havent seen before.
    This is with the steering wheel centered.
    Jul 2004
    Houston, TX
    36 Cylinders
    U_ISIS and U_SZL signal missing is usually a fault with the steering angle sensor.
    They do go bad often on E60, just so you know.. but 3 times bad? Hmm.
    You installed them centered, and no tearing of the ribbons?
    -Abel
    Jul 2012
    the slipring i kept moving on to the different szl modules.
    bought 3 used ones. after trying and not fixing the second time i sold it used and it worked perfect in that car after i set it up the same way.
    i have inspected the brush sensor that this have and it looks clean and with no breakage.
    Jul 2012
    So today i replaced the DSC unit (only the module boltet with 4 screws) and there was no change.
    im at a loss now.
    Could anyone explain how the can signal travels from the szl to the dsc and the AFS? I mean is it the blue and white wire (which I think is the F-can) connected in serial, or is it trough another box that redirects the signal?.
    i dont want to throw another 450$ on another szl whitout checking other things that could be faulty.
    Jul 2012
    Im thinking, could i have done something wrong along the way when coding and replacing part? I have done as following:
    With daten v.55 i believe.
    1. Winkfp: flashed the modules with my vin and coresponding software.
    2. Ncs expert : expert mode- sg codieren (dsc,ars,afs,szl)
    3. INPA (dis,ista....) : deleted fault codes and synchronized steering angel.
    ALL the above without any errors or faults whatsoever.
    4. So i load up my DIS v.44 (also tryed DIS v.57 and on my 2 other diagnostic laptops) and function select. Active steering - startup alignment. (it completes motorposition reset =ok, steering angel calibration = ok, when it tells me to wiggle the steering wheel +- 10 degrees from center i press next and it stops working)
    AND right before this, it tells me to adjust the absoulute steering angel to 0 degrees. Here nothing happends when turning the wheel. it sits at 0 no matter how much i turn. could this be a pointer at the problem ????
    Jul 2004
    Houston, TX
    36 Cylinders
    Who is reporting 0, steering angle sensor or ARS?
    Maybe it's a wiring problem?
    You did everything fine in software.
    -Abel
    Jul 2012
    in the calibration routine it stays at 0. better if i run throug it and take photos for you maybe.
    im thinking wires to. but have only checked on the rack and right beside the modules i have replaced. all looks good...
    Jul 2012
    Jul 2012
    Jul 2012
    Jul 2012
    When turning the steering wheel left to right several times this changed to signal disturbed or something (it flashed very fast and i didnt quite cache what it said but it was something like it lost contact. At the same time i got an airbag lamp in my cluster. This has not happend before.
  1. Active steering and DSC Failure
    By Bimmers86 in forum 2004-2010 (E60,E61)
    Last Post: 02-24-2018, 02:06 PM
  2. 2001 Bmw 330XI power steering and DSC Problem
    By jj02850659 in forum 1999 - 2006 (E46)
    Last Post: 05-10-2011, 05:46 AM
  3. abs and dsc failure
    By 530dmaniac in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-07-2010, 04:37 PM
  4. ABS and DSC failure at 50,387 miles Please Help
    By pruettfan in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 07-22-2009, 02:36 AM
  5. active steering and such
    By builder in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-05-2005, 04:30 PM
