Results 1 to 9 of 9
Thread: Hood Hinge Bump Stop Orientation
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    This is going to sound retarded but how do these little square bump stops orient on the slot? As you can see the hole is offset from the center. Both of mine were missing so I have no proper reference.
    Mar 2008
    montreal,Canada
    bmw 850
    i think they are designed that way so you can adjust the hood height at the back.
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Ah I see. So just kinda rotate em around till I like it.
    Mar 2008
    montreal,Canada
    bmw 850
    Quote Originally Posted by killian665 View Post
    that's the idea
    Toronto, Canada
    BMW 850CSi
    I’m not so sure that the orientation doesn’t matter. The correct hood height should be adjusted using the 2, 10mm hinge bolts, not these things. I see these as simply rubber dampers/cushions. I believe the correct orientation is with the longer sides of the rectangle oriented horizontally with the resultant two thinner parts facing upwards (towards the hood) and towards the outside (hinge arm).
    So in the top photo, it would have to be re-oriented counter-clockwise 90 degrees for placement on the bottom photo nipple (drivers side). This results in a snug fit with least amount of distortion. I’ve founds that placing the thicker side upward (against the hood) or orienting the rectangle vertically causes the thing to get overly squashed over time and eventually fall out. YMMV.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    ^^^^this^^^^
    '91 850i 6sp (mint) (sold)
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Thank you so much. Oddly enough I was playing with them and that was the orientation I liked most.
    Mar 2008
    montreal,Canada
    bmw 850
    i have heard alot of e31s have issues with the wiper rubbing on the back of the hood and the missing bump stop is the cause of it,
    so that led me to believe that it does effect the hight of the hood.
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    That very issue is what led me to check if I had them or not. And I did not. So I guess we’ll see.
  1. Hood/Bonnet Height and Bump Stops
    By BobieM in forum 8 Series (E31)
    Last Post: 10-14-2015, 03:20 PM
  2. Bump stop question
    By BlackTintz in forum 1991 - 1999 (E36)
    Last Post: 07-16-2002, 01:12 AM
  3. Bump Stop Missing from GC Rear Shock!
    By ///M3 2 NV in forum 1992 - 1999 M3 (E36)
    Last Post: 07-13-2002, 06:43 PM
  4. Bump stop question.
    By aus in forum 1992 - 1999 M3 (E36)
    Last Post: 06-03-2002, 11:18 PM
  5. What to do w/ bump stops w/ bilstein sport & H&R sport??? HELP!!!
    By ///MForever in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-17-2001, 07:40 AM
