Results 1 to 4 of 4
Thread: Sway bar install tip
    May 2016
    Berkeley, CA
    1982 E21
    Thanks to all the info on this forum, I installed new control arms and tie rods on my 82 320i. In most of the posts on this subject, lining up the sway bar/control arms with the frame bolt holes was a two man job.
    I attempted the project solo and discovered that once all the prelim work was completed, the sway bar/control arm could be positioned surprisingly easily by using a come-along attached to each end of the sway bar, just behind the front washers. The washers keep the come-along hooks in place and the sway bar can be compressed while the control arms are tapped into alignment with the holes in the frame.
    It worked very well for me and I wanted to share it.
    Sep 2015
    Massachusetts
    E21 327i, E46 325iT/5
    Something like this?
    https://photos.smugmug.com/Cars/1980...MG_4288-X2.jpg
    I probably didn’t need the front strap but it didn’t hurt having it on there.
    May 2016
    Berkeley, CA
    1982 E21
    Nice - I should have taken a photo -
    Pioneer, CA
    73' tii 79 320i 73'2002
    I've used a ratchet strap with good success.
  1. Sway Bars install tips?!?
    By Filip75 in forum 1991 - 1999 (E36)
    Last Post: 09-06-2003, 07:03 PM
  2. Replies: 15
    Last Post: 02-10-2003, 12:39 AM
  3. Question on rear sway bar install
    By 19redwings in forum 1992 - 1999 M3 (E36)
    Last Post: 09-14-2002, 02:05 PM
  4. Is sway bar installation a DIY job
    By Saul in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-03-2002, 12:44 PM
  5. Sway Bar install instructions?
    By qwickm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-18-2002, 02:04 AM
