Hi guys, long time lurker. I'm planning to convert my e30 powered antenna to a fixed z3 antenna and I just noticed in the link to the picture below (first picture) of a Z3 antenna base where its grounded to the body of the car with a white wire connector, presumably the positive.
Why does this antenna have this setup when it's not supposed to be powered like the old Hirschmann? What are the extra wires for?
Many thanks, Al
http://www.zroadster.net/forum/viewtopic.php?t=8613
if its to the body, it is for sure aground so it could be to dissipate static from the air moving over the antenna while driving?
No e30s again.
Here's my conjecture. The Z3 antenna likely has a built in RF amplifier and the white wire is the power wire. This serves the same purpose as the white wire connected to your E30 antenna. When powered, it turns on (raises) the antenna. The major difference between the two is the old E30, the turn on wire is only a signal. The high current to actually turn the motor is one of the other wires. (I can't remember the color.) In the Z3 the white wire supplies enough current to power it directly.
Also, brown is the ground wire.
"Howdy, Folks!"
1997 328i/4/5 - Cosmosschwarz Metallic on Dove Grey - Auto/Manual Swap - M3 Bilstein Sport/H&R Sports (95 M3 mounts) - Offset M3 LCAB - 20mm M3 rear sway bar - X-Brace - AA Tuning Strut Tower Bar - Rogue Engineering RSM - Dinan Cat-Back - 3.38 LSD - E46 330 front/328 rear brakes - SS Brake Lines - E36 fitment Style 42's (staggered) - M3 Front Bumper - M3 side moldings - M3 Rear Diffuser - DJ Auto Headlights (6k HIDS) - Frenched Fogs - OEM Clear Tails - E65 Rearview Mirror (Homelink controls + Autodim) - Alpine Type S Cabin Speakers (6x9 Retrofit) - 8" JVC woofer - Black Kidneys - Red Needles/Chrome Gauge Rings - OEM Alarm - Full Interior/Trunk LED Lighting - Mishimoto Full-Aluminum Radiator - More to Come!
