Results 1 to 12 of 12
Thread: Who was asking what the temps were on my ceramic coated headers?
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    After driving about 15 miles I pulled into the garage, I kept the engine running.
    Pulled out my IR and digital surface contact temp readout.
    The reading was 415F on the digital and 420F on the IR.
    I'm sure I measured the temps on my OE manifold years ago but don't remember what they were.
    Must have been higher as my under hood temp seems lower with ceramic coated headers.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Ceramic coating? Headers? It is interesting, never hear about it, I knew that the coating of piston increases melting point of it, but what is the reason of coating of Headers?
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Not too hot Jim! Ceramic must be helping!
    I have an EGT sensor. Shows around 750 F at idle.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Mainly heats occur in combustion chambers/cylinders, that heat impacts to pistons and easelly destroy them. Why you need coated headers? What is the reason?
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by philly98540 View Post
    Philly, your reading the temp inside the headers, right?
    Quote Originally Posted by dovlet View Post
    Dovlet, the coating keeps the heat inside the header. More heat keeps the exhaust gas moving faster.
    Also keeps the under hood temps lower.
    Mar 2012
    Lansdale, Pa
    Yes, inside the headers Jim. On hwy cruise, it runs around 1000 F +/-. IIRC its around 1300+ F when I'm on it.
    I can't wait for your new project to get moving. All brandy new and shiny stuff!!!
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Is it? I did no know it. That is good. So, may i ask? What kind of new project Philly talking about? Share with me. I am interesting on that )))
    JimLev's Avatar
    Sundance Mesa, NM
    Dovlet, I'm building a Factory Five Racing '33 Ford Hotrod.
    I'm putting a new GM LS3 6.2L engine in it. Stock HP with 4 CAT's is 430. I already have the engine and tranny.
    I have ceramic coated headers on it and will not be using CAT's so HP should be at least 440, maybe 450.
    The car will weigh about 2400Lbs.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Deamn, i was also interested in ls3. I saw many projects with 100% income in power. Only changes in intake & fuel system can give you about more than 100hp. Wau, my regards bro. Good luck.
    JimLev's Avatar
    Sundance Mesa, NM
    Replacing the cam will give you an instant 50HP increase. Think it's about $200.
    Jul 2010
    baldwin, ny
    2003 540MSPORT 6 #861
    Ahhh welcome to the LS WORLD love that world
    2003 540MSPORT #861/1265 -GF71249 .Black Sapphire Metallic/Sandbeige.Dinan intake~M60 manifold
    Spec racing stage 2+ clutch and custom light flywheel .M5 rear LSD 3:15~M5 driveshaft ~Rogue Octane SSK
    36K ENGINE SWAP!!!.~Rogue thrust arm bushings~Rogue studds~Dinan strut bar
    EIBACH front/rear sway bars with BEASTPOWER brackets~CDV delete~Redline fluids/Racing blue Ate~ APEX EC7 RIMS SQUARE 18 x 10's~M Pararallel rims 9.5 all around~285 30 18 rears~265 35 18 fronts~ENKIE 18x10's square with Continental Slicks 275's square~RE 11's, 595 RSR's~BC racing coil overs 8k/6K~Steel braided brake lines~Powder Coated valve covers-A1 headers 100 cell cats, performance resonator and 4
    cross tips, CUSTOM BBK - MASSIVE HATS AND BRACKETS - AERO-6 WILDWOOD-, ANODIZED CALIPERS STAINLESS STEEL PISTONS THERMAL TREATED, CUSTOM WILDWOOD ROTORS 14.50
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Yeah, cheapest income ever.
  1. Replies: 1
    Last Post: 12-05-2017, 06:04 AM
  2. Who was asking about the Alpine E46 M3 at United Roswell??
    By M42boy in forum Georgia sponsored by Harrison Motorsports
    Last Post: 08-25-2010, 05:48 PM
  3. How to figure out what the offset is on my SSR's?
    By Gregg in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-30-2007, 04:39 PM
  4. whats the rev limit on my 328is??
    By jefiddler in forum 1991 - 1999 (E36)
    Last Post: 10-05-2004, 10:11 PM
