Results 1 to 5 of 5
Thread: CCC Reset How?
    Sep 2016
    Phoenix
    E46 E39
    CCC Reset How?
    No iDrive on 07 E66. Blank screen. I want to try to reset before I tear into it and have it fixed. What is the reset procedure?
    Jan 2016
    Ca
    2001 525it
    More important is if the sos module is failed and it can shut down the ccc. You can install an optical loop to remove sos module, it's a fiber optic loop. I believe the sos module is on the trunk, I would try that first.
    Sep 2016
    Phoenix
    E46 E39
    I see a loop in the glove compartment by the fuses. Is this the same loop that you are talking about? Can I remove that to diagnose and bypass any bad module in the system?
    Sep 2016
    Phoenix
    E46 E39
    I disconnected the loop in the glove compartment and one side of the cable has a red light. This, to me, the loop is completed. However, I still have no display nor radio.
    Mar 2017
    Casper, Wyoming
    2006 BMW 750li
    Quote Originally Posted by M5XTu View Post
    I know this post is a couple months old but I just thought I’d add my two cents. The fiber optic loop in the glove compartment is required as the fiber optic system will be disrupted and not able to complete its path. If your issue still hasn’t been resolved, I would recommend pulling out your MMI (display screen) and checking the fuse and wiring. It’s very simple to pull it out. You’ll have to pop off the black A/C vents and then unscrew I believe four screws on the upper portion of the screen.
  1. pressure plate resetting, how to/do i need to?
    By razahyde in forum 1996 - 2003 (E39)
    Last Post: 05-07-2009, 10:10 PM
  2. oil reset how to on a 1991 318i
    By smi2710 in forum 1983 - 1991 (E30)
    Last Post: 12-01-2008, 06:28 PM
  3. 1994 325 I engine oil reset- how to do
    By jergy7 in forum 1991 - 1999 (E36)
    Last Post: 01-26-2008, 06:09 PM
  4. Did Code reset, How long will it take b4 Sec pump is ready?
    By Third Riech in forum 1991 - 1999 (E36)
    Last Post: 10-31-2005, 10:49 AM
  5. Engine indicator reset...how?
    By efria in forum 1992 - 1999 M3 (E36)
    Last Post: 07-02-2002, 01:28 AM
