Hey guys noob question here. I just joined the forum. Looking to remove my motor/trans from my 325e next week and im wondering what the process is for the wiring harness. Should I disconnect everything or can i just unplugged the ecu and pull the slack through the firewall amd leave everything plugged in? Just wondering what would be best. Also if anyone has any tips on the engine removal process I would appreciate it. Thanks guys 👍🏽
you can for sure do it that way, unplug from ecu and a few other little connections by the ecu and than pull through the firewall. these older bmw are very easy to work on so if you have done this type of stuff on other manufacturer vehicles, you will be good to go on these cars.
No e30s again.
Great thank you!
Note, however, that the big firewall grommet is not sold separately, so be a little bit gentle with it.
2011 M3 Sedan
2006 GMC Sierra 2500HD LBZ
1999 323i GTS2
1995 M3 - S50B32/S6S420G/3.91
1990 325is
1989 M3 - S54B32/GS6-37BZ
Hers: 1996 Porsche 911 Turbo
Hers: 1989 325iX
Got it thanks nick 👍🏽
