Results 1 to 5 of 5
Thread: Real world experience with 8 1/2” and 9 1/2” wide 17” wheels
    casperlynn's Avatar
    casperlynn is offline Ghost in the machine BMW CCA Member
    Feb 2009
    kodak, tn
    96 Stg2 M3 clone
    Ok, I have a E36 currently on 17” x8” wheels with 40 offset, square, with 255 40’s in the rear and 235 45’s in the front. All fenders are rolled. The rear fenders are also slightly pulled. I am on adjustable coil overs with camber plates. No spacers. I do not have any rubbing issues.
    I am considering new 17” wheels. The fronts are 8 1/2” with 30 offset. The rears are 9 1/2” with 20 offset. Does anyone have any real world experience with these wheel sizes?
    thanks in advance!
    S52, AA C38-81 stage 2 aftercooled supercharger (14 PSI), Meth injection, Gatorback belts, Provent 200 oil separator, ARP studs, VAC MLS head gasket, SAP delete, ASC delete, TB heating delete, CCV delete, post cat O2 sensors delete, vanos mechanical jam delete, M50 intake mani, Mishimoto radiator, 155f thermostat, Stewart pump, euro diesal fan, CES overflow tank, AEM digital gauges, Bavarian coils, BMP tuned headers, Magnaflow true duals exhaust, E60 530i ZF manual 6 speed, UUC EVO 3 shifter, stage 2 E46 UUC clutch with Fidanza FW, M3 front brakes/spindles, E46 328i rear brakes, adjustable rear camber arms, adjustable camber plates on Yellow DPS coil-overs, M3 crossbrace, Staggered 255/45Z and 235/40Z BF Goodrich G-Force Sport 2's on 17's, 3.91 LSD, MM aluminum underpanel, Z3 steering rack, UUC sways.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Very wrong rear offset for the E36. You want more like ET40 if you want decent rubber. If you want to stretch some skinny tires on and tilt the wheels in like some of the kids do, then you might be able to fit 17x9.5 ET20 rears but I don’t know for sure. You can fit 17x8 ET20 in the rear but not with more than maybe a 235/40/17 and lots of negative camber.
    Apr 2015
    Tennessee
    1998 BMW 328i
    If you want a 9.5 inch wide rear I think 35 is the proper offset. I have no experience with wheels this wide, i just remember seeing a few apex fitment guides
    casperlynn's Avatar
    Feb 2009
    kodak, tn
    96 Stg2 M3 clone
    I thought the rear offset was way out there but I could not visualize it. I was hoping to go to a 265 series tire in the rear but I am not about to kid stance the car. Thanks for the input
    Jun 2005
    New England
    I run 275/40/17 on 17x9 ET42 and had to raise the rear and roll and pull the fenders. It does not really work. I will be installing flares. 255/40/17 is all you can reliably put in the arches with a reasonable ride height and not run a lot. Use flares if you want big rear tires and wheels — even the rivet on ones require cutting and welding of the metal underneath to provide clearance — it’s not quick and easy.
  1. Replies: 11
    Last Post: 08-06-2013, 10:41 AM
  2. Real world experience with BMW OEM wheel lock bolts?
    By bruinbro in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 08-04-2013, 06:10 PM
  3. Real world experience with Recaro Sportster CS seating?
    By WK446 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-23-2008, 03:55 AM
  4. My experience with UUC Pullies and the FDK
    By Oxcart 1 in forum 1991 - 1999 (E36)
    Last Post: 06-27-2003, 06:38 PM
  5. Jim Conforti full OBD II upgrade... Any real world experience?
    By ///M_Wraith in forum 1992 - 1999 M3 (E36)
    Last Post: 02-07-2003, 12:01 AM
