Car in question:
Upon inspection, it looks like the inner rim of the front wheels are slightly rubbing/grinding against the lock collars of my coilovers.
Specs of the wheels/tires: 235/45/17, 18x8.5 et15 square
I'd like to use a 3mm, 5mm, or even 10mm spacer up front, but would like to know what would be the best option without risking rubbing against the fender wall.
Any thoughts?
EDIT: I'm happy w/ the ride height and am not trying to adjust as I just got an alignment.
How much space is there from the tire to the fender?
Pictures?
10 mm front spacers would be nice because there are hub-centric IMO.
With 3mm spacer wheel will still center to car's hub. 5mm depens on the wheels center bore desing wheter it will center to hub or not. Usually 5mm can used too.
Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS, E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
Can't find my tape measure. Do these pictures help at all?
