Results 1 to 10 of 10
Thread: Studding the head
    Aug 2015
    Crystal Lake, IL
    1996 BMW 328i Sedan
    Studding the head
    Are the majority of you installing the head studs in the block with the head off? I’m trying to avoid taking the head off, and I’m having a heckuva time getting the 12 point nut and washer down in there let alone getting a socket in place-keep running into the bottom of the lifter trays.
    I’ve tried a dental pick, some pliers, a spring loaded grabby thing and my long E12 socket tool with a 12 point adapter I made:
    No luck. I really don’t wanna take the VANOS apart or the head off, it was a bitch ( well a pain anyway) to re-time the cams.
    Should I just pull the head???
    Manchester, N.H.
    96 332IS 6466 turbo
    Cams and trays out.
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Virginia
    97' m52 turbo
    Quote Originally Posted by SilburE36 View Post
    Can you not rotate the camshafts? There's divots in them for this very purpose.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    You can do it with the cams and trays in. But you may want a wobble extension on a short socket and you may need to grind down the socket to make it skinnier. And yes, the cams have flats or grooves you can take advantage of for clearance if needed.
    Huntsville, AL
    95 M3
    I did mine without removing the cams. I did have to grind two flats on the castle nut at 180 degrees from one another so that they would slide past the cams. I also left the bmw washers on place.
    WOT
    Jul 2005
    PEI, Canada
    2001 330i
    If you have 10mm head studs, this is possible.
    With 11mm head studs, I've got E14 nuts......which you have to pull the cam trays for....
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    I use a shaved 12mm socket (turn it on a belt sander). Works well.
    Mar 2013
    Upstate NY
    M3
    I can't remember for sure but I think the duralast socket works but 3/8 drive
    Aug 2015
    Crystal Lake, IL
    1996 BMW 328i Sedan
    Thanks for the input everyone. I’ll shave my 12mm socket down some more. I’m primarily having trouble with head bolts #1 and 2-seems like there is more “meat” around the cam tray in that area. The remaining bolts are MUCH less obstructed. I’ll leave the OEM washers in place also-thx hsv.
    On a somewhat unrelated note, is it acceptable to post pics directly from a phone, or is third party hosting (imgur etc) encouraged? It’s been years since I’ve posted to forums.
    Virginia
    97' m52 turbo
    I dont see why not? Either / or
    I'm sure the forum owners would like you to use a third party though, it would save them server space and bandwidth. Thing is with those free image hosting accounts is that they can delete your media at anytime or break the links
  1. Stripped an Exhaut Stud in the Head, Need Advice
    By 99mtres in forum 1992 - 1999 M3 (E36)
    Last Post: 07-30-2013, 03:06 PM
  2. Ok so oil goes through the head stud holes?
    By 5mall5nail5 in forum Forced Induction
    Last Post: 04-27-2008, 09:20 AM
  3. Oil goes through the head stud holes? M50NV head
    By 5mall5nail5 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-26-2008, 01:16 AM
  4. torque spec's for studs on the head
    By NAe36 in forum 1991 - 1999 (E36)
    Last Post: 11-01-2007, 09:48 PM
  5. are the head studs in a s50 motor the same as a s52?
    By JoCo in forum 1992 - 1999 M3 (E36)
    Last Post: 01-17-2005, 10:08 PM
