BMW of Bloomfield
Results 1 to 5 of 5
Thread: Immaculate Immaculate BMW 1995 E36 M3 Coupe - 5-Speed Manual - Dakar Yellow - $21500
    Dec 2003
    San Francisco, CA
    1995 M3 - Dakar Yellow I
    Immaculate Immaculate BMW 1995 E36 M3 Coupe - 5-Speed Manual - Dakar Yellow - $18k
    Immaculate 1995 BMW M3 Coupe for sale in Dakar Yellow (267) with M3 Lightweight Front and Rear Cloth Hurricane Pattern Manual Sport Seats / Black interior (0638)
    VEHICLE IS LOCATED IN NORTHERN CALIFORNIA (SF/MARIN AREA)
    Price: $18,000
    - 125,700 miles
    - Clean CARFAX
    - 4th Owner (purchased in November 2005 with 101,449 miles)
    - Extensive list of maintenance, repairs, upgrades and restoration work
    - Non-smoker
    - Extremely clean exterior and interior
    - Drives like new
    - A/C blows cold
    - Always garaged
    - Never tracked
    - No oil leaks, power steering leaks, coolant leaks
    - No warning lights/check control warnings illuminated
    - Factory Options: Sunroof, Cruise Control, On-Board Computer, Console Valet
    - OEM BMW Windshield (no cracks or chips)
    - OE ZKW Glass Euro Ellipsoid Headlights
    - BMW OEM Remote Keyless Entry Security System installed
    - Michelin Pilot Sport 2 235/40R17 Tires with little tread wear
    - Catalytic Converters replaced less than 1k miles ago (125,074)
    - OEM BMW 5-Speed ///M Shift Knob w/ Boot - Part No. 25-11-1-221-901
    - OEM BMW 98.5+ ///M3 3-Spoke Steering Wheel with Airbag
    - Suspension has been completely restored/repaired/upgraded (the following parts have been installed/replaced): OEM BMW front upper shock mounts, JTD rear shock mounts with OEM BMW reinforcement plates, OEM BMW front & sway bar bushings, Turner Motorsports rear sway bar reinforcement plates, OEM BMW front & rear / upper & lower spring hats, OEM BMW front tie rods, OEM BMW rear subframe bushings, OEM BMW rear trailing arm bushings (w/ limiters), OEM rear control arms & bushings, OEM BMW differential bushings, OEM BMW x-brace and Dinan Stage 3 Suspension (Koni single adjustable front struts and rear shocks, Dinan front & rear springs, Dinan front & rear sway bars and Dinan front fixed camber plates). *New hardware was used with every one of these upgrades/installations.
    Dec 2003
    San Francisco, CA
    Dec 2017
    Red Bank, NJ
    2016 Exomotive Exocet
    Was just wondering if the car is still available? If so can you please PM me, thanks!
    Dec 2003
    San Francisco, CA
    PM Sent.
    Here is a more detail list of the work completed to the vehicle:
    1995 BMW ///M3 Coupe 5-Speed Manual – Dakar Yellow (267)
    - VIN: WBSBF932XSEH03096
    - Options: Sunroof (0401), Cruise Control (0540), On-Board Computer (0540), Console Vale (0937, M3 100% Group (0102)
    - 10/94 Production Date
    - Original Retail Date: 12/15/94
    - Purchased on 11/30/95 with 101,449 miles
    - Current Mileage: 125,785
    December 15, 2005 – Mileage: 101,999:
    - Vanos Unit replaced with new OEM BMW Vanos Unit due to noise.
    - Valve Cover Gasket(s) replaced in conjunction with Vanos unit replacement.
    - Replaced Thermostat, Thermostat Housing and Gasket due to Residue Around Housing.
    - Replaced Coolant Level Sensor with new OEM BMW Coolant Level Sensor.
    - Flushed Coolant with BMW Coolant/Water 50/50 Mixture.
    January 5, 2006 – Mileage: 102,124:
    - Installed Original Equipment ZKW Euro-Spec Headlight Assemblies.
    - Installed Original Equipment ZKW ZKW Fog Light Assemblies.
    January 7, 2006 – Mileage: 102,241:
    Inspection II Service
    - Oil Change Completed with Synthetic Oil and OE BMW Oil Filter Kit.
    - Engine air filter replaced with OE Mahle Filter.
    - Microfilter replaced with OE Bosch Filter.
    - Spark Plugs replaced with OE NGK BKR6EK.
    - Transmission Fluid replaced with Redline D4 ATF.
    - Differential Fluid replaced with Redline 75W90 Gear Oil.
    - Fuel Filter replaced with OE Mahle Filter.
    - Redline Fuel Injector Cleaner put in Fuel Tank.
    - Brake Fluid Flush Completed.
    January 8, 2006 – Mileage: 102,260:
    - Replaced Lower Front Windshield Cowl Cover with OEM BMW Cowl Cover.
    January 10, 2006 – Mileage: 102,298:
    - Replaced Dashboard Air Vent (Center) with OEM BMW Air Vent.
    January 13, 2006 – Mileage: 102,315:
    - Installed UUC Version 4.0 Clutch Stop.
    January 15, 2006 – Mileage: 102,473:
    - Replaced Brake Rotors with Powerslot Slotted Rotors (all 4 corners).
    - Replaced Brake Pads with Hawk HPS brake pads (all 4 corners).
    - Installed new OEM BMW Brake Pad Wear Sensors.
    January 18, 2006 – Mileage: 102,562:
    - Replaced worn hood shocks with new OEM BMW Hood Shocks
    January 20, 2006 – Mileage: 102,614:
    - Replaced scratched Front Bumper Lip with new OEM BMW Front Bumper Lip
    January 23, 2006 – Mileage: 102,805:
    - Replaced worn Windshield Wiper Blades with new Bosch Wiper Blades.
    - Replaced leaking Vanos Oil Line with new OEM BMW Vanos Oil Line.
    - Replaced Oxygen Sensor with new OE Bosch Oxygen Sensor.
    - Replaced Crankcase Vent Hoses with OEM BMW Crankcase Vent Hoses
    April 2, 2006 – Mileage: 103,233:
    - Replaced slightly torn Guibo/Flex Disc with new OEM BMW Guibo/Flex Disc.
    - Installed Rogue Octane Short Shift Kit with Weighted Selector Rod.
    - Replaced Left Front Sway Bar Link with new OEM BMW Sway Bar Link due to ball joint wear.
    - Installed BMW Factory X-Brace with Oil Pan Buffer Stop (rubber) - OEM BMW Parts.
    - Replaced original Transmission Mounts with Black UUC Transmission Mounts & Enforcer Cups.
    - Installed OEM BMW One-piece M-Technic Illuminated Shift Knob/Boot Combo
    October 1, 2006 – Mileage: 104,172:
    - Replaced Brake Light Switch with new OEM BMW Brake Light Switch.
    - Replaced squeaking Factory Clutch Arm Bushings with UUC Clutch Arm Bushings.
    - Replaced Front Upper Seat Belt Mount Covers due to cracking.
    November 25, 2006 – Mileage: 104,268:
    - Installed UUC Magnetic Oil Drain Plug.
    - Installed OEM BMW Oil Filler Cap with S52 ///M Cap.
    - Adjusted Emergency Brake Tension (tightened as needed).
    December 1, 2006 - Mileage: 104,428:
    - Had OEM 17.5lb/hr. Fuel Injectors cleaned | balanced | blueprinted.
    - Cleaned Air Flow Meter (HFM) with CRC Air Flow Meter Cleaner.
    December 24, 2006 – Mileage: 104,516:
    - Installed OEM BMW Remote Keyless Entry | Security System.
    December 30 | 31, 2006 – Mileage: 104,580:
    - Replaced Clutch | Flywheel with new OEM S52 Clutch Kit and Resurfaced OEM S52 Flywheel.
    - Replaced OEM Clutch Fork, Dowel Pin, Throw-out Bearing, Selector Seal and Shift Knuckle.
    - Replaced Flywheel and Pressure Plate Bolts with new OEM Bolts.
    - Replaced Left and Right Front Fender Liners with new BMW OEM pieces.
    - Installed JTD Design Aluminum Front Under Panel.
    January 21, 2007 – Mileage: 104,682:
    - Flushed and refilled Washer Fluid Reservoir with BMW Windshield Washing Solution/Water.
    March 17, 2007 – Mileage: 104,884:
    - Installed OEM 1995 M3 LTW Front and Rear Cloth (Hurricane Pattern) Manual Sport Seats (roughly 1 of 125 sets of these seats).
    July 2, 2007 – Mileage: 105,562:
    - Installed Turner Motorsports Stainless Steel Brake Lines.
    - Installed UUC Motorwerks Stainless Steel Clutch Line w/ new OEM Clutch Slave Cylinder.
    August 19, 2007 – Mileage: 105,957:
    - Replaced all four Rear Subframe Bushings with new OEM BMW Bushings.
    - Replaced Outer Upper Control Arm Bushings with new OEM BMW Updated Bushings.
    - Replaced Outer Lower Control Ball Joints with new OEM BMW Updated Ball Joints.
    - Replaced Inner Upper Control Arm Bushings with new OEM BMW Bushings.
    - Replaced Lower Aluminum Control Arms with new OE Meyle Aluminum Control Arms.
    - Replaced Two Rear Differential Bushings with new OEM BMW Bushings.
    - Replaced Front Differential Bushings with new AKG Polyurethane Bushings.
    - Replaced Front Differential Bolt with new OEM BMW Updated Differential Bolt.
    - Replaced Rear Trailing Arm Bushings with new OEM Updated BMW Rear Trailing Arm Bushings.
    - Installed Ground Control Rear Trailing Arm Bushing Shims.
    - Replaced Rear Sway Bar Links and Sway Bar Bushings with new OEM BMW Links and Bushings.
    - Replaced all Rear Subframe Bolts, Studs and Washers with new OEM BMW Bolts, Studs and Washers.
    September 27, 2007 – Mileage: 106,933:
    - Replaced both Front Inner & Outer Tie Rods with OE Lemfroeder Tie Rods.
    - Replaced Tie Rod Boots, Clamps and Locking Plates with new OEM BMW Boots, Clamps and Locking Plates.
    - Four Wheel Alignment completed on Hunter Alignment Machine.
    October 13, 2007 – Mileage: 107,136:
    February 26, 2008 – Mileage: 108,784:
    - Installed Alpine iDA-X300 Digital Media Player Head Unit.
    August 6, 2008 – Mileage: 111,127:
    April 28, 2009 – Mileage: 112,114:
    - Replaced Idle Control Valve and Connecting Rubber Hose with new OEM BMW parts.
    May 1, 2008 – Mileage: 112,159:
    - Replaced Power Steering Reservoir with new OEM BMW Reservoir.
    - Replaced Power Steering Intake Hose with new OEM BMW Intake Hose.
    - Replaced Power Steering Return Hose with new OEM BMW Return Hose.
    - Replaced Power Steering Hardware, Washers and Hose Clamps as needed.
    - Replaced Front Wiper Blade Assemblies with new OEM BMW Wiper Blades Assemblies.
    July 9, 2009 – Mileage: 112,279:
    - Replaced faulty Driver’s Door Lock Actuator with new BMW OEM Actuator.
    - Replaced exterior Driver’s Door Handle with OEM BMW “BMW Motorsports” Door Handle.
    August 2, 2009 – Mileage: 112,363:
    November 4, 2009 – Mileage: 112,542:
    - Replaced Fuel Pump with new OEM BMW Fuel Pump.
    December 13, 2009 – Mileage: 112,833:
    - Replaced all six Bremi Ignition Coils and Coil boots with new OE Bremi Coils and Coil Boots.
    October 14, 2010 – Mileage: 113,922:
    - Installed Dinan Stage 3 Suspension Kit, which includes Front & Rear Springs, Front & Rear Koni Single Adjustable Shocks/Struts set at Dinan’s Spec (1 ⅛ turn from Full Soft), Front & Rear 22mm Sway Bars and Fixed Front Camber Plates.
    - Installed Turner Motorsports Rear Sway Bar Reinforcement Kit.
    - Replaced Front & Rear, Upper & Lower Rubber Spring Hats with new OEM BMW Spring Hats.
    - Replaced all Mounting Hardware, Gaskets and Bump Stops with new OEM BMW parts.
    - Replaced Battery with new OEM BMW 65AH Battery.
    October 25, 2011 – Mileage: 114,533:
    - Removed cylinder head and replaced Valve Spring Retainers with updated OEM BMW Part Number 11-34-1-432-453 with replacement of all necessary OEM BMW Seals, Gaskets and Hardware (Valve Seal Repair Kit, Head Gasket, Valve Cover Gaskets, and Cylinder Head Bolts).
    - Replaced Crankshaft Position, Coolant Temperature Sensor, Knock Sensor, Double Temperature Sensor, and Coolant Level Tensor with new OEM BMW Parts.
    - Replaced Radiator, Water Pump, Thermostat, Thermostat Housing & Gasket, Radiator Hoses, Heater Hoses, Expansion Tank, and Radiator Cap with new OEM BMW Parts.
    - Replaced Starter Motor with new OEM BMW Part.
    - Replaced Alternator and A/C Drive Belts, Hydraulic Belt Tensioner and Adjusting Pulley with new OEM BMW Parts.
    - Replaced Fuel Filter with new OEM BMW Filter.
    - Replaced Front Windshield and Perimeter Seal with new BMW OEM Parts.
    - Mounted and Balanced new Michelin Pilot Sport 2 Tires - 235/40ZR17 OEM Size.
    February 22, 2012 – Mileage: 115,114:
    - Replaced Clutch Arm/Pedal Assembly with Mason Engineering Metal Clutch Arm/Pedal Assembly.
    October 14, 2012 – Mileage: 117,428:
    September 29, 2013 – Mileage: 120,084:
    October 2, 2014 – Mileage: 122,989:
    May 22, 2015 – Mileage: 125,074:
    - Replaced both Catalytic Converters with CARB Compliant MagnaFlow 332304 Catalytic Converters.
    September 25, 2015 – Mileage: 125,283:
    - Replaced Left and Right Exterior Black Trim/Molding surrounding the Front and Rear Side Windows with new OEM BMW Parts.
    May 11, 2016 – Mileage: 125,348:
    - Replaced Main Belt Tensioner with new OEM BMW Belt Tensioner.
    September 27, 2016 – Mileage: 125,417:
    January 30, 2018 – Mileage: 125,602:
    Dec 2003
    San Francisco, CA
    Sold
  1. Replies: 26
    Last Post: 08-05-2015, 05:00 AM
  2. Replies: 0
    Last Post: 10-04-2014, 06:42 PM
  3. E36 1995 E36 M3 Coupe
    By ltutrani721 in forum 3 series & Z Series
    Last Post: 10-01-2012, 08:23 PM
  4. E36 FS: 1995 E36 M3 Coupe - Alpine White - 88k Miles - Nor-Cal
    By Spencer in forum 3 series & Z Series
    Last Post: 09-30-2012, 10:34 PM
  5. E36 1995 E36 M3 coupe sunroof motor/cassette
    By elliott95 in forum Interior Lighting & Body Parts
    Last Post: 04-09-2011, 06:31 PM
