Results 1 to 11 of 11
Thread: Thank you to geargrinder & my son to fixing my leaking msport!!!
    Jul 2010
    baldwin, ny
    2003 540MSPORT 6 #861
    Finally since owning her no more leaks!!!! Tks geargrinder for sending me in the right direction- my son who got me off my rear who is a b tech teased me he could diagnose it for $100 per hour lol- anyways you to can do it!!!! And yes it doesn't change my outlook lol
    2003 540MSPORT #861/1265 -GF71249 .Black Sapphire Metallic/Sandbeige.Dinan intake~M60 manifold
    Spec racing stage 2+ clutch and custom light flywheel .M5 rear LSD 3:15~M5 driveshaft ~Rogue Octane SSK
    36K ENGINE SWAP!!!.~Rogue thrust arm bushings~Rogue studds~Dinan strut bar
    EIBACH front/rear sway bars with BEASTPOWER brackets~CDV delete~Redline fluids/Racing blue Ate~ APEX EC7 RIMS SQUARE 18 x 10's~M Pararallel rims 9.5 all around~285 30 18 rears~265 35 18 fronts~ENKIE 18x10's square with Continental Slicks 275's square~RE 11's, 595 RSR's~BC racing coil overs 8k/6K~Steel braided brake lines~Powder Coated valve covers-A1 headers 100 cell cats, performance resonator and 4
    cross tips, CUSTOM BBK - MASSIVE HATS AND BRACKETS - AERO-6 WILDWOOD-, ANODIZED CALIPERS STAINLESS STEEL PISTONS THERMAL TREATED, CUSTOM WILDWOOD ROTORS 14.50
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Jul 2010
    baldwin, ny
    oh come on he's a putty cat
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    If you only knew what he told me.......
    Jul 2010
    baldwin, ny
    that would be great if anyone cared LOL ......
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    I wanted to open such thread about him (geargrinder) & Thad (tptrsn). Both of them always helping & supporting any one who need a help. My regards Gents.....
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
    DeWitt, Michigan
    Jul 2010
    baldwin, ny
    of course we can't forget JIM- Jim is the man - just a little appreciation is all that is needed for all the help these guys help - tks gents
    Roswell, GA 30075
    2003 540i Sport - 6 Spd.
    Quote Originally Posted by evomel View Post
    Yes, all of the aforementioned have been amazing in terms of helping me over the years, along with quite a few more. If only I had the skills and knowledge to have something valuable to offer in return of all their favors.
    Cheers!
    --P
    '03 540i-6
    153k mi; bought April ‘07 w/38k mi
    Silv/Blk, CWP, UUC SSK w/DSSR, M5 diff, JBR LW FW, SPEC Stage 2 clutch, Zionsville w/2-stage fan, coolant hoses, M60 intake manifold, motor-out overhaul (powder-coated VCs, TCGs, valley pan, coolant mani, head gaskets, heads refurb, all other gaskets, seals), Beisan vanos, PS pump & hoses, AC comp, fuel pump & filter, washer hoses, 88-degree thermo, DUDMD tune, Vibrant Racing muffler, Zeck CDV, Brembo solid-disc rotors w/ Textron pads & UUC SS brake lines, Dinan springs w/Koni Yellow shocks/struts, M5 front & rear sway bars, H&R 10mm spacers & studs front & rear, Pilot Sport A/S 3s, headlight adj repair, polished headlight lenses, 6k Umnitza Xenon & AE bulbs, new OEM M-Sport bumpers, gauge rings, permanent seat-twist repair to front seats, ZHP shift knob, M5 headliner kit (reinforced A-pillar clips), Schmiedmann pedals, MID & cluster pixel repair, Bavsound Stage 1 speaker upgrade & dedicated amp w/DSP subwoofers, retrofitted cupholder
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Thanks Mel.
    Everyone here is important, even if your not a veteran gearhead/wrench turner.
    Sometimes we don't know the answer to your questions so we do a little research to figure it out.
    It's a win for both of us.
    Jul 2010
    baldwin, ny
    Tks Jim- or should I say MANY tks its all good - and its a great feeling for both sides self gratifying!
  1. Help me welcome my son to Bimmerforums
    By bagman in forum 1983 - 1991 (E30)
    Last Post: 05-19-2017, 03:30 PM
  2. Finished my Interior and Fixed my door locks!
    By Alpinewhite 633 in forum 1976 - 1989 (E24)
    Last Post: 06-19-2010, 07:04 PM
  3. My clutch burnt out just after I taught my son to use it. Hmmm.
    By njcardsfan in forum 1991 - 1999 (E36)
    Last Post: 10-13-2006, 09:12 PM
