Results 1 to 6 of 6
Thread: Shift pin kit install. Is this normal?
    Richmond, VA
    99 M Roady; 02 540it
    Someone give me a clue, lol.
    Just bought and used Thayer Motorsports drift kit and ZF trans pin and bushing kit and just finishing up and came across a possible issue? Any help would be much appreciated. Video explains
    http://www.youtube.com/watch?v=g7ZmgkNU0zs
    Dec 2013
    People's Republic of MD
    22 doors and 4 tops
    Looks like you installed one of the bushing too far as you used the wrong drift pin. Ask me how I know.....
    Remove the 5th and reverse detent pins, look inside the holes while you activate the shifter and see if the fork is hitting the bushing..
    PM me if you want to talk. I've done several of these and F'ed one up by going too quick and grabbing the wrong drift pin. Cost me three days and $5 for another bushing..
    Richmond, VA
    Quote Originally Posted by 66 6 View Post
    Thanks so much for replying. I am dumbfounded. I did this exactly.....
    • To install the new lined bushings for the reverse gear pins, slide a bushing (BMW 23117542726) onto the reverse pin bushing drift (BMW 234023), and tape into place with a mallet until the drift bottoms out against the transmission case (fig. 06-01).
    • Installing the 5th gear bushing is the same as the reverse bushing, except that the slightly-shorter 5th gear bushing drift is used (BMW 234022).
    One guy guy told me to put the circle clips back in, then roll the transmission on a table all way over once or twice and things will “fall into place or get properly seated” and I’ll be good. That sounds weird.
    Richmond, VA
    Quick update for all. Apparently when you have this symptom, literally just roll the transmission over one turn ad things “fall into place”. Lol. Works like a charm!
    Jun 2016
    North Carolina
    '94 325ic, '03 530i 5MT
    Glad you got it sorted. I thought someone was pulling your leg but apparently not! Good to know for future project.
    Mar 2017
    San Francisco
    1998 M3 Sedan
    I'm currently installing new bushings and pins for reverse and 5th gear and am having trouble placing the sealing cap and retaining ring back on. Can anyone provide any tips? Thanks in advance.
  1. Is this normal - difficult to shift in reverse when cold?
    By achtung98m in forum Z3 (E36/7, E36/8)
    Last Post: 12-30-2014, 03:28 PM
  2. Shift lever play in rubber bushing is this normal???
    By bpeters in forum 1992 - 1999 M3 (E36)
    Last Post: 04-30-2010, 05:18 PM
  3. Installed iPod interface, iPod stays on at all times is this normal?
    By jcj1 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-24-2007, 12:36 PM
  4. Replies: 15
    Last Post: 03-31-2007, 07:39 PM
  5. Is this normal? (my front suspension install)
    By ArkticSilber in forum 1992 - 1999 M3 (E36)
    Last Post: 10-22-2003, 11:09 AM
