RM European Auto Parts
Results 1 to 6 of 6
Thread: E38 740il Need help oil pan problems
    May 2013
    nc
    1997 740il 2008 750li
    What steps should I take
    I have a 1997 e38 740il. It was parked for 3 years and now I'm trying to bring her back to life. Long story short I removed the oil drain plug and a thread was broken . in I served it back in and it got stuck. I applied pressure down and and removed it. Well today I went and got a new plug . It went all the way in and wouldn't lock tight so I removed it. It came out but the threads was boogered. I think the threads in the pan are stripped. If seen some post about moving up to m12 1.75 self tapping bolt. What should I do?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Jan 2016
    Ca
    2001 525it
    Or replace the lower oil pan
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Yeah, on that engine, I'd recommend just replacing the lower pan. A helicoil is the wrong choice anyway.
    The pan already used an M12 x 1.5. If you were going to try for a simple drill and tap to a larger size, you'd go to a Mercedes 14 x 1.5
    Really, most salvage places will have a lower oil pan, and that will be your best bet. Don't forget to buy a new gasket !
    Chris Powell
    BMWCCA 274412
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Check the bolts on the oil pump while you have the pan off. They are known to work loose on the early E38s. Also make sure there is no debris, i.e. bits of plastic, in the bottom of the oil pan.
    Jun 2002
    E39M5, E500 4WD
    Yeah, bits of plastic pretty much mean you're doing the timing rail job.
    "Self-tapping bolts" are B.S.. NEVER EVER try that. Do it right, or don't do it.
    Chris Powell
    BMWCCA 274412
  1. Need help oil pan
    By Atl E30 in forum Georgia sponsored by Harrison Motorsports
    Last Post: 07-08-2012, 10:29 AM
  2. need help oil pan cracked
    By overman9999 in forum 1983 - 1991 (E30)
    Last Post: 09-25-2008, 07:18 AM
  3. Please help, oil pan problem
    By trojanman in forum 1991 - 1999 (E36)
    Last Post: 08-16-2005, 07:42 PM
  4. Help, need an oil pan for '93 318i.
    By Ken318 in forum BMW Parts For Sale
    Last Post: 10-29-2004, 10:14 AM
  5. Help! (Oil Pan Gasket Problem)
    By m3teknitian in forum 1992 - 1999 M3 (E36)
    Last Post: 02-28-2004, 04:24 PM
