I've been scratching my head with my headlights first I got right side was malfunction, then this past week my left low beam went out , today I went I got new bulbs replaced them and still haven't had any success added pictures for before and after, could it be a fuse issue?
before
https://drive.google.com/file/d/0B7y...ew?usp=sharing
after
Can't tell if yours is pre-lci or not.. but my 09 has a quirky passenger side low beam. I think the igniter needs replaced. Have you checked those?
It's an older pre-lci model.
Start with the easiest solution first. (Fuse)
Also, the wiring insulation flakes off after 6 years or so on these cars which could be causing a short or other error. I just reinsulated mine a couple years ago. There are many threads across the interwebs on this.
Sent from my VS988 using Tapatalk
Mine was doing that recently bought a new ds1 with the built in igniter bulb no luck it ended up being the ballast underside of the light
