Results 1 to 23 of 23
Thread: Little piece of metal found in rear Diff???
    Jan 2005
    Wisconsin
    1992 bmw325i
    Was starting to change all the fluids in my 99 M3 I just bought and found this piece near the drain plug. Fluid that was drained was actually pretty clean. Not new but not real dirty. I don’t have a lot of knowledge when it comes to knowing the internals of the differential. Anyone have an idea of what this is. The car drove great for the 200 miles I drove it so far. No grinding or whirring noise in the rear at all.A7EC247A-BB98-4CE1-B227-4F7A6F2455C9.jpg
    Apr 2014
    NY
    1998 328i
    I would pop the cover off for a closer look.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    The carrier cap bolts loosen up and can come out and the cap can crack or break. You will likely have much worse problems soon.
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Quote Originally Posted by troy19bimmer View Post
    That's the cap breaking. You need to stop driving it right now. If one of those ears has broken off, you've sheared all the bolts but one - and that last bolt broke the ear rather than breaking itself. Ask me how I know.
    You're living on borrowed time. The good news is that if it's still functioning, you've likely caught it in time to save it.
    It's not too hard to remove (both the diff and the LSD carrier). You'll have to extract the bolts with vice grips or something, and you'll need new grade 12.9 bolts (I got mine at Bel-Metric, but don't remember the size off the top of my head) which are decently inexpensive. I'm sure there's a DIY around here on it.
    But I'd stop driving it immediately if you want any hope of saving your bearings. This is an easy Saturday project, maybe even a half day if you're decently experienced.
    Jan 2005
    Wisconsin
    1992 bmw325i
    I have not driven this car in over a month. It has been sitting on my lift at my shop, as I have been replacing a lot of parts/maintenance items. Like I said I don't know much about the internals of a diff so that's why I posted this. I will have to drop and remove cover and inspect from there I guess. I have enough common sense not to drive the car once I discovered this. I am glad I decided to change all the fluids in the car so that I did discover that broken piece in the diff.
    Jan 2005
    Wisconsin
    1992 bmw325i
    What is the technical term for that flange/cap?? Do they sell them aftermarket or am I stuck buying right from BMW?
    Jun 2005
    New England
    Try bimmerdiffs but you don’t have to buy from them or bmw. Just use the correct size and grade bolt. Unfortunate since your cap is damaged, you need to find a good used one.
    Apr 2016
    Irvine, CA
    99 328is, 03 X5
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    I'm not sure you can buy the internal parts of a diff at your local auto parts store. I would ask at the transmission shop. There are distributors that sell to the transmission shops, they would be the source for differential parts also. You have one of those parts where you take it into the shop and drop it on the counter and say, "I need one of these."
    I bought a rebuild kit for an old NP-435 transmission once upon a time. There was a transmission supplier that I found on the 'net that was on my way home from work. I forget the name of them, but you should be able to find a parts supplier that has an office that's just a FedEx truck away.
    Jan 2005
    Wisconsin
    1992 bmw325i
    https://www.difflab.com.au/BMW-188mm...air?search=cap
    This looks like what I will need. I guess Ill remove diff and see if this is something I feel comfortable doing once I get it apart. If not, I have a trans shop I send work to once in a while that would install it for me.
    Jun 2005
    New England
    The bolts are no big deal. You can get them from a lot of places if you know the size. The cap is obviously harder to find.
    Jan 2005
    Wisconsin
    1992 bmw325i
    Will keep you guys posted. I already have the drive shaft and exhaust dropped already because I was replacing the shifter and other parts so I am not too far away from removing the differential. Will also post pictures as well. Thanks for the help so far.
    Jul 2010
    Murrieta, CA
    DRIVESHAFT POINTERS
    You should mark the two halves where they separate in the middle at the slip joint. You should also mark where the yokes bolt to the transmission and differential. The transmission end has a flex disc, the disc has arrows on it that point to the front of the car and the screws that bolt the shaft to the transmission alternate directions. You should replace the center support bearing, there is a rubber piece that suspends the bearing within the holder, the rubber rots and comes apart. Push the bearing support forward in the mounting holes.
    The u-joints must be re-aligned so they are in phase (on the same plane) with each other. If the u-joints are not in phase, you can get some driveline vibrations that will make you crazy. There is a u-joint on both sides of the slip joint.
    Jan 2005
    Wisconsin
    1992 bmw325i
    Yeh that stuff is all done already. That part of the reason I dropped out exhaust and drive shaft already was to replace those items and the quibo(was all torn up and had random hardware not installed properly). I got all new bolts and nuts to install the new guibo. I unfortunately did not mark the driveshaft at the rear diff and the front at trans so I guess I will see what happens when it all goes back together.
    Jul 2010
    Murrieta, CA
    Marking it just makes it easy to see that you have the parts all aligned. If you did not mark, then you must check else all hell will break loose and you have to take it all apart again. It's far easier to look now, and correct the assembly if it's wrong.
    TIP for making marks
    Go to the hardware store and buy a bottle of Appliance Touch-up Paint. It comes in a small bottle with a tiny applicator brush built into the cap. Clean the surfaces where the paint will be applied, and the paint will remain for years.
    Jan 2005
    Wisconsin
    1992 bmw325i
    I just took the diff out and one of my techs did mark the drive shaft in the front at the trans and at the rear diff. I also marked the axles so they go back in the same spot as well(don't think that really matters but did it anyway. Going to send to a trans shop I use and have them install the new cap and bolts. Just don't want to wait two weeks to have it shipped from out of the US. Anyone have any other sources within the US and know what bolts to order if the cap doesn't come with them?
    Jan 2005
    Wisconsin
    1992 bmw325i
    Also just saw the subframe has a crack in it. Can this be welded or repaired without removing it?4627FB67-CD57-4226-9AE1-929AC34996A1.jpg
    May 2017
    Owings, Md
    1998 328i
    Looks rusty, I think you would be better off swapping it out for a clean used one, they aren't expensive
    Apr 2016
    Irvine, CA
    99 328is, 03 X5
    Something to consider in order to avoid this happening again, a powder coated and reinforced subframe... they aren't cheap by any means, however. But something you could easily do on your own, locally.
    https://store.garagistic.com/e36-rei...-rear-subframe
    Jan 2005
    Wisconsin
    1992 bmw325i
    Yeh I found that site Team Neverlift and that's actually not too expensive in my opinion. I just bought this car and haven't even driven it more than 5 miles. I was hoping to maybe attack the rear sub frame next Winter when my shop is a little slower. I just want to make sure the car runs and drives good for a summer before sticking another few grand into it like I recently have. I guess I will let it ride for the meantime unless I hear some really bad noise or clunks back there. I can always throw it up on a lift pretty quick and inspect it periodically.
    Jun 2005
    New England
    If you can get that crack area cleaned up, mig it and maybe add some reinforcement. Then next year pull the subframe and blast it and paint it and reinforce it or buy another one.
    Jan 2005
    Wisconsin
    1992 bmw325i
    Yeh I may do that before I re-install the diff and everything else. I like the idea of replacing the entire subframe and installing all new bushings in it as well. I'm in my 30's now and I bought my first e36 when I was 17. It wasn't any fun back then because I couldn't buy all sorts of parts for the car. Now that have a business and make pretty good money, its more fun to own an m3 vs. when I was a teenager.
    Jun 2005
    New England
    If you have the time and money, redo all your rear bushings and mounts now and reinforce the subframe and do RTAB pocket reinforcements and rear subframe mounting point reinforcements. Use M3 spec outer rear control arm bushings and subframe bushings. You will transform the feel of the rear end.
  1. Metal shavings in rear diff?
    By 530transam in forum 1988 - 1996 (E34)
    Last Post: 02-14-2012, 09:30 AM
  2. What is the downside of using spacers in rear?
    By five3five in forum 1992 - 1999 M3 (E36)
    Last Post: 03-31-2005, 11:48 AM
  3. Pieces of metal in my oil....
    By Wasiq in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-11-2004, 05:01 AM
  4. A Little Piece of Sunny Florida...
    By Ron17 in forum Georgia sponsored by Harrison Motorsports
    Last Post: 04-21-2004, 03:36 PM
  5. I found a SMALL piece of metal on my oil plug magnet
    By J10B in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-10-2004, 10:12 AM
