Results 1 to 9 of 9
Thread: AWD, DSC, ABS Malfunction
    Dec 2015
    Speonk
    08 S4 Avant, 04 Touareg
    Has anyone gotten the AWD, DSC, ABS Malfunction? Mine just popped up so I went to Autozone - no codes.
    But they symptoms are becoming more consistent: at initial start, no codes but immediately after putting it into 1st, the 4X4 warning goes off - coupled with an odd, stuttering and loss of power; after a min or two, it then goes into AWD, DSC, ABS Malfunction. The strange thing is after it signals AWD/DSC/ABS - it drives fine, under acceleration and braking. I'm guessing I have to take it to a dealer now.
    2010 BMW E61, MT, Miro 111 (Stage 1 BMS JB4 upcoming...)
    2008 A4 Avant 2.0T, MT, Stage 2+ (AWE Tuning, Koni FSD/Eibach), BBS CK (sold)
    2004 Volvo V70R MT, Flash Green/Atacama (sold)
    2004 VW Touareg 4.2L V8, 19" AHTEO's
    1998 A4 Avant 2.8L MT (totaled)
    1995 90 Cs Quattro MT (sold)
    Jul 2017
    Oxford, MS
    2010 BMW 528xi 2001 530i
    Have you done any maintenance lately where the battery was disconnected for a long period of time? I had mine off for a week almost while replacing a valve cover. The same warning went off but it cleared itself up within about half an hour of driving
    2005 RHD TJ Sport
    2010 BMW 528xi
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I would try a better scan tool. One with BMW specific software.
    Correct. Autozone cheap scanners can't scan the DSC module.
    DE, USA
    '15 435i,'10 535i,'08 X5
    Might be low voltage.
    Check battery voltage before and after starting.
    Use DMM or unlock OBC and use test 9.
    Feb 2018
    North Tonawanda NY
    2009 528i X-Drive
    Mine has been doing the same thing after I replaced the rear bearing with a non dealer rear bearing . Switched it to a bearing from the dealer all lights are gone
    Dec 2015
    Speonk
    Replaced battery, let is sit overnight and all the errors are gone! Keeping fingers crossed. Would anyone know why a "low battery" notice doesn't go off first?
    Seneca, SC
    2007 750i BMW; 2003 Z4 3.0 BMW; 2002 Lexus LS430;
    The first symptom of a failing battery in my '08 was constantly having to reset the time. In my '03 Z4 all the warning lights would come on.
    Aug 2016
    Next to Snowden
    Not a BMW that's for sur
    Quote Originally Posted by jomama View Post
    Dunno, but battery problems on our E60's can trigger a whole slew of unrelated codes. Usually the first bit of advice in these situations (battery codes and other unrelated codes) is to charge/replace the battery and clear the codes and see what comes back.
    Let's hope this solved it for you!
  1. Replies: 3
    Last Post: 12-21-2015, 06:50 AM
  2. AWD, DSC, ABS and EMERG EBV!
    By captmarvin in forum 2004-2010 (E60,E61)
    Last Post: 01-01-2015, 07:25 PM
  3. AWD & DSC malfunction + alignment?
    By annieontheroad in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 12-22-2010, 01:48 PM
  4. 2006 BMW 530xi - AWD/ DSC malfunction - brake - ABS
    By syrus in forum 2004-2010 (E60,E61)
    Last Post: 11-06-2010, 09:44 PM
  5. DSC and ABS malfunction
    By Brostradamus in forum 2001 - 2006 M3 (E46)
    Last Post: 07-23-2008, 01:51 PM
