BAVToys
Results 1 to 2 of 2
Thread: 2011 BMW 328i Convertible e93, Need HELP - left headlight hi/low not working
    Dec 2016
    Phelan, CA
    Cessna, 2011 BMW Conv.
    On my 2011 BMW 328i, convertible, e93, left side (driver) headlight, hi/low beams would not work. (Bi xenon).
    I purchased the car a few weeks ago and some condensation was visible inside the headlight (left only). I found also some corrosion that I have cleaned gently with a wire brash, tooth brash and a spray for cleaning electrical connections.
    So far, I have removed the front bumper and removed the head light.
    I have replaced all bulbs, no go
    I checked all (glove compartment only) fuses, no go.
    I switched all components, ballasts from the working (right side) and..no go.
    I bought all new components, no go .
    I checked which slats/pins on the main connector to the headlight are hot -
    when the switch is on hi beam, (power on) - slat/Pin #’s 3, 4, 5, 6, are hot
    when the switch is on the low beams - slat/pin #’s 4, 5, are hot. (Switch is on and the car is running).
    what the hell do I miss?
    I donĀ’t know how to check the bulbs them self, ( high power)
    I donĀ’t have the headlight wire diagram, maybe someone here would be kind to post or just contact me.
    I hate to go and spend $1,000.00 ouch.
    I going crazy, what did I miss? I can not drive and enjoy my newly purchased car.
    Is there is some individual or a reputable business that I can sent the headlight for repair?
    is anyone here have an headlight for sale for a reasonable price?
    If I would try to convert the headlight (bi xenon) to LED, would it help?
    P.S. I will checked for continuity, from the main plug pins to the bulb.... no continuity
    Are there on the market none factory adaptive headlights?
    A Million thanks in advance.
    James
    Dec 2016
    Phelan, CA
    Update:
    Today I have bench tested the headlight and high and low lights are working. Now is time to go outside and connect the headlight to the car.
    Showwiz
  1. F30 2015 BMW 328i SULE F30 need help or suggestion with fizing error codes
    By kaupuku in forum 2012-2019 (F30, F32, F33, F34, F36)
    Last Post: 06-11-2019, 07:09 PM
  2. FS: E93 - 2011 BMW 328i Convertible - WHITE, Loaded, 55,995 mi., PRISTINE CONDITION
    By CatsMeow83 in forum Non Specific BMWs (Classics, Exotics, MINIs)
    Last Post: 04-09-2019, 01:15 PM
  3. 2013 BMW 328i Convertible (E93) - Sensor Cover Fell Out?
    By petes457 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 06-08-2018, 09:24 PM
  4. 2011 BMW 328i convertible (e93)
    By amb1984 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-04-2015, 09:40 AM
  5. NEED HELP!!!! PLEASE>>>ALL Windows are NOT Working
    By MPowerAG in forum 1991 - 1999 (E36)
    Last Post: 10-30-2002, 09:24 PM
