Results 1 to 2 of 2
    Feb 2018
    Seattle
    BMW X5
    Post X5 heater blows hot on one side, cold on other, then switches....
    I’ve seen a couple similar posts for this issue, but mine is a little different. So over the past couple days while using the heater in my 2010 x5, the passenger side will blow cold air, if I turn the temp knob up it will start blowing warm for a while then switch back to cold air. Here’s the different part, it switches back and forth between the passenger and drivers side. If I turn up the temps i do get responses in temps coming out of the vents, both sides will be warm, but it’s doesnt last, then switches to one side being cold.. And it’s only cold one side at a time, seeming to be alternating between driver and passengers side... not sure what could be happening since it’s not just one side, not simultaneous, and alternating...any thoughts?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to X5 forum
  1. IHKA issues - hot one side, cold on the other side
    By orgullodemexico in forum 1988 - 1994 (E32)
    Last Post: 01-28-2016, 10:41 PM
  2. Replies: 6
    Last Post: 01-06-2015, 05:48 PM
  3. Car is lower on one side than the other
    By knickfan5745 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-19-2012, 10:34 AM
  4. Help with A/C not blowing as cold on one side as the other
    By Stonington in forum 1999 - 2006 (E46)
    Last Post: 08-09-2010, 10:42 AM
  5. Heater blowing hot when set to cold!
    By fooboobeegee in forum 8 Series (E31)
    Last Post: 05-12-2009, 12:55 PM
