My driver side door panel is detached and the plastic pieces that holds the clips that attach to the door are all busted.
Does anyone know if those plastic pieces have part numbers that attach to the door panel and can be ordered ? (Not the clips, but the parts on the door panel)
I would like to avoid the expense to get new door panels.
Thanks / Ch
Hi,
You can most likely fix all of the plastic pieces. If yours are really shot, in otherwords completely brittle, then i would recommend getting a used door panel from the wrecker and stripping off the plastic parts yoyu need and glue them on the your panels. If you really want new parts look them up at : realoem.
If you want to go the repair route I would give "instant bond" glue a try when repairing the plastic to plastic repairs, highly recommended. When glueing the plastic pieces to the fiber board I have used Sika brand polyurathane construction adhesive, again highly recommended. The instant bond worked so well I was able to repair my uppermost plastic attachment pieces which are really fragile to almost like new condition and then bonded them on to the fiber board with the Sika.
Hope this helps,
Don B
