Results 1 to 23 of 23
Thread: Fuel siphoning
    Jan 2012
    Upstate South Carolina
    1996 840Ci / 2007 B7
    Fuel siphoning
    I'm trying to siphoning some old fuel out of my car to replace with fresh, so hopefully my first restart attempt will be successful. I am, however, seemingly reaching some obstruction in the filler pipe before reaching the fuel. Is there some trick to siphoning fuel in these cars?
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    Quote Originally Posted by Spandrel View Post
    I had the same problem when I started working on the new to me E31. I never did find a way to siphon from filler neck. So pulled seats and removed carriers which I needed to do anyway to replace fuel pumps and hoses.
    The parts diagram doesn't show any obstruction in drawing.
    radlaw's Avatar
    radlaw is offline SoCalEights Member BMW CCA Member
    Feb 2010
    Poway (San Diego), CA USA
    1995 BMW 840Ci
    Why not just fill your tank with new gas and drive around?
    Jan 2012
    Quote Originally Posted by radlaw View Post
    The gas has been sitting in the tank for almost 4 years with no stabilizer. I don't want to run that through the system (there's a little less than half a tank in there). The fuel lines to the engine were empty, but the fuel was still sitting in the tank.
    Dec 2013
    San Antonio
    I had to change out the fuel pump and fuel sensor carriers so I was able to clean bottom of tank by hand after pouring a can of seafoam into empty tank and letting it stand for several days. I just wiped out the gunk or tar on bottom of tank that seamfoam dissolved.
    Jan 2012
    Quote Originally Posted by JDP530 View Post
    I don't currently have fuel pump work in the plan, and would prefer to leave well enough alone if possible....
    Jan 2012
    Go in from the fuel pump?
    So if i wanted (had to) go in from the fuel pump to siphon, what's the removal procedure? What am I likely to break? How hard is it to get replacements quickly? I can't find anything on TimM's site relating at least...
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    honestly, the best way is to pull the pump/float carriers.
    Short of that, if you just need to empty the tank and refill... this is the only way to do it:
    Disconnect ONE of the fuel feed lines from the metal tube on the firewall.
    Attach a longer hose and stuff the end in one of 4 5gallon gas cans available
    Stick a bolt into the open end of the hose dangling now from the fuel rail. (trust me, just do it)
    Jumper 12v to each of the fuel pump relays.
    Turn it off when the tank is drained.
    This works to drain BOTH sides of the tank, something you could never do with a siphon hose from the fuel door pipe anyway... one pump empties the fuel into your cans, the other keeps the tank leveling siphon circuit going so all the gas eventually ends up being picked up by the pumps.
    Do NOT run the pumps dry for any period of time.. .when the hose stops the spit, you quit.
    For 4yr old gas, that's likely enough... for known heavy sediment and sludge, take out the back seats, open the inspection plates, and take the carriers out from both sides of the saddle. This allows you to literally reach inside and mop it up after draining...
    '91 850i 6sp (mint) (sold)
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    That's certainly the way I would do it - I did the same when emptying 60 Litres from the leaking tank on my 740i
    My BMW Repair YouTube Channel
    Jan 2012
    This is a great idea! I pulled the seats to take a look last night, got impatient and pulled the pump carrier next to the filler neck (RHS) enough to sneak a siphon tube down into that side of he tank and drained it. Still have ~3-4 gallons in the other side (fuel gauge just above the red zone). Debating if it's worth using this method to get that other side, or just put 10 gallons of ethanol free 93 in there with a bottle of fuel system cleaner and roll the dice...
    The rubber covering on the LHS is whole - the disk flap has not been fully cut. Is there a pump carrier on that side as well in an 840? Or is it just an inspection port (or nothing)?
    Doesn't using the pump to empty pull nastiness into the pump? And if I tried running it now, with one side almost completely empty, do I risk running the pump dry?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    There's a sender for the fuel gauge on the LHS - and the tank uses a similar fuel circuit to the E38 as detailed below:
    http://www.meeknet.co.uk/E38/Sender/Index.htm
    Using the pump will get the most possible fuel out of BOTH sides of the tank
    NW suburban Chicago
    hiss by my window
    Why not just disconnect the fuel line and run the pump? After all that's what it is made for.
    I deal with long dormant cars fairly frequently and try not to make more work for myself. If removing the sender you'll want to replace the gasket.
    Some E34s have a drain plug on the tank, not sure if that practice carries over to 8 chassis but might be worth a peek.
    Sep 2008
    Santa Barbara
    Quote Originally Posted by ross1 View Post
    Disconnect ONE of the fuel lines, either at the pump or on the firewall, it doesn't matter... run a hose from that, jumper both fuel relays and empty the tank. This will drain both sides...
    Dec 2013
    San Antonio
    Quote Originally Posted by cartoonz View Post
    Cartoonz, have you picked up your 'new' car? Congratulations on purchase!
    Sep 2008
    Santa Barbara
    PHUNNY car comes home tomorrow
    May 2013
    Salinas CA.
    1993 BMW 850CI
    You are a Lucky cad! I had the pleasure of seeing George only once,,,what a hoot he was, and there was so much more to that night!
    Tampa, FL
    '93 850Ci, '07 X5 4.8
    Congrats on getting "Phunny" man!!
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    Do the Phunny plates come with it?
    91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
    Jan 2012
    Hmmmm. Got around to trying this today. My E-boz doesn't look like the V8 diagram in the linked PDF on your relay finder, Timm:
    diagram:
    That's certainly the way I would do it - I |did the same when emptying 60 Litres from the leaking tank on my 740i
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    No, mine doesn't either, the picture is from the M60 version. Here's mine
    ...and I expect that the fuel pump relay is the one closest to the camera. But, if I were you I would apply power to Fuse 23 rather than poking the relay....
    Jan 2012
    Does it matter which prong gets the positive wire and which the negative? (And thanks for the picture - good to confirm that I put everything back correctly)
    Sep 2008
    Santa Barbara
    Timm has it right, fuse 23... power that
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    You need 0V to the chassis (use the jump point on the suspension tower) and 12V to Fuse 23, you can use either side of the fuse.....
  1. Fuel siphon pump
    By Jpcl in forum 1996 - 2003 (E39)
    Last Post: 01-02-2017, 02:55 PM
  2. Fuel Tank siphon pump and fuel pump
    By 57Thorny in forum 1996 - 2003 (E39)
    Last Post: 11-07-2009, 01:23 AM
  3. What is the siphon pump in the fuel tank supposed to do?
    By bimmer213 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-10-2007, 11:11 AM
  4. fuel levels and siphon pump
    By gsxy in forum 1992 - 1999 M3 (E36)
    Last Post: 07-28-2006, 06:31 PM
