Results 1 to 18 of 18
Thread: 0.75A Battery Drain - Fuse 33 (10A) Cigarette Lighter
    Jun 2004
    SB / LA
    e36M3/4, e60 525, e39
    I decided to wire a dual USB charger into by car while I have my interior taken off.
    I have been getting a 5.2mV (~0.75A) drain on Fuse 33 (10A Cigarette Lighter) which drains the battery over the course of a few days.
    - Wired the power of the charger to the Violet/White radio wire
    - Wired the ground of the charger to the cigarette lighter ground
    - The charger works when the car is on - blue light on the charger
    - The charger doesn’t work when the car is off
    - I have a new battery
    Is this a normal draw with an accessory added?
    [SIZE="1"]1997 M3/4/5 18x8.5 Hartge Classics, F1 Stage 2 Clutch Kit
    :one This Year :: Koni inserts, HR Sport, Rogue RSM, Ball Joints, Powerflex LCAB, Adjustable Sway Links (DIY), Headliner, MM Underpanel, 3 spoke wheel swap, BavSound Speakers, Bluetooth radio adapter
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    That's a function of the accessory you added. Most USB chargers always draw some power, and yours draws more than most.
    Rewire it to a switched source.
    Neil
    Rigel 7
    M3, 850i, E30T, E55T
    I used the glovebox flashlight power as it's switched with ignition, should be plenty for your usb charger.
    Jun 2004
    SB / LA
    great thanks! I will rewire it and test
    Jun 2004
    SB / LA
    I connected to the flashlight in the glovebox and still have a draw - the double usb socket that I’ve wired into it has an inline fuse. Could that be the source of the power drain?
    Double USB is basic, 5v 1A and 5v 2.1A
    Apr 2016
    Philadelphia
    1997 m3
    You actually have more than just the cigarette lighter on that fuse. Heres a diagram of everything that fuse is for. Hope it helps!
    Jun 2004
    SB / LA
    I started with the trunk light and opened the trunk after a few minutes of being closed with the battery connected. The bulb was so hot, so I disconnected the bulb and test the mV reading at the fuse.
    With the bulb in: 5.1mV
    With the bulb out: 11.91V (not mV) —- not sure why it would be so high. Any thoughts?
    I’m using this method
    https://youtu.be/lRcj1fQcWwU
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    Red/white wires are B+. The wire diagram in post #6 shows the charge socket is red/white.
    Violet/white wires are switched ignition.
    Since your interior out, you can easily use the phone power connector that is located around the parking brake/armrest base. It can be pulled back in front of the shifter.
    [IMG][/IMG]
    Jun 2004
    SB / LA
    Left the battery connected overnight to see if the trunk bulb was the cause of the battery drain. Battery was nearly dead - no start but dash lights would still come on.
    Tampa, FL
    97 E36M3 S54
    I don't care what that video says you need to be looking at mA of your battery in series with your DMM. Pull fuses/disconnect things in the car until the idle current plummets. You should be at 15mA on an E36, not 750mA.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    E36 has 30mA, not 15
    Maximum closed current by vehicle: E31 50mA, E32 50mA, E34 40mA, E36 30mA, E38 50mA, E39 40mA, E46 40mA, E52 50mA, E53 40mA, Z3 30mA
    Performing Closed Current Draw Test
    • Select proper measuring device (DISplus, MoDic or DVOM)
    -Remember amperage draw in excess of 10A will damage DVOM.
    -Use inductive amp probe of DISplus when amperage draw is high.
    -When using DISplus inductive probe, clamp on negative battery cable with arrow pointing away from battery. Switch off all consumers. (It is not necessary to disconnect B- from body when using inductive probe)
    • Connect (-) test lead to negative battery terminal and (+) test lead to a known good ground.
    • Ensure all systems are OFF !
    • Be sure DVOM is on and set in proper mode.
    • Disconnect battery ground lead from body.
    • Observe meter reading, wait 16 minutes for vehicle to enter sleep mode.
    • Identify faulty circuit by disconnecting fuses, relays, control modules or connectors, observing meter readings.
    • Defective circuit is found when current is below maximum closed current for vehicle being tested.
    use this link for more details http://www.e38.org/battery.pdf
    Jun 2004
    SB / LA
    Quote Originally Posted by M52 POWER! View Post
    Thanks gonna work on that Thursday
    Quote Originally Posted by shogun View Post
    Great info - much appreciated
    Tampa, FL
    97 E36M3 S54
    You're quoting the maximum, my number was typical, usual, expected. In fact I literally last week measured it on my car as I was doing some wiring and saved the picture....
    Jan 2003
    USA
    BMW M3
    Subscribed.
    Jun 2004
    SB / LA
    Here is my set up to test the draw. However the reading is zero, none of the lights are on when it’s set like this etc... I reconnected the negative terminal and I took a video inside the trunk after closing it - the trunk light remained on with the trunk lid closed. 2 questions:
    1. Is my setup incorrect for testing amp draw?
    2. Is there a DIY for the trunk light switch? I searched but couldn’t really find one.
    Dec 2013
    La Center, WA
    98 M3 Sedan, 97 M3 Coupe
    Quote Originally Posted by persiandude View Post
    Your wiring looks fine for measuring the amp draw. It's hard to see but it looks like your red connector on the meter needs to be plugged in the right side. mA is on the right side and A is on the left side.
    Tampa, FL
    97 E36M3 S54
    On your DMM you have it set to AC amps (the ~ line gives it away), which will show 0A on a DC circuit. Not familiar with that meter, but you likely need to press the function button to change it to DC amps.
    AC left, DC right.
    Edit: one more thing, make sure you don't pull any loads that are > 10A or it'll immediately pop the fuse in the meter. Loads like door locks, windows, headlights, AC fan etc need to be avoided.
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    M52, I never question a man who uses a Fluke!
  1. Parasitic battery drain: Fuse 8 : passenger door control module
    By Stilllearning6 in forum 1995 - 2001 (E38)
    Last Post: 02-17-2017, 05:32 PM
  2. Battery drain / Fuse 55 Servotronic
    By BIMMERBOBBYB in forum 1995 - 2001 (E38)
    Last Post: 11-06-2016, 11:50 AM
  3. Battery Drain - Fuse 41 Brake Light circuit cause/fix?
    By Smafie in forum E39 Touring / Wagon
    Last Post: 12-04-2015, 04:43 PM
  4. 93 325is battery drain fuses stay on
    By bimm3rFan in forum 1991 - 1999 (E36)
    Last Post: 03-08-2015, 04:29 PM
  5. Battery Drain (Fuse 56)
    By vhariable in forum 1995 - 2001 (E38)
    Last Post: 01-22-2013, 10:49 PM
